Whenever I try to upload a sketch to my new rainbowduino I get the error "stk500_recv(): programmer is not responding". I have tried all of the "voodoo" out there regarding pressing the reset button at the perfect moment but nothing has worked. Does anyone have any suggestions on what I can try. I'm starting to think that the chip is bad.
I just got a rainbowduino but am having issues uploading a sketch to it. I have looked all over the forum and the internet but noting suggested to other people has worked for me. I have tried pressing the reset button at tons of different times during/before the upload process as suggested by some people with no result. The error I am getting when uploading is "stk500_recv(): programmer is not responding". Does anyone have any suggestions? I'm starting to think that my chip is bad.
Chip: Rainbowduino ATmega328
Computer OS: windows 10
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\Mark\Desktop\arduino-nightly\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM3
Using Programmer : arduino
Overriding Baud Rate : 57600
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x53
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x53
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x53
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x53
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x53
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x53
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x53
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x53
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x53
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x53
Windows 10 also usually means there is a chance you are using USB 3.0
Sometimes that can be a problems with Arduinos so make sure you are using a USB 2.0 port.
If you don't have a USB 2.0 port insert a USB 2.0 "POWERED" hub between the USB 3.0 port and the Arduino.
...which uses an FTDI adapter. Forcing the processor into reset is irrelevant. If you suspect the FTDI adapter is not working correctly, disconnect it from the Rainbowduino then connect a jumper between TX and RX. The reset of the loop-back steps are essentially the same.
Let's build some board, slap an Atmel chip on it and call it crapDuino.
No support needed, 'cause they'll end up with their questions at the Arduino forum..
If this is your board, the reset pin is at the red arrow (there's a text ´RST´ right there).
One of the available GND pins (male in this case) is at the blue arrow.
You can also keep pressing the reset button during your test, does the same thing.
By the way, looks like both sterretje as well as Coding Badly are right.
You can daisy-chain these boards.
And the means to do so, offers a nice way to also use an external adapter board to be able to upload to this board, so it seems (all pins seem to be available, looking at the above picture)
Thanks for the visual MAS3 I was able to run the loop test but had no results. The lights on the board light up but nothing is echoed back when I enter stuff into serial monitor. So if nothing is echoed back what does that mean?
I have tried multiple USB cables and ports all of which are known to work.
When you say the USB-to-serial converter is not powered does that mean that I need to have a power supply plugged into the board when I am uploading to it?
