Hi All,
(So sorry for my English not so good)
I'm a new about Arduino, I need your help with my code as below.
My explanation about the function of my system
With Arduino Pro Mini by Deek Robot
I'm using with the remote control by other together with raindrop sensor for control motor.
- 2 signal from remote control to do forward and reverse of motor, relay output is operated accordingly
- When raindrop sensor detected, only forward relay take activity, reverse relay will be cancel
Raindrop sensor output is attached by interrupts function.
My problem that when motor is running by remote control if raindrop is detected, motor is running as required, it is correct. But the system is ready standby, if raindrop is detected at this time, motor did not run smoothly, output relay have taken ON then OFF in short time then ON again, look like blink.
Here is my code, kindly take your time to help me with my best regards:
int limitted = 5; //limitted switch
int remoteFo = 9; //input for Forward from remote control board
int remoteRe = 7; //input for Reverse from remote control board
int FoPin = 10; //output for Forward relay
int RePin = 11; //output for Reverse relay
int CoPin = 12; //output for magetic brake
pinMode(FoPin, OUTPUT);
pinMode(RePin, OUTPUT);
pinMode(CoPin, OUTPUT);
pinMode(remoteFo, INPUT_PULLUP);
pinMode(remoteRe, INPUT_PULLUP);
pinMode(limitted, INPUT_PULLUP);
attachInterrupt (0, Rain, LOW);
void Rain()
int limitedFo = digitalRead(limitted);
delay(200);
digitalWrite(RePin, HIGH);
if (limitedFo == LOW) {
digitalWrite(CoPin, LOW);
digitalWrite(FoPin, LOW);
else {
digitalWrite(FoPin, HIGH);
digitalWrite(CoPin, HIGH);
int stateFo = digitalRead(remoteFo);
if (stateFo == LOW) {
delay(100);
else {
int stateRe = digitalRead(remoteRe);
if (stateRe == LOW)
delay(100);
digitalWrite(RePin, LOW);
else {
