Hello, how would you like help me with the programming of a drawbridge with a geared motor, Stepper Motor Driver A4988 Arduino 3d Printer, 10 Pcs Push Button Switch Without Retention 4 Pins Black Arduino, Precision Resistor 1% 1/4w X 10 Units 130 Values
1 u. | Value: 10K, Photoresistors Ldr Light Sensor 5mm Arduino X 10 Units
1 unit.
I need it to rise when the water level rises or when a boat is going to pass.
Thank you
Have you tested the motor and other components with simple test programs? Can you make a block diagram showing how you are connecting this all together? Do you intend to have something that will supply power to the Arduino, to the motors, etc.
