Hi, is here somebody who can help?
I try to upload code to ESP 32 board, but after compileing sketch there is an error warning: Compilation error: 'ESP_MAC_WIFI_STA' was not declared in this scope; did you mean 'ESP_IF_WIFI_STA'?
Here is a code
#include <Arduino.h>
#include <BleKeyboard.h>
#include <Preferences.h>
#include <WiFi.h> // For getting the MAC address
#if SOFTWARE_SERIAL_AVAILABLE
#include <SoftwareSerial.h>
#endif
// Declare function prototype for generating a serial number
String generateSerialNumber();
// Create a BLE Keyboard instance
BleKeyboard bleKeyboard;
// Create a Preference instance for saving settings
Preferences preferences;
// Define variables
const String RR_Version = "V2.5.1";
const int button1state = LOW;
const int button2state = LOW;
const int button3state = LOW;
const int button4state = LOW;
const int button5state = LOW;
// Define the pins for the LEDs
const int ledBLUE = 34; // Blue LED pin
const int ledRED = 22; // Red LED pin
// Define the pins for the pushbuttons
const int button1 = 19; // Button 1 pin
const int button2 = 18; // Button 2 pin
const int button3 = 5; // Button 3 pin
const int button4 = 4; // Button 4 pin
const int button5 = 2; // Button 5 pin
// Define the pin for the mode switch button.
const int modeSelect = 21;
// Default value for the selected app. Change this if you want a different default app.
// 0: No softapp yet
// 1: Locus Maps
// 2: Rally Navigator
// 3: OsMand
// 4: Piste Roadbook Reader
// 5: Terra Pirata
int softApp = 0; //Locus set as default when starting unit
int softAppSaveValue; // temp softApp value for EEPROM
// Define the delay time in ms between button presses and between toggle switches.
const int buttonWait = 250; // Button delay time
const int toggleWait = 20; // Toggle switch delay time
const int ledFlashDelay = 150;
const int ColorBlack = 0;
const int ColorBlue = 1;
const int ColorRed = 2;
// Function to blink the blue LED
void blinkBlueLed() {
digitalWrite(ledBLUE, LOW);
delay(150);
digitalWrite(ledBLUE, HIGH);
// Function to generate a serial number based on the last 3 bytes of the MAC address
// Function to generate a 6-digit serial number based on the last 3 bytes of the MAC address
String generateSerialNumber() {
uint8_t baseMac[6];
esp_read_mac( baseMac,ESP_MAC_WIFI_STA); // Read the MAC address
// Extract the last 3 bytes of the MAC address and convert them to a 6-character string
char serialNumber[7]; // 6 hex digits + null terminator
sprintf(serialNumber, "%02X%02X%02X", baseMac[3], baseMac[4], baseMac[5]);
return String(serialNumber); // Return the 6-character serial number
// Function to get the unique chip ID as a serial number
/*String getChipID() {
// The chip ID is based on the last 24 bits of the MAC address
uint32_t chipId = 0;
for(int i=0; i<17; i+=8) {
chipId |= ((ESP.getEfuseMac() >> (40 - i)) & 0xFF) << i;
return String(chipId);
// Forward declarations
void flashLedIndicator(int FlashCount, int FlashDelay, int FlashColor);
void storeSoftApp(int softAppVal);
// This function is called once when your program starts. It's used to initialize variables,
// input and output pin modes, and other libraries needed by your sketch.
// Initialize serial communication for debugging
Serial.println("Starting Rampage Controller ...");
// Load previous softApp selection from preferences
preferences.begin("my-app", false); // Open preferences
softAppSaveValue = preferences.getUInt("counter", 0); // Retrieve saved value
preferences.end(); // Close preferences
// Set the softApp to the saved value
if (softAppSaveValue > 5) {
softApp = 0; // Reset to 0 if the value exceeds the number of apps
softApp = softAppSaveValue; // Otherwise, set to the saved value
// PRINT STARTUP STATUS
Serial.print("Rampage Controller Version: ");
Serial.println(RR_Version);
Serial.print("You are in softApp: ");
Serial.println(softApp);
// Generate BLE name with version and chip ID
String bleName = "Rampage_" + generateSerialNumber();
Serial.print("BLE Name: ");
Serial.println(bleName); // Print to check the full name
// Initialize BLE with the generated name
bleKeyboard = BleKeyboard(bleName.c_str());
bleKeyboard.begin();
Serial.println("BLE Keyboard started and advertising...");
Serial.print("BLE Advertising with name: ");
// Set up button pins as input with built-in pullup resistors
pinMode(button1, INPUT_PULLUP);
pinMode(button2, INPUT_PULLUP);
pinMode(button3, INPUT_PULLUP);
pinMode(button4, INPUT_PULLUP);
pinMode(button5, INPUT_PULLUP);
// Set up LED pins as output
pinMode(ledBLUE, OUTPUT);
pinMode(ledRED, OUTPUT);
// Set up mode select switch pin as input with built-in pullup resistor.
pinMode(modeSelect, INPUT_PULLUP);
// Indicate ready state by setting the blue LED on
digitalWrite(ledRED, LOW);
// THIS IS THE LOOP SECTION OF THE CODE THAT KEEPS LOOPING AND RUNNING
// START SOFT APP SELECT LOOP
// The digitalRead(modeSelect) function checks if the mode select button has been pressed (LOW means button press)
if (digitalRead(modeSelect) == LOW) {
// Turn on the red LED (HIGH) and turn off the blue LED (LOW)
flashLedIndicator(0,0,ColorRed); //Set Red Led
// Check if button 1 has been pressed
if (digitalRead(button1) == button1state) {
// If button 1 has been pressed, set the softApp variable to 1
softApp = 1;
storeSoftApp(softApp);
// Output a message to the serial console
Serial.println("While in Mode Select you have selected softApp 1: Locus Maps.");
// Send a message via Bluetooth to the connected device
if (bleKeyboard.isConnected()) {
bleKeyboard.println("App 1: Locus"); }
// Call function to flash LED according to softApp # selected
flashLedIndicator(1,ledFlashDelay,ColorBlue);
// End of select softapp 1
// Check if button 2 has been pressed
// The sequence of operations is the same as for button 1, but softApp is set to 2
if (digitalRead(button2) == button2state) {
softApp = 2;
Serial.println("While in Mode Select you have selected softApp 2: Rally Navigator.");
bleKeyboard.println("App 2: Rally"); }
flashLedIndicator(2,ledFlashDelay,ColorBlue);
// End of select softapp 2
// Check if button 3 has been pressed
// The sequence of operations is the same as for button 1 and 2, but softApp is set to 3
if (digitalRead(button3) == button3state) {
softApp = 3;
Serial.println("While in Mode Select you have selected softApp 3: OsMand.");
bleKeyboard.println("App 3: OsMand"); }
flashLedIndicator(3,ledFlashDelay,ColorBlue);
// End of select softapp 3
// Check if button 4 has been pressed
// The sequence of operations is the same as for button 1, 2, and 3, but softApp is set to 4
if (digitalRead(button4) == button4state) {
softApp = 4;
Serial.println("While in Mode Select you have selected softApp 4: Piste Roadbook Reader.");
bleKeyboard.println("App 4: Piste"); }
flashLedIndicator(4,ledFlashDelay,ColorBlue);
// End of select softapp 4
// Check if button 5 has been pressed
if (digitalRead(button5) == button5state) {
softApp = 5;
Serial.println("While in Mode Select you have selected softApp 5: Terra Pirata.");
bleKeyboard.println("App 5: Terra Pirata"); }
flashLedIndicator(5,ledFlashDelay,ColorBlue);
// End of select softapp 5
// END SOFT APP SELECT LOOP
// START SOFT APP RUN LOOP
if (digitalRead(modeSelect) == HIGH) {
flashLedIndicator(0,0,ColorBlue); // Set Blue Led
delay(ledFlashDelay);
if (!bleKeyboard.isConnected()) {
flashLedIndicator(1,ledFlashDelay,ColorRed); }
if (softApp == 0) { // App 0 No softApp value yet
Serial.println("You are in softApp: ZERO");
} // End softapp 0
if (softApp == 1) {
// App 1 Locus Maps : Button 1 : Zoom In : Vol +
// App 1 Locus Maps : Button 2 : Zoom Out : Vol -
// App 1 Locus Maps : Button 3 : Map Up : 'r'
// App 1 Locus Maps : Button 4 : Centre Map : 'c'
// App 1 Locus Maps : Button 5 : Display on/off : 'd'
// PUSH BUTTONS
Serial.println("Button 1 - Locus - Volume Up");
// Sending the command for zooming in : Volume Up
bleKeyboard.write(KEY_MEDIA_VOLUME_UP); }
flashLedIndicator(1,10,ColorBlack);
Serial.println("Button 2 - Locus - Volume Down");
// Sending the command for zooming out : Volume Down
bleKeyboard.write(KEY_MEDIA_VOLUME_DOWN); }
Serial.println("Button 3 - Locus - 'r' key");
// Sending the command for map up : the 'r' key
bleKeyboard.write('r'); } // Key r
Serial.println("Button 4 - Locus - 'c' key");
// Sending the command for Map Centre : 'c' key
bleKeyboard.write('c'); } // key c
Serial.println("Button 5 - Locus - 'd' key");
// Sending the command for Display : 'd' key
bleKeyboard.write('d'); } // key d
} // End softapp 1
if (softApp == 2) {
// App 2 Rally Navigator : Button 1 : Trip UP : Vol +
// App 2 Rally Navigator : Button 2 : Trip Down : Vol -
// App 2 Rally Navigator : Button 4 : Scroll UP : Media Next
// App 2 Rally Navigator : Button 5 : Scroll Down : Media Previous
// PUSH BUTTONS
Serial.println("Button 1 - Rally - Volume Up");
// Sending the command for Trip UP : Volume Up
Serial.println("Button 2 - Rally - Volume Down");
// Sending the command for Trip Down : Volume Down
Serial.println("Button 4 - Rally - Next Media");
// Sending the command for Scroll UP : Next Media
bleKeyboard.write(KEY_MEDIA_NEXT_TRACK); }
Serial.println("Button 5 - Rally - Prev Media");
// Sending the command for Scroll Down : Prev Media
bleKeyboard.write(KEY_MEDIA_PREVIOUS_TRACK); }
} // End softapp 2
if (softApp == 3) {
// App 3 OsMand : Button 1 : Pan UP : Dpad_Up
// App 3 OsMand : Button 2 : Pan Down : Dpad_Down
// App 3 OsMand : Button 3 : Centre : 'c'
// App 3 OsMand : Button 4 : Pan Left : Dpad_Left
// App 3 OsMand : Button 5 : Pan Right : Dpad_Right
// PUSH BUTTONS
Serial.println("Button 1 - OsMand - Dpad_Up");
// Sending the command for Pan UP : Dpad_Up
bleKeyboard.write(KEY_UP_ARROW); }
Serial.println("Button 2 - OsMand - Dpad_Down");
// Sending the command for Pan Down : Dpad_Down
bleKeyboard.write(KEY_DOWN_ARROW); }
Serial.println("Button 3 - OsMand - Keycode_C");
// Sending the command for Centre : Keycode_C
Serial.println("Button 4 - OsMand - Dpad_Left");
// Sending the command for Pan Left : Dpad_Left
bleKeyboard.write(KEY_LEFT_ARROW); }
Serial.println("Button 5 - OsMand - Dpad_Right");
// Sending the command for Pan Right : Dpad_Right
bleKeyboard.write(KEY_RIGHT_ARROW); }
} // End softapp 3
if (softApp == 4) {
// App 4 Piste : Button 1 : Rb Scroll Fwd : w
// App 4 Piste : Button 2 : Rb Scroll Rev : x
// App 4 Piste : Button 3 : Trip + : a
// App 4 Piste : Button 4 : Trip - : d
// App 4 Piste : Button 5 : Medial Play/Pause : q
// PUSH BUTTONS
Serial.println("Button 1 - Piste - 'w' key");
// Sending the command for Rb Scroll Fwd : 'w' key
bleKeyboard.write('w'); }
Serial.println("Button 2 - Piste - 'x' key");
// Sending the command for Rb Scroll Rev : 'x' key
bleKeyboard.write('x'); }
Serial.println("Button 3 - Piste - 'a' key");
// Sending the command for Trip + : 'a' key
bleKeyboard.write('a'); }
Serial.println("Button 4 - Piste - 'd' key");
// Sending the command for Trip - : 'd' key
Serial.println("Button 5 - Piste - 'q' key");
// Sending the command for Medial Play/Pause : 'q' key
bleKeyboard.write('q'); }
} // End softapp 4
if (softApp == 5) {
// App 5 Rally Navigator : Button 1 : Fwd scroll : Media Next
// App 5 Rally Navigator : Button 2 : Rev scroll : Media Previous
// App 5 Rally Navigator : Button 3 : Trip + : Vol -
// App 5 Rally Navigator : Button 4 : Trip - : Vol +
// App 5 Rally Navigator : Button 5 : Lock screen : x
// PUSH BUTTONS
Serial.println("Button 1 - media next scroll forward");
Serial.println("Button 2 - media previous scroll down");
Serial.println("Button 3 - Volume - trip +");
Serial.println("Button 4 - Volume + Trip -");
Serial.println("Button 5 - Lock screen");
} // End softapp 5
} // End of HIGH state button loop
} // End of loop code
void flashLedIndicator(int FlashCount, int FlashDelay, int FlashColor) {
if (FlashCount == 0) {
if (FlashColor == ColorBlue) {
digitalWrite(ledBLUE, HIGH); // Turn on the blue LED
digitalWrite(ledRED, LOW); } // Turn off the red LED
if (FlashColor == ColorRed) {
digitalWrite(ledBLUE, LOW); // Turn off the blue LED
digitalWrite(ledRED, HIGH); } // Turn on the red LED
if (FlashColor == ColorBlack) {
else {
int ledBlueState = digitalRead(ledBLUE);
int ledRedState = digitalRead(ledRED);
delay (FlashDelay);
for (int i = 1; i <= FlashCount; i++) {
if (FlashColor == ColorBlue) digitalWrite(ledBLUE, HIGH);
if (FlashColor == ColorRed) digitalWrite(ledRED, HIGH);
delay(FlashDelay);
delay(FlashDelay);
digitalWrite(ledBLUE, ledBlueState);
digitalWrite(ledRED, ledRedState);
void storeSoftApp(int softAppVal) {
preferences.putUInt("counter", softAppVal); // Use softAppVal instead of counter
preferences.end();
Verify your IDE is ready for your hardware. Have you selected the correct board support (which ESP32)? Perhaps the board you selected does not have WIFI, therefore, no need to have a defined value for reading the WIFI MAC?
Thanks for reply. I posted code in right way now....
My board is ESP32 WROOM-32
I do not know the ESP32 (or WROOM-32), but is this the file you need for wifi?
#include "esp_wifi.h"
Found here... Wi-Fi - ESP32 - — ESP-IDF Programming Guide v5.4.1 documentation
No, it's
#include <WiFi.h>
Try adding:
#include <esp_mac.h>
It still doesn't work ...
Not the most informative of feedback. What didn't work? Post the updated code. Post the complete error message verbatim, not your paraphrased version of it. What version of the Arduino ESP32 Board Core Package are you using?
C:\Users\juraj\Downloads\2.5.1 Rampage Bluetooth Controller 2.5.1\2.5.1 Rampage Bluetooth Buttons Open Source Files Stable 20240831\03 Arduino Code\rampage_navigator_version_2.5.1\rampage_navigator_version_2.5.1.ino: In function 'String generateSerialNumber()':
C:\Users\juraj\Downloads\2.5.1 Rampage Bluetooth Controller 2.5.1\2.5.1 Rampage Bluetooth Buttons Open Source Files Stable 20240831\03 Arduino Code\rampage_navigator_version_2.5.1\rampage_navigator_version_2.5.1.ino:81:25: error: 'ESP_MAC_WIFI_STA' was not declared in this scope; did you mean 'ESP_IF_WIFI_STA'?
81 | esp_read_mac( baseMac,ESP_MAC_WIFI_STA); // Read the MAC address
| ESP_IF_WIFI_STA
C:\Users\juraj\Downloads\2.5.1 Rampage Bluetooth Controller 2.5.1\2.5.1 Rampage Bluetooth Buttons Open Source Files Stable 20240831\03 Arduino Code\rampage_navigator_version_2.5.1\rampage_navigator_version_2.5.1.ino:81:3: error: 'esp_read_mac' was not declared in this scope
exit status 1
Serves me right for putting more than one request in a post. One more time ....
// RALLY RAMPAGE BLUETOOTH BIKE HANDLEBAR NAVIGATION CONTROLLER
// www.rallyrampage.com
// Version: 2.5.1 (Stable BLE and LED Status Update)
// Updated: 2024-10-14
// Ownership: Rally Rampage
// Published by: Rally Rampage
// Target Hardware: ESP32 Wroom Development Board
// UNIQUE FEATURES
// Five apps commands including Terra Pirata Roadbook Reader
// Remembers the last app when lost power
// reconnects on power up again
#endif
// Define variables
// 1: Locus Maps
// 3: OsMand
// 5: Terra Pirata
delay(150);
uint8_t baseMac[6];
softApp = 1;
softApp = 2;
softApp = 3;
softApp = 4;
softApp = 5;
} // End softapp 0
if (softApp == 1) {
// PUSH BUTTONS
} // End softapp 1
if (softApp == 2) {
// PUSH BUTTONS
} // End softapp 2
if (softApp == 3) {
// PUSH BUTTONS
} // End softapp 3
if (softApp == 4) {
// PUSH BUTTONS
} // End softapp 4
if (softApp == 5) {
// PUSH BUTTONS
} // End softapp 5
else {
delay (FlashDelay);
delay(FlashDelay);
delay(FlashDelay);
preferences.end();
I don't know where to find core board package, this is my first experience with arduino or esp boards...
It's available from the IDE's board manager. Exactly where depends on which version of the IDE you're using. With v1.8.x it's Tools --> Board --> Board Manager
Also, which board have you selected to compile for? Again with With v1.8.x it's Tools --> Board
The following minimalist code compiles for me with ESP32 Core v3.1.1 which is fairly recent.
#include <WiFi.h>
uint8_t baseMac[6];
esp_read_mac(baseMac, ESP_MAC_WIFI_STA);
I was wrong. Remove this and use #include <WiFi.h>.
version of IDE is 2.3.4 and the board is esp 32 wroom DA module
The IDE version is not the same as the ESP32 Arduino Core version. I don't use IDE 2.x, so I can't tell you where to find that info. But it would behoove you to find out. Knowing the Core version is much more important with ESP32 than with other platforms as there can be significant changes to the API calls between different versions.
What happened when you tried my code from Post #14?
Your code can be easily upload to the board.
Chip is ESP32-D0WD-V3 (revision v3.1)
Features: WiFi, BT, Dual Core, 240MHz, VRef calibration in efuse, Coding Scheme None
Crystal is 40MHz
MAC: 5c:01:3b:72:f0:44
Some info about board...
This detailed logfile will contain all the information that is needed to analyse the error
Why did you put #include <esp_mac.h> inside that preprocessor conditional compilation clause? Move it to right under #include <WiFi.h>. Also, delete #include "esp_wifi.h", you don't need it at all.
I made it as you told me and there are still lot of warnings, maybe it is due to some libraries...
In file included from c:\Users\juraj\Documents\Arduino\libraries\ESP32_BLE_Keyboard\BleKeyboard.cpp:14:
C:\Users\juraj\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/include/driver/deprecated/driver/adc.h:19:2: warning: #warning "legacy adc driver is deprecated, please migrate to use esp_adc/adc_oneshot.h and esp_adc/adc_continuous.h for oneshot mode and continuous mode drivers respectively" [-Wcpp]
19 | #warning "legacy adc driver is deprecated, please migrate to use esp_adc/adc_oneshot.h and esp_adc/adc_continuous.h for oneshot mode and continuous mode drivers respectively"
c:\Users\juraj\Documents\Arduino\libraries\ESP32_BLE_Keyboard\BleKeyboard.cpp: In member function 'void BleKeyboard::begin()':
c:\Users\juraj\Documents\Arduino\libraries\ESP32_BLE_Keyboard\BleKeyboard.cpp:105:19: error: cannot convert 'std::string' {aka 'std::__cxx11::basic_string<char>'} to 'String'
105 | BLEDevice::init(deviceName);
| std::string {aka std::__cxx11::basic_string<char>}
In file included from c:\Users\juraj\Documents\Arduino\libraries\ESP32_BLE_Keyboard\BleKeyboard.cpp:7:
C:\Users\juraj\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\libraries\BLE\src/BLEDevice.h:41:27: note: initializing argument 1 of 'static void BLEDevice::init(String)'
41 | static void init(String deviceName); // Initialize the local BLE environment.
c:\Users\juraj\Documents\Arduino\libraries\ESP32_BLE_Keyboard\BleKeyboard.cpp:116:32: error: no matching function for call to 'BLECharacteristic::setValue(std::string&)'
116 | hid->manufacturer()->setValue(deviceManufacturer);
In file included from C:\Users\juraj\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\libraries\BLE\src/BLEServer.h:23,
from C:\Users\juraj\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\libraries\BLE\src/BLEDevice.h:21:
C:\Users\juraj\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\libraries\BLE\src/BLECharacteristic.h:79:8: note: candidate: 'void BLECharacteristic::setValue(uint16_t&)'
79 | void setValue(uint16_t &data16);
C:\Users\juraj\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\libraries\BLE\src/BLECharacteristic.h:79:27: note: no known conversion for argument 1 from 'std::string' {aka 'std::__cxx11::basic_string<char>'} to 'uint16_t&' {aka 'short unsigned int&'}
C:\Users\juraj\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\libraries\BLE\src/BLECharacteristic.h:80:8: note: candidate: 'void BLECharacteristic::setValue(uint32_t&)'
80 | void setValue(uint32_t &data32);
C:\Users\juraj\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\libraries\BLE\src/BLECharacteristic.h:80:27: note: no known conversion for argument 1 from 'std::string' {aka 'std::__cxx11::basic_string<char>'} to 'uint32_t&' {aka 'long unsigned int&'}
C:\Users\juraj\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\libraries\BLE\src/BLECharacteristic.h:81:8: note: candidate: 'void BLECharacteristic::setValue(int&)'
81 | void setValue(int &data32);
C:\Users\juraj\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\libraries\BLE\src/BLECharacteristic.h:81:22: note: no known conversion for argument 1 from 'std::string' {aka 'std::__cxx11::basic_string<char>'} to 'int&'
C:\Users\juraj\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\libraries\BLE\src/BLECharacteristic.h:82:8: note: candidate: 'void BLECharacteristic::setValue(float&)'
82 | void setValue(float &data32);
C:\Users\juraj\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\libraries\BLE\src/BLECharacteristic.h:82:24: note: no known conversion for argument 1 from 'std::string' {aka 'std::__cxx11::basic_string<char>'} to 'float&'
C:\Users\juraj\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\libraries\BLE\src/BLECharacteristic.h:83:8: note: candidate: 'void BLECharacteristic::setValue(double&)'
83 | void setValue(double &data64);
C:\Users\juraj\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\libraries\BLE\src/BLECharacteristic.h:83:25: note: no known conversion for argument 1 from 'std::string' {aka 'std::__cxx11::basic_string<char>'} to 'double&'
C:\Users\juraj\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\libraries\BLE\src/BLECharacteristic.h:77:8: note: candidate: 'void BLECharacteristic::setValue(uint8_t*, size_t)'
77 | void setValue(uint8_t *data, size_t size);
C:\Users\juraj\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\libraries\BLE\src/BLECharacteristic.h:77:8: note: candidate expects 2 arguments, 1 provided
C:\Users\juraj\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\libraries\BLE\src/BLECharacteristic.h:78:8: note: candidate: 'void BLECharacteristic::setValue(String)'
78 | void setValue(String value);
C:\Users\juraj\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\libraries\BLE\src/BLECharacteristic.h:78:24: note: no known conversion for argument 1 from 'std::string' {aka 'std::__cxx11::basic_string<char>'} to 'String'
Using library ESP32 BLE Keyboard at version 0.3.0 in folder: C:\Users\juraj\Documents\Arduino\libraries\ESP32_BLE_Keyboard
Using library BLE at version 3.2.0 in folder: C:\Users\juraj\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\libraries\BLE
Using library Preferences at version 3.2.0 in folder: C:\Users\juraj\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\libraries\Preferences
Using library WiFi at version 3.2.0 in folder: C:\Users\juraj\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\libraries\WiFi
Using library Networking at version 3.2.0 in folder: C:\Users\juraj\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\libraries\Network
exit status 1
Compilation error: exit status 1
