RAM efficient way of sending string to class function
So my current code works but is starting to consume large amounts of RAM. I am building a display library that contains all the commands/function required for my Arduino to interact with my Nextion interface.
One example: a function in my library class that sends a change of txt value command to any component on the Nextion:
void SAVC_Display::SendText(uint8_t page, char *objectName, char *text) {
    SendPage_Object(page, objectName);
    _DISPLAY.print(F(".txt=\""));
    _DISPLAY.print(text);
    _DISPLAY.print(F("\""));
    SendCommandEnd();
In my main c++ file i call this in various different ways: (Screen is my class instance)
Screen.SendText(0, "tYes_Season", "Spring");
Screen.SendText(0, "tHeaderTitle", title);  //title is a char[31] array
I am assuming that by passing these to the function as a literal string (which I want to get away from) it puts the literal string value into RAM at start up or something?
One idea was to create a list of PROGMEM variables to store all the component names. But that test didn’t work as you can’t point to it. I also have over 150 components on my Nextion pages so a little impractical.
I may be missing something obvious here or just being a complete noob.
Any advice/guidance would be greatly appreciated.
Sure you can:
void printProgmemString(const __FlashStringHelper *p);
const char myString[] PROGMEM = "Hello World";
	printProgmemString((__FlashStringHelper *) myString);
void printProgmemString(const __FlashStringHelper *p) {
	Serial.println(p);
I’m sure someone can post similar code using one of the fancy C++ specific casting methods. But, quite frankly, I can never keep them straight.
That seems like a feasible solution for solving the usage of RAM.
However as I have over 150 components i’d have to create a PROGMEM variable for every one.
Are there any other solutions?
Why don’t you use an array?
const char stringArray[][10] PROGMEM {
		"String 0",
		"String 1",
		"String 2"
const size_t numStrings = sizeof(stringArray) / sizeof(stringArray[0]);
	for (size_t i = 0; i < numStrings; i++) {
		printProgmemString((__FlashStringHelper *) stringArray[i]);
	Serial.println(p);
Ok, so with your help on the FlashStringHelper casting i actually come up with a solution similar to yours but without the need to declare every single component name as a PROGMEM variable.
So now my class looks like this:
void SAVC_Display::SendText(uint8_t page, const __FlashStringHelper *objectName, char *text) {
    SendCommandEnd();
and I call the function like so:
Screen.SendText(0, F("tYes_Season"), "Spring");
Screen.SendText(0, F("tHeaderTitle"), title);  //title is a char[31] array
That stores the string into PROGMEM instead of RAM and will pass a pointer to the function. Works a treat.
Just changing this over on that once function has had a huge impact to my RAM usage:
BEFORE
RAM: [== ] 22.4% (used 1832 bytes from 8192 bytes)
Flash: [= ] 13.1% (used 33250 bytes from 253952 bytes)
AFTER
RAM: [== ] 17.9% (used 1468 bytes from 8192 bytes)
Flash: [= ] 13.1% (used 33368 bytes from 253952 bytes)
EDIT:
After changing all the functions that used the methodology in my original post I have saved over 700 bytes of RAM.
RAM: [= ] 14.4% (used 1178 bytes from 8192 bytes)
Flash: [= ] 13.3% (used 33750 bytes from 253952 bytes)
I’ve given you the solution for this one as it was your code that inspired the final solution. Thanks again!
