I wrote a script to control a single step mash for brewing beer using the Arduino board. The input is from a thermistor and the output turns a pump and heater on.
This is less impressive than it sounds, because 1. I don't have a thermistor, 2. I don't have parts for a pump or heater control circuit, 3. I don't have a pump or electric heater and 4. I don't have an electric brewing system.
This script can turn on LED lights (which represent ON signals to the heater and pump) at the appropriate times. At this time I am using a potentiometer to represent a thermistor, so to check it I am manually adjusting the "temperature" while the script runs.
Actually, I have a draft three step mash script written, but I want to get my thermistor and adjust this script so it works with the values that the thermistor returns before I work out the bugs.
This script seems to work, I will just have to adjust the temperature values to match what the thermistor returns and change the times to fit real brewing times.
int T = 0; //initialize variables, T is the input from the thermistor
int oneT = 600; // oneT is the desired mash temperature, as returned by the thermistor and determined by measurement
int oneTmin = 580; // the temp when you want the heater to kick in
int oneTmax = 620; // the temp when the heater should turn off
int oneS = 0; // If oneS is 0, then the mash has not yet started. If it is 1, then the mash has started.
int oneC = 0; // If oneC is 0, then the mash is not yet complete. If it is 1, then the mash is complete.
long startone = 0; // placeholder for the starting time for mash 1
long stopone = 0; // placeholder for the stop time for mash 1
long remaining = 0; // difference between startone and stopone
int remainsecs = 0; // convert to something close to a second like integer
void setup(){ // run setup once
pinMode(4, OUTPUT); // initialize pin 4 as output, will be used to trigger heater relay circuit
pinMode(8, OUTPUT); // initialize pin 8 as output, will be used to trigger pump relay circuit
Serial.begin(9600); // sends serial data to pc, allow for reading the temp and status as reported by Serial.print
void loop(){ // loop this as long as Arduino has power or until reset button is pressed
delay(3000); // 3 second delay between loops
T = analogRead(2); // get voltage from thermistor
Serial.print("Temperature: "); // print thermistor value to pc, this is not really temp but a number between 1 and 1024
Serial.print(T);
Serial.print("\n");
if (oneC == 1){ // if mash is complete, loop this
digitalWrite(4, LOW); // LOW tells board to output 0V on pin
digitalWrite(8, LOW);
Serial.println("MASH STEP 1 COMPLETE"); // this prints out every 3 seconds when mash is done
if (oneC == 0){ // if mash is not complete do the next big loop
if (oneS == 0){ // if mash has not been started, do this loop
if (T < oneT){ // if temperature is less than mash temp, do this
digitalWrite(4, HIGH); // HIGH tells board to output 5V on pin, this turns pump and heater on
digitalWrite(8, HIGH);
if (T > oneT){ // if temp is more than mash temp, do this loop
digitalWrite(4, LOW); // turn off heat and pump
oneS = 1; // start mash by toggling oneS to YES (or 1)
startone = millis(); // start mash clock, reads milliseconds from this moment
stopone = startone + 50000; // calculate the end of mash, here just an arbitrary 50000 milliseconds, later will be 3.6 million milliseconds or 60 minutes
Serial.print("Started Mash Step 1 at ");
Serial.print(millis()); // still need to convert this into human readable time, it is milliseconds now
Serial.print("\n");
if (oneS == 1){ // If mash has started do this loop, note we have already tested that mash has not completed.
long curtime = millis(); // set variable curtime to the elapsed time since program started
remaining = (-1)*(curtime - stopone); // caculate how many milliseconds until mash is complete
remainsecs = (int)(remaining/1000); // convert into human readable second like intervals but not exact
Serial.print(remainsecs); // print it to screen
Serial.print(" - ");
Serial.print("Remaining");
Serial.print("\n");
if (curtime < stopone){ // if we have not yet reached the end of the mash, do this
if (T < oneTmin){ // if the mash temp is less than the minimum temp set in variables above, do this
digitalWrite(4, HIGH); // pour on the heat
if (T > oneTmax){ // if mash temp is over the maximum temp set above, turn off the heat
if (curtime > stopone){ // if we reach the end of the mash time
digitalWrite(4, LOW); // turn off the heat and pump
Serial.print("Stopped Mash Step 1 at "); // print stop time (not really necessary or useful, just for checking)
Serial.print("\n");
oneC = 1; // set mash status to complete, or oneC to YES (1)
Serial.print("\n");
Serial.println("MASH STEP 1 COMPLETE"); // print this once every big loop
