random() always giving the same result, used randomseed()
hi i am trying to generate a random number in the ftp code, but it alwaysgives the same 26807 result i used randomseed(analogRead(A0)), in setup and in the loop, no changes
please help here is the part of my code
randomSeed(analogRead(A0));
  digitalWrite(10,HIGH);
  if(SD.begin(4) == 0)
    Serial.println(F("SD init fail"));
  Ethernet.begin(mac, ip);
  delay(2000);
  Serial.println(F("Ready. Press f or r"));
  byte inChar;
  inChar = Serial.read();
  if(inChar == 'f')
  {randomSeed(analogRead(A0));
    if(doFTP()) Serial.println(F("FTP OK"));
    else Serial.println(F("FTP FAIL"));
  if(inChar == 'r')
    readSD();
File fh;
long rand=random(10000,999999);
Serial.printlt(rand);
the result is always 26807
What is the code supposed to do?
Call randomseed only once but call random every time you want a new number... here it seems you generate only one random number - but unsure as your code is a snippet that won’t compile
Go read the documentation and see the example
long randNumber;
void setup(){
  randomSeed(analogRead(0));
  randNumber = random(50,300); // generate  a random number between 50 and 299
  Serial.println(randNumber);
Is A0 connected to anything? If so, it's not going to produce a good random seed.
If it is not connected to anything and you want it more random you can attach a piece of wire to A0 but don't connect the other end of the wire to anything!
https://forum.arduino.cc/index.php?topic=66206.msg537783#msg537783 might be of interest.
