Random Analog Values With Mega And LM35 Sensor Can't Readanalog
Hi Every Body
I have problem With Mega and temperature Sensor lm35 i Can't Read analog values form any analog provider in this case my sensor lm35
this my code used
int readValue;
float temperature ;
float temperatureF ;
analogReference(INTERNAL2V56);
//Serial.println(readValue);
readValue = analogRead(A0);
temperature = (readValue * 0.0049);
temperature = temperature * 100;
temperature =(temperature/2)+0.5;
temperatureF = (temperature * 1.8) + 32;
Serial.println("Temperature: ");
Serial.print(temperature);
what ever formula not true
but i mast get fixed value
not random value in the attache u can see my result & connected method
Try this code.
int t=0;
int vcc=A2; // sets analog input A0 as +5V source for LM35
int sensor=A3; // sets A1 as the sensor input
int gnd=A4; // sets analog input A2 as ground for LM35
float temp;
float tempc;
float tempf;
pinMode(vcc,OUTPUT);
pinMode(gnd,OUTPUT);
pinMode(sensor,INPUT);
digitalWrite(vcc,HIGH); // sets analog input A0 HIGH
digitalWrite(gnd,LOW); // sets analog input A2 LOW
Serial.begin(9600); // sets the baud rate at 9600
pinMode(13, OUTPUT);
{ delay(1000); // calls a 2 second delay
t=t+1; // increments the time by 2 every two seconds
temp=analogRead(sensor); // reads the LM35 output
tempc=(temp*5)/10; // converts the digital value into temperature degree C
Serial.println("...............");
Serial.println("Temperature logger");
Serial.print("Time in sec = "); // prints the time on serial monitor window
Serial.println(t);
Serial.print("Temperature in deg C = "); // prints the temperature in degreeC
Serial.println(tempc);
if (tempc>281.00){
digitalWrite(13,HIGH);
digitalWrite(13, LOW);
There have been problems with LM35 sensors from ebay.
This simple sketch should work.
It uses the Mega's internal 2.56volt Aref (as in the sketch from OP).
1.1volt Aref could be better though (2.5x better resolution).
Leo..
float tempC;
float tempF;
  analogReference(INTERNAL2V56); // Mega only
  tempC = analogRead(A0) * 0.25; // for 2.56volt Aref only
  tempF = (tempC * 1.8) + 32.0; // Celcius to Fahrenheit
  Serial.print("Celcius: ");
  Serial.print(tempC, 1); // one decimal place
  Serial.print("  Fahrenheit: ");
  Serial.println(tempF, 1);
  delay(1000); // print delay
thanks
sorry my English so bad
i think i have bad sensor
