random blinking without delay and blinking with delay in 1
Thanks for your help! I finally managed to get to a setup I like :slight_smile:
I now have:
2 leds which blink at a different pace
1 led which blinks randomly
1 led which flashes 3 times and waits for a bit and flashes 3 times again
/* Multiple independent delay - 3 different blinking patterns
  Written by several forum members. In public domain.  Oct 2011.
// Which pins are connected to which LED
const byte led12 = 13;
const byte led11 = 12 ;
const int led3 = 4 ;
const byte led9 = 10 ;
// Time periods of blinks in milliseconds (1000 milliseconds to a second).
// Time variable and constants are always unsigned long
const unsigned long led12interval = 300UL ;
const unsigned long led11interval = 350UL ;
unsigned long previousMillis;
unsigned long previousMillisrandom;
unsigned long intervalblinkrandom = 200UL;   // not a constant, it will be changed
unsigned long currentMillis = millis();
unsigned long currentMillisblinkrandom = millis();
unsigned long currentMillisblink = millis();
// Variable holding the timer value so far. One for each "Timer"
unsigned long led12timer = 0 ;
unsigned long led11timer = 0 ;
unsigned long led3timer = 0 ;
unsigned long led9timer = 0 ;
unsigned long waitUntil = 0;
// Variable to know what the current LED state is
int led12State = LOW ;
int led11State = LOW ;
int led3State = LOW ;
int led9State = LOW ;
const unsigned long intervalblink = 50;
int counter = 0;
  pinMode (led12, OUTPUT) ;
  pinMode (led11, OUTPUT) ;
  pinMode (led3, OUTPUT) ;
  pinMode (led9, OUTPUT) ;
  led12timer = millis () ;
  led11timer = millis () ;
  led3timer = millis () ;
  waitUntil += intervalblinkrandom;
  // Handling the blink of one LED.
  // First, check if it is time to change state
  if ( (millis () - led12timer) >= led12interval ) {
    // It is time to change state. Calculate next state.
    if (led12State == LOW)
      led12State = HIGH ;
      led12State = LOW ;
    // Write new state
    digitalWrite (led12, led12State ) ;
    // Reset timer
  // The other LED is controlled the same way. Repeat for more LEDs
  if ( (millis () - led11timer) >= led11interval ) {
    if (led11State == LOW)
      led11State = HIGH ;
      led11State = LOW ;
    digitalWrite (led11, led11State ) ;
  unsigned long currentMillisrandom = millis();
  if ( currentMillisrandom - previousMillisrandom >= intervalblinkrandom)
    previousMillisrandom = currentMillisrandom;
    intervalblinkrandom = random( 25, 300);   // set the new interval
    // toggle
    digitalWrite( led9, digitalRead( led9) == HIGH ? LOW : HIGH);
  if ( currentMillisblink - previousMillis >= intervalblink)
    previousMillis = currentMillisblink;
    // Select what to do with certain values of counter.
    switch ( counter)
      case 0:
      case 2:
      case 4:
        digitalWrite( led3, HIGH);
        break;
      case 1:
      case 3:
      case 5:
        digitalWrite( led3, LOW);
        break;
    counter++;
    if ( counter >= 25)
      counter = 0;
Thanks for your quick help!
