Random characters when running Atmega_Board_Programmer
Hi all,
I just put together my first barebone, following Gammon his tutorial here
then the tutorial gives me this info:
When you run it you should see something like this in the Serial Monitor:
Board Detector Output
Atmega chip detector.
Entered programming mode OK.
Signature = 1E 95 0F
Processor = ATmega328P
Flash memory size = 32768
LFuse = E2
HFuse = DA
EFuse = FD
Lock byte = EF
Bootloader in use: Yes
EEPROM preserved through erase: No
Watchdog timer always on: No
Bootloader is 2048 bytes starting at 7800
Bootloader:
7800: 0C 94 34 3C 0C 94 51 3C 0C 94 51 3C 0C 94 51 3C
7FF0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
MD5 sum of bootloader = 27 EB 87 14 5D 45 D4 D8 41 44 52 CE 0A 2B 8C 5F
First 256 bytes of program memory:
However i get some random charcters,
Written by NxFF 0xFF 0xFF 0xFF 0xFF 0xFF 0xFF 0xFF
Programming mode off.
0xFF 0xFF 0xFF
F0: 0xFF 0xFF 0xFF 0xFF 0xFF 0xFE 0xFF 0xFF 0xFF 0xFF 0xFF 0xFF 0xFF 0xFF 0xFF 0xFF
u$]]JK| %D6OI%D6IKKK"rbbb2 bLRPPR11VV2VV44g4g4EEX; V:&T2''8TTX3""ffDDRDQh"""V"V0gg,TT""JQq"TT''bSb(5RRt"A"A''DQ
V(VRPVVBgg 4r:<0(s ::0"gg@{BBEE,f,P@@D0 ((R",,TT
"sP''$P""q"&q&x"RlQRlQ77RTTT&4VV0bbR@DDqqr4""seRR&VV&XX!tP1bR&T 7R5&T 5KV
2E(#
QT5T
B,R
T,C'b"PDR,R,'Cb"PDQ)ssY@@"F"F b(V(V&TT&&VVIA:A7Rqbd&&dTVV(T
VDIv
DIv,""bPbPT"1b7T1@RfePRfTePT22, ' %P@PVq"'T2""T377bQA"bb"d""Q"qRBq!"BR&2!&6VXV̢ XVQ Q "EV77 EbT8 "ffPKTRP 6bTbfPYbggbbLVL<@bbXR,Q33RRv"D"D b&& Pw     4"'cRbTRT2 5b2 52Г2TT77@@7"zzRQQ'',P@@$P vbTbf0%0%PbL<P""XRBwB2R2"TS fS@@7R!&2V6V@B(7R!&&TЖ(QeR"ȀM'"(7RR`"M"(7R`VV
(52CC2BB#PPPPePe"")R""22VTVbPbPbQV&5"Q5""$dDQ$(V6TT%2(f (JBKbbD@2
 gttT&VV
O@@"D""T"DQT'"QP  "P  "RVZbP$
  &&CCHVH""EE&@DH1 1 52,b  50'AT
T"R
gg EfEE(G32##P
P""S sbbrP:VV;V&
 ePI7T&7&TbT&b&VV&IPs"QRsы21@32T&1@3&775 T3 b 5 ""''Q"R("ZQ"BA"A"P"R$QfR[(QsR[sRRRja&""PRP""c&B4tPPE
f$VI
f$V  2P2CC'T3 b33 5 ""SR"HRlQ''ppL EVP2VVwTVVQQ&,&"@Q"66DIwd'' bbBBjbbEE1V1RPRPI6TTbfl ' ePVV&$H""SP""dRYRYRA"VV@RV"V'!V'!VwwTDKT:SSB7BQQRR"HRHR,Q''"P"P305&&RRH''B"
C'b&@'Cb&@"T55B 5T$RQQDQ(#"A
(DQ (*1baA
( *Ԉ8VbbE&VbTTr6r6PX''fAP
BBRR&&@BPq 'A$3 RRT**&P&Ph$TT  J&&b&&77R R&
There is some readable output in the beginning but it just changes to this weird stuff.
Anybody an idea?
ps:
I have a test led soldered to my barebone this one will blink simultaneously with my original arduino uno when i reset my uno.
(deleted)
spycatcher2k: You need to set the baud rate on the serial monitor to the correct speed (look at the source code).
Wow that was a real simple solution and after searching in the tutorial it's even mentioned. I'm sorry for this stupid mistake thanks for helpen!
