random display
hello I am trying to set up a simple display so when you push a botton a random light, lights up, or LED. i'm trying 3 LEDs right now but will need more later. I am new to this and am a [u]super novice[/u]. tryied writing this code but nothing happons. I read the info on "random" and this is what I came up with ... thanks
(ya I don't know much)
const int BUTTON = 9; long randNumber; int buttonState = 0; int loopwait = 0; int LEDpin (3); void setup() { pinMode (LEDpin, OUTPUT); pinMode (BUTTON, INPUT); randomSeed(analogRead(0)); } void loop() {
//random number to generate an led buttonState = digitalRead(BUTTON); (loopwait = 1000); if (buttonState == HIGH); randNumber = (3);
if (randNumber == 0) { LEDpin = 3; } if (randNumber == 1) { LEDpin = 4; } //20 if (randNumber == 2) { LEDpin = 5; }
buttonState = digitalRead(BUTTON); { if (buttonState == LOW); digitalWrite(LEDpin, HIGH); loopwait = 1000;
} if (buttonState == HIGH); { digitalWrite(LEDpin, LOW); loopwait = 1000; } }
Here's your problem:   randNumber = (3); You have to actually call the random() function to get a random value:   randNumber = random(3);
None of the earlier "if"s had semicolons. Why does this one?
Please remember to use code tags when posting code.
OK so like this? it still doesn't work
//random number to generate an led buttonState = digitalRead(BUTTON); (loopwait = 1000); if (buttonState == HIGH); randNumber = random(3);
if (randNumber == 0) { LEDpin = 3; } if (randNumber == 1) { LEDpin = 4; } if (randNumber == 2) { LEDpin = 5; }
buttonState = digitalRead(BUTTON); if (buttonState == LOW);{ digitalWrite(LEDpin, HIGH); loopwait = 1000;
Still the semicolons. See reply #2
Please, please remember to use code tags.
ok I removed them, still no good.
OK, thanks for letting us know.
loopwait = 1000;
What is this value that you keep setting to the same number but never once use for anything? We're you intending to try to have a delay at some point?
ya i guess i dont need them, accept trying to avoid button bounce
ok so I am trying something different. I just don't get the random thing. this sort of works.
void setup() { pinMode (LEDpin, OUTPUT); pinMode (BUTTON, INPUT); randomSeed(analogRead(0));} void loop() {
//random number to generate an led buttonState = digitalRead(BUTTON); (loopwait = 0);{ if (buttonState == HIGH){ randNumber = random(3); if (randNumber == 0) { LEDpin = 3;} if (randNumber == 1) { LEDpin = 4;} if (randNumber == 2) { LEDpin = 5;} digitalWrite(LEDpin, HIGH); loopwait = 10;}
else { if (buttonState == LOW) { loopwait = 0; digitalWrite(LEDpin, LOW);
OK, let's return to the code tags later. So, the code a OK?
tophatt:
Your loopwait variable is not doing that or anything else. You’re just setting the value of a variable and doing nothing with it. You might as well have int fred = 6 in there. It means nothing.
If you want to introduce a delay, use the delay function.
int LEDpin (3);
This is more traditionally written:int LEDpin = 3;
This might set the mode for Pin 3 but it certainly won't set the mode for Pin 4 or Pin 5.  pinMode (LEDpin, OUTPUT); You should probably set the mode for all three:
  pinMode (3, OUTPUT);
  pinMode (4, OUTPUT);
  pinMode (5, OUTPUT);
Since the variable "loopwait" does nothing your LEDs will be blinking faster than you can see.
You are picking a new random pin every time buttonState is HIGH so your LED will be switching around too fast to see. You probably want to pick a new random number only when buttonState changes from LOW to HIGH.
