I am working on a project that I would like to have the LEDs fade randomly. I like using this code for using RGB LEDs but making it work for more than 3 Dies has been a problem.
// 2009 Kenneth Finnegan
// kennethfinnegan.blogspot.com
// Pins. Must be PWM pins.
#define REDLED 9
#define BLUELED 10
#define GREENLED 11
// Can't be higher than 255
#define MAXBRIGHT 200
// s[tate] t[arget] colors
byte s[3] = {0}, t[3] = {0};
// Make the random MORE RANDOM!
randomSeed(analogRead(0));
// Initialization wiring check
// You should see RED, BLUE, then GREEN.
// If you don't, then you ballsed something up.
analogWrite(REDLED, MAXBRIGHT);
analogWrite(REDLED, 0);
analogWrite(BLUELED, MAXBRIGHT);
analogWrite(BLUELED, 0);
analogWrite(GREENLED, MAXBRIGHT);
analogWrite(GREENLED, 0);
byte i, offset;
// Select the next target color
// Start from a random one of the three colors to prevent
// the cycle from being red biased.
offset = random(3);
t[offset] = random(MAXBRIGHT);
t[(offset+1)%3] = random(MAXBRIGHT - t[offset]);
t[(offset+2)%3] = MAXBRIGHT - t[offset] - t[(offset+1)%3];
// Slowly drift to the new target color 1 at a time until
// it has been reached
while(s[0]!=t[0] || s[1]!=t[1] || s[2] != t[2]) {
for (i = 0; i<3; i++) {
if (s[i] > t[i]) {
s[i] = s[i] - 1;
} else if (s[i] < t[i]) {
s[i] = s[i] + 1;
analogWrite(REDLED, s[0]);
analogWrite(BLUELED, s[1]);
analogWrite(GREENLED, s[2]);
delay(10);
// Let the viewer enjoy the new color before
// selecting the next target color.
delay(2000);
If you look at the analogue write page in the reference it says:-
On most Arduino boards (those with the ATmega168 or ATmega328), this function works on pins 3, 5, 6, 9, 10, and 11. On the Arduino Mega, it works on pins 2 through 13. Older Arduino boards with an ATmega8 only support analogWrite() on pins 9, 10, and 11.
So you would have to use pins 3, 5 & 6 for another LED. Did you use them when you tried to extend the code?
What did you end up with when you extended it?
This is what I have. Not so sure on how to modify the algorithm.
d// 2009 Kenneth Finnegan
#define LED0 11
#define LED1 10
#define LED2 9
#define LED3 6
#define LED4 5
#define LED5 3
#define MAXBRIGHT 255
// You should see each LED blink.
//LED0
analogWrite(LED0, MAXBRIGHT);
analogWrite(LED0, 0);
//LED1
analogWrite(LED1, MAXBRIGHT);
analogWrite(LED1, 0);
//LED2
analogWrite(LED2, MAXBRIGHT);
analogWrite(LED2, 0);
//LED3
analogWrite(LED3, MAXBRIGHT);
analogWrite(LED3, 0);
//LED4
analogWrite(LED4, MAXBRIGHT);
analogWrite(LED4, 0);
//LED5
analogWrite(LED5, MAXBRIGHT);
analogWrite(LED5, 0);
byte i, offset;
offset = random(3);
if (s[i] > t[i]) {
s[i] = s[i] - 1;
s[i] = s[i] + 1;
analogWrite(LED0, s[0]);
analogWrite(LED1, s[1]);
analogWrite(LED2, s[2]);
analogWrite(LED3, s[3]);
analogWrite(LED4, s[4]);
analogWrite(LED5, s[5]);
delay(10);
delay(2000);
}d
