Random function is using too much memory?
The project I am working on now takes a random number, after a button press and then uses this random number display a message on an LCD Screen. There are a total of 28 messages.
Whenever I use MessageNumber = random(28), the Global variable memory jumps from 20% to 230% being used.
The strange thing is that the MessageNumber is declared locally and is not a global variable.
I understand it is something to do with the large number of switch cases, but i am unsure of how to implement the variables correctly.
void messages()
  //in this function messages will be displayed on screen
  int MessageNumber = random(28);
  switch (MessageNumber)
    case 0:
         tft_Message(); tft.println(" 1 of 28");
          //displaymessage
       } break;
case 1:
         tft_Message(); tft.println(" 2 of 28");
          //displaymessage
       } break;
case 3:
         tft_Message(); tft.println(" 3 of 28");
          //displaymessage
       } break;
case 4:
         tft_Message(); tft.println(" 4 of 28");
          //displaymessage
       } break;
} // etc to case 27
delay(5000);
This is the part of the body of code which is causing problems.
It seems that every time the “int MessageNumber = random(NUMBER)” increases, and extraordinary amount of memory is being used for it.
Also I should say that random(seed) is being used to get the random number.
I know it is the fact that this number is being inside the switch which is why so much memory is being used, but don’t know why or have a workaround.
Help would be greatly appreciated.
Thanks.
It is probably the strings you are printing within your case statements that are consuming a lot of memory. Use the F() macro to store then in program memory instead.
e.g.
tft_Message(); tft.println(F(" 3 of 28"));
You could factor your code and save both ROM and RAM - the string " of 28" seems repeated.
blh64:
e.g.
You’re absolutely right.
Didn’y even occur to me that it just wouldn’t read through the other cases if the number was too low.
Thanks for this!
AWOL:
Will be doing this aswell, cheers fellas.
(deleted)
spycatcher2k:
tft_Message()
tft.print(" “);
tft.print(1 + MessageNumber );
tft.print(F(”  of 28"));
Factoring. K++.
