int myDelay = 0;
const int button = A0; // on off button in anolog pin 0
int ledflag=0; // LED status flag
pinMode(2,OUTPUT); // PINS 2 - 12 are output leds, each pin is connected to 1 or 2 led's
pinMode(3,OUTPUT);
pinMode(4,OUTPUT);
pinMode(5,OUTPUT);
pinMode(6,OUTPUT);
pinMode(7,OUTPUT);
pinMode(8,OUTPUT);
pinMode(9,OUTPUT);
pinMode(10,OUTPUT);
pinMode(11,OUTPUT);
pinMode(12,OUTPUT);
pinMode(13,INPUT);
digitalWrite(2,LOW) ; // all LED's are off to start
digitalWrite(3,LOW) ;
digitalWrite(4,LOW) ;
digitalWrite(5,LOW) ;
digitalWrite(6,LOW) ;
digitalWrite(7,LOW) ;
digitalWrite(8,LOW) ;
digitalWrite(9,LOW) ;
digitalWrite(10,LOW) ;
digitalWrite(11,LOW);
digitalWrite(12,LOW);
digitalWrite(13,LOW);
void loop () {
if (digitalRead(button)==HIGH){ // if button is on ( button connected to pin 13 and 12 v pin )
if (ledflag==0) { // and the status flag is LOW
ledflag=1; // make status flag HIGH
else { // otherwise...
ledflag=0; // make status flag LOW
if (ledflag =1){ // if led = 1 , button is on, if button is on run loop for random led
myDelay= analogRead(A0) // Tells arduino to read analog pin 0 and store it in the variable called myDelay ( potentiometer connection to on off switch )
int Led = random ( 2 , 13 ) ; // pick random number from 2-12, store value in variable called LED
digitalWrite(Led, HIGH) ; // turn on the random LED
delay(myDelay); // leave on for # of milliseconds set by potentiometer ( 1-10 dial )
digitalWrite(myLed,LOW); // turn off that led
delay(myDelay) ; // delay off for amout of time it was on
Oops.
Please remember to use code tags when posting code.
Please post the the error message
the second if statement has an error that says "expected unqualified-id before 'if' "
the second loop said "function definition is not allowed here before '{' token "
The random command isn't recognized, it is just plain text, rand glows orange but i cant use that because had too many variables or something
Please post the error message
The third "if" doesn't appear to be in a function.
You also have two functions called loop.
Oops
ya i figured that the third statement was probably not in a function but wasn't sure how to fix that.
I also did know that you had to name loops.
if I put the second loop line (selecting random leds) above the third if statement and re-named it would that work ?
Post code, not pictures of code.
Post error messages, not pictures of error messages.
You don't name loop functions because there can be only one loop function.
You can call a function just about anything as long as it doesn't start with a number. Best to give it a descriptive name.
void loop () {
error:
error: expected unqualified-id before 'if'
exit status 1
Never, ever do that.
ok, but what can I do about the third if statement, is there another way i should write this ? is placing inside the loop valid ? Thanks for your help
= is assignment, == is equality - getting this wrong is a common error, learn to read the first as "becomes" and the second as "equals".
Auto indent the code to make sure the braces match correctly...
It needs to be inside a function.
And '=' is an assignment, '==' is a compare; I doubt that you want to assign ![]()
well my power turned off yesterday because of a storm and now my code just says
Compilation error: Error: 2 UNKNOWN: exit status 1
I have selected arduino uno, I have also gone to preferences and selected show verbose output for compile and upload.
still stuck with this error ![]()
It probably said a bit more than that - try scrolling up.
Using board 'uno' from platform in folder: C:\Users\mF\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3
Using core 'arduino' from platform in folder: C:\Users\m\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3
Detecting libraries used...
"C:\\Users\\m\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\m\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino" "-IC:\\Users\\m\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\variants\\standard" "C:\\Users\\MDEPET~1\\AppData\\Local\\Temp\\arduino-sketch-3B79A39C8F78772B6F73D29814459DD4\\sketch\\MF_rand_p.ino.cpp" -o nul
Generating function prototypes...
"C:\\Users\\m\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\m\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino" "-IC:\\Users\\m\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\variants\\standard" "C:\\Users\\MDEPET~1\\AppData\\Local\\Temp\\arduino-sketch-3B79A39C8F78772B6F73D29814459DD4\\sketch\\MF_rand_p.ino.cpp" -o "C:\\Users\\MDEPET~1\\AppData\\Local\\Temp\\arduino-sketch-3B79A39C8F78772B6F73D29814459DD4\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Users\\m\\AppData\\Local\\Arduino15\\packages\\builtin\\tools\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\MDEPET~1\\AppData\\Local\\Temp\\arduino-sketch-3B79A39C8F78772B6F73D29814459DD4\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Users\\m\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\m\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino" "-IC:\\Users\\m\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\variants\\standard" "C:\\Users\\MDEPET~1\\AppData\\Local\\Temp\\arduino-sketch-3B79A39C8F78772B6F73D29814459DD4\\sketch\\MF_rand_p.ino.cpp" -o "C:\\Users\\MDEPET~1\\AppData\\Local\\Temp\\arduino-sketch-3B79A39C8F78772B6F73D29814459DD4\\sketch\\MF_rand_p.ino.cpp.o"
c:\Users\m\OneDrive - MCCR\Documents\Arduino\MF_rand_p\MF_rand_p.ino: In function 'void setup()':
c:\Users\m\OneDrive - MCCR\Documents\Arduino\MF_rand_p\MF_rand_p.ino:31:15: error: a function-definition is not allowed here before '{' token
void loop () {
c:\Users\m\OneDrive - MCCR\Documents\Arduino\MF_rand_p\MF_rand_p.ino:56:5: error: expected '}' at end of input
oh i see what your saying, i have these errors:
- a function-definition is not allowed here before '{' token
void loop () { - expected '}' at end of input
any idea how i can fix them ? also why is it not coming up in read like before ?
Error messages.without the code they refer to is pretty pointless.
int myDelay = 0;
int myDelay = 0;
pinMode(2,OUTPUT ); // PINS 2 - 11 are output leds, each pin is connected to 3 led's because there are 30 lights and only 14 pins
pinMode(3,OUTPUT);
pinMode(4,OUTPUT);
pinMode(5,OUTPUT);
pinMode(6,OUTPUT);
pinMode(7,OUTPUT);
pinMode(8,OUTPUT);
pinMode(9,OUTPUT);
pinMode(10,OUTPUT);
pinMode(11,OUTPUT);
pinMode(12,OUTPUT);
void loop () {
if (digitalRead(button)==HIGH){ // if button is on ( button connected to pin 12 and 12 v pin )
ledflag==1; // make status flag HIGH
digitalWrite(lights,HIGH); // and turn on the LED
digitalWrite(lights,LOW); // and turn off the LED
if (digitalRead(lights)==HIGH){ // if pin 13 is on then run led loop for random lights
myDelay= analogRead(AO) // Tells arduino to read analog pin o and store it in the variable called myDelay
int Led = rand ( 2 , 13 ) ; // pick random number from 2-12, store value in variable called LED
ya, sorry . didnt include because its pretty much the same as the original
Your setup function needs a closing brace }
thanks i just realized that my last version wasn't saved when the power went out
