Random initial serial monitor characters
When I use the millis() function to incorporate a time component to my sketch, I get these random characters that show up on the first line of the serial monitor when I initially start up the serial monitor. Why does this happen? And is there a way to fix this?
unsigned long time;
const int ldrSensor = A1;
  Serial.print("Time: ");
  time = millis();
  Serial.print(time);
  Serial.print("ms");
  Serial.print("  ");
  delay(50);
  int ldrRead = analogRead(ldrSensor);
  Serial.print("LDR = ");
  Serial.print(ldrRead);
  Serial.println("  ");
  delay(50);
Here is what I see when I start up the serial monitor. The first line shows the random characters.
LDRꢂªþTime: 0ms LDR = 406
Time: 100ms LDR = 405
Time: 200ms LDR = 405
Time: 302ms LDR = 405
Time: 402ms LDR = 404
Time: 502ms LDR = 404
Time: 604ms LDR = 405
Time: 704ms LDR = 407
i googled with your subject,
and there is some answer may help you.
http://arduino.cc/playground/Main/DisablingAutoResetOnSerialConnection
I get the garbage characters at the start all the time as well. It's a little annoying and I deal with it by starting out the sketch with Serial.println("\n").
It's probably a bug in the second uP on the Arduino board that is used for USB communication.
