Hello. I need to turn on two LEDs, red and green, in a random sequence. I am currently using the randomSeed(analogRead(0)) and randNumber = random(2) commands and it works pretty well. Now, I want to define the percentage of cases in which each LED will be on. That is, for example, 30% for the red LED and 70% for the green LED. What is the simplest way to do that?
Post you code for random and your best try for % code.
Without attempting to write the code...
Create a random number between 0 and 9.
Follow it by an if-statement.
There is a 30% chance it's less than 3.
random(2) creates 50% (1/2) so what would create 70% or 30%?
What is the task of the sketch in real life?
Yes, I know that. I probably need to create an array of 0's and 1's and somehow determine the percentage of 0 and 1. The 30 and 70% are not fixed values; there must be a possibility to change the percentage.
Some behavioral experiment in which the subject will do some task on a green light and wait on a red light.
use a switch-case with 0 - 9 and 3 of the cases will result "red" and the rest will result "green"
Okay.
At any time, change the rate of randomness. random(2) has a 50:50 rate/ratio of creating a 0 or a 1. Similar with 1/7 ot 1/3. Creating arrays or storing values stops any change. Or do you know that, too?
That!
Make it a variable!
Here's the sketch that creates a sequence of 10 numbers with 30% of 0's and 70% or 1's
int randNumberLED; //either 0 (red LED) or 1 (green LED)
int output;
int i = 1;
int j = 0;
randomSeed(analogRead(0));
Serial.println("");
while (i <= 10) {
randNumberLED = random(3);
if(randNumberLED == 0) {
j++;
if ((j/10) <= 0.3) {
output=0;
else {
output=1;
Serial.print(output);
Serial.print(" , ");
i++;
That's true. But I feel it needs improving. The 10 numbers don't have an equal probability of being 1.
EDIT: no, all 10 could be zero.
int thirtyseventy;
thirtyseventy = random(0, 9);
Serial.println(thirtyseventy);
if (thirtyseventy > 6)
Serial.println("green");
Serial.println("red");
delay(3000);
why not a simple random(101) and switch on the red if it is <= 30?
Isn't that what I just did in the previous post?
