Random negative numbers
I tried to use unsigned long random(-1,1) to get random numbers from -1 to 1, but it only picks negative numbers. Can you tell me how to fix this? thanks
The high limit is exclusive.
[quote author=Coding Badly link=msg=3836332 date=1533877734] The high limit is exclusive.
[/quote] Hi thanks for reply, I did tried increasing the positive value to other than 1.
random(-1, 2)gives me -1, 0 or 1
Is that what you want ?
The implementation in the repository(s) looks OK. Could you show us exactly how you're using it (with the nearby code)?
You can't have negative numbers in unsigned values
Silente: You can't have negative numbers in unsigned values
I was wondering the same thing. How are you only getting negative numbers in a variable that is unsigned (positive representation only)?
adwsystems: I was wondering the same thing. How are you only getting negative numbers in a variable that is unsigned (positive representation only)?
Bear in mind that we have not seen any working code
Hi thanks for replies. I’m not sure what i was doing wrong but now i can get both positive and negative values. I’m using int randomDelay = random(-1, 2);
I’m making essentially a macro where i’d like to simulate real mouse movement and for that i’d like to make it prefer 0 over -1 and 1.
For reference this is the code(There is also a joystick and a coded switch like the switch tutorial):
#include <Mouse.h>
#include <Keyboard.h>
#include <Joystick.h>
Joystick_ Joystick;
int8_t joystickType = 0x02;
float Multiplier = 1.2;
bool includeXAxis = true;
bool includeYAxis = true;
const int Analog1 = 0;
const int Analog2 = 1;
const int Analog3 = 2;
const int Analog4 = 3;
int XValue = 0;
int YValue = 0;
int inPin = 2;         // the number of the input pin
int state = LOW;      // the current state of the output pin
int reading;           // the current reading from the input pin
int previous = HIGH;    // the previous reading from the input pin
// the follow variables are long's because the time, measured in miliseconds,
// will quickly become a bigger number than can be stored in an int.
long time = 0;         // the last time the output pin was toggled
long debounce = 200;   // the debounce time, increase if the output flickers
  Joystick.begin();
  pinMode(inPin, INPUT_PULLUP);
int randomizerX = analogRead(Analog3);
  XValue = analogRead(Analog1);
  YValue = analogRead(Analog2);
  XValue = XValue * Multiplier;
  YValue = YValue * Multiplier;
  Joystick.setXAxis(XValue);
  Joystick.setYAxis(YValue);
  reading = digitalRead(inPin);
  if (reading == LOW && previous == HIGH && millis() - time > debounce) {
    if (state == LOW)
      state = HIGH;
      state = LOW;
    time = millis();
  previous = reading;
  if (state == HIGH) {
    int randomValue = random(-1, 2);
    Mouse.move(0, 2, 0);
    Mouse.move(randomValue, 0, 0);
    Serial.println(randomValue);
