Random number generation between certain numbers
Hi there. I'm fairly new to this whole programming thing so please try to explain everything as simple as possible.
For a project I need to generate a random number. This can be a psuedo random number and I know I can achieve this with the arduino random(); function, but there's a catch:
I need to generate a random sequency from 4 given numbers, specifically 5,6,9 and 10.
So I can't use random(lower boundary, upper boundary) I think.
Is there any way I can exclude 7 and 8 from my random sequence?
Thank you very much in advance
ps. apologies for the english, I'm not a native speaker
Use an array
uint8_t chosenNumbers[] = {5,6,9,10};
index it with a random number between 0 and the size of the array minus one (namely, 3).
The Arduino will generate the same random sequence after reset.
But you can use an analog input for a random seed to start with.
https://www.arduino.cc/en/Reference/RandomSeed
It doesn't matter if the analog inputs are connected to a sensor or not connected at all.
In the setup()
int total = 0;
for( int i = A0; i<=A5; i++)     // or up to A7 for many Arduino boards.
  total += analogRead(i);
randomSeed( total);
And in the loop()
int index = random(4);              // 0...3
int r = chosenNumbers[index];
Serial.println( r);
Not sure how you want to store the results, but this is one way that might help:
  randomSeed(A0);
  long rndVal;
  static int numberFound = 0;
  rndVal = random(5, 11);
  if (rndVal != 7 && rndVal != 8) {
    Serial.print(" ");
    Serial.print(rndVal);
    if (numberFound++ % 10 == 0) {    // Print a new line if 10 shown
aarg in post #1 shows the way to go
another 2 ways to do it (only usable for small set of numbers) just to see that anything is possible
  Serial.print("Start ");
  Serial.println(__FILE__);
  randomSeed(A0);
  long rndVal;
  // METHOD 1
  rndVal = random(4);
  switch (rndVal)
    case 0: rndVal = 5; break;
    case 1: rndVal = 6; break;
    case 2: rndVal = 9; break;
    default: rndVal = 10; break;
  // METHOD 2
  rndVal = random(5, 9);   // 5,6,7,8
  if (rndVal > 6) rndVal += 2;   // 5,6,9,10
Koepel:
Well, the 'randomness' would matter if that sensor had a continuous constant output... :wink:
econjack and robtillaart, what is so special about "randomSeed(14)" ?
That is what you both do with "randomSeed(A0)".
I assume it is a mistake, but I can find a few more of that on the internet as well.
You both mean "randomSeed(analogRead(A0))" ?
I don't like to be limited to just one analog pin, that's why I used every analog pin in my Reply #2.
  rndVal = random(4);
  switch (rndVal)
Why is 3 the default case?
rndVal = (random(2) ? 5 : 9) + random(2);
@Koepel: I just was in a hurry and forgot the analogRead() call. My guess is that robtillaart just did a cut-and-paste, which perpetuated my error.
Koepel:
New around these parts?
http://forum.arduino.cc/index.php?topic=66206.msg630884#msg630884
http://forum.arduino.cc/index.php?topic=66206.msg631681#msg631681
aarg:
Use an array
So
uint8_t rndm[] {5,6,9,10};
random(rndm[0-3]);
should work?
should work?
No!
There is no element at position -3 of the rndm array. So, you are calling random() with some unknown garbage.
HNDRX:
So
random(rndm[0-3]);
should work?
The correct syntax is given in reply #2 or on the reference page.
aarg:
I'm sorry but I don't understand why they are using the analog intputs (yeah, bit of a noob here), I just need a random number from the numbers 5,6,9 and 10.
PaulS:
No!
Oh sorry I meant
random(rndm[0,3]);
That better?
That better?
That won't even compile. So, no.
HNDRX:
Oh sorry I meant
random(rndm[0,3]);
That better?
You obviously haven't followed the link to the random() reference page, that I provided in reply #13. :frowning:
golly gee willikers....
  randomSeed(analogRead(A4));
  int myRandomValue = rndm[random(0,4)];
  Serial.println(myRandomValue);
aarg:
Yes I have, actually, but I still don't quite understand it I guess. When I compile
random(rndm[0,3]);
It doesn't show any errors so I can't see what I'm doing wrong. Can you please explain?
