Random pointless box coding
hey guys I and just getting into this arduino stuff and done a few simple project so far but I am struggling with some of the code as I only done visual basic befor and not C++
What I have got is the pointless box and I want to make it do random stuff each time the switch it flicked what I got so far is as follows
switchval = digitalRead(sp); // reads the value of the switch
if (val == HIGH) // to catch the switch being flicked
randomSeed(millis()) // set random seed
randNum = random(1, 10)
call random fuction depending on the randNum
void random1()
do some random servo stuff
reset servo
go back to normal code
void random2()
reset servo
blah blah blah
just don't know how to make and call the fuctions the best way. other that doing "if 1 then call random1 if 2 call .........."
I want to learn how to code properly
please can people help thanks
If/else if or switch.
If there are going to be a great deal of random functions, you can use an array of function pointers.
yes there going to be a few random functions so I would like to use an array of functions but could u give me some example code please on how to do this?
garycox:
Google "C++ function pointer array". Plenty of examples already out there.
well I have a look and I cant find or maybe understand,
I don't want to give the function any parameters I just want to run a lump of code then carry on in the void loop with no returns using an array. I not sure if its a function I need so I don't want to tell it anything
I just want to say depending on the random number run the appropriate lump of code then continue
garycox:
Try looking at some of the examples for longer than 14 minutes.
Then don't. Function pointers don't require arguments or non-void return types.
If you don't want to use functions with an array of function pointers, then you're going to have to use a switch or if/else if.
sorry you will have to excuse my newbie ness to c++ and I don't really know what I need to do, I will try to look up more functions with an array of function pointers.
Thanks for ur help so far and pointers
Try something like this:
switch (randNum)
    case 1:
      random1();   //Call random1 function when randNum = 1
    case 2:
      random2();   //Call random2 function when randNum = 2
    default:
       random10();   //Call random10 function when randNum doesn't match anything else
       // default is optional
P.S.
In this application switch/case is a better solution, but also take a look at [u]if-statements[/u]. Beginning programmers usually learn conditional execution with if-statements and if/else statements before learning switch/case, and you should understand both.
oh right ok, that's sound like I good idea, I will get this into my code and report back to see how I get on.
thanks
Function pointers example:
typedef void (* GenericFP)(void); //function pointer prototype to a function which takes no arguments and returns 'void'
GenericFP functionArray[3] = { &random1, &random2, ...}; //create an array of 'GenericFP' function pointers.
void loop(){
  boolean val = digitalRead(1);  // reads the value of the switch
  if (val == HIGH) {               // to catch the switch being flicked
     randomSeed(millis());          // set random seed
     byte randNum = random(1, 10);
     functionArray[randNum](); //call the randNum'th function.
void random1(){
void random2(){
void random ...
Hey guys cheers for the coding tips and thanks to DVDdoug I got the switch case working in my project. now I want to get the function arrays working, I just trying with the code that tom gave me just trying to see if I can get it to work before I apply it to my project. I got this little test programme.
GenericFP functionArray[2] = { &random1, &random2}; //create an array of 'GenericFP' function pointers.
void loop(){
     byte randNum = random(1, 3);
     Serial.println(randNum);
void random1(){
  Serial.println("Random sentence with ONE");
void random2(){
  Serial.println("Random sentence with TWO");
but all I get in to serial monitor is a random number then loads "&" all on one line, and it never seems to call the function. I don't know what I have done wrong can someone help pls?
Someone might want to check on their array indicies.
random(1,3) will return either 1 or 2. For the array you need 0 or 1.
Try this:
random(2); //a random number up to but excluding 2.
That has seem to have done the trick, thanks again.
Now to put it into my project. :stuck_out_tongue:
