Hi there
I was just messing around with a row of 10 LEDs connected to pins 4-13, and wrote a simple function to make a random number of LEDs flash in a random order, however only the LEDs connected on pins 4-9 behaved as expected, the other LEDs on pins 10-13 just occasionally lit up every(obviously it varies but approx) 10 seconds, then stayed on for a while, then switched back off again.
int L[] = {13, 12, 11, 10, 9, 8, 7, 6, 5, 4};
void setup(){
//pinModes
void loop(){
 Random();
void Random(){
 digitalWrite(L[random(4,14)], HIGH);
 delay(50);
 digitalWrite(L[random(4,14)], LOW);
 delay(50);
Even when I tried this exactly the same problem happened
 void Random(){
 digitalWrite(L[random(4,10)], HIGH);
 delay(50);
 digitalWrite(L[random(4,10)], LOW);
 delay(50);
 digitalWrite(L[random(10,14)], HIGH);
 delay(50);
 digitalWrite(L[random(10,14)], LOW);
 delay(50);
You're using random to get the pins you want, which in this case means you don't need L at all. If you want to use L, you reed to get a random number between 0 and 9 to address the array properly.
Speed-wise it's not too bad (there are now much faster). Quality-wise it's certainly good enough to blink LEDs (it has some weaknesses / fails a few basic tests; there are now much better).
wildbill:
You're overstepping the bounds of your L array.
This:
Could simply be this:
digitalWrite(random(4,14), HIGH);
Thanks very much, don't know why I didn't see that myself
