Random servo trigger
Hello lads, I am using this code for my Iron Man statue to light it up and also servo to open helmet when I push the button.
Is there any way to randomize opening and closing the helmet when is statue just displayed with no button interaction needed ? Like it opens and stay opened for certain time and then closed for certain time… all random with led working as I am pushing the button
(second servo on pin 10 is not used by the way)
Thanks
#include <Servo.h>
Servo myservo; // create servo object to control a servo
Servo myservo1;
const int buttonPin = 2; // the pin that the pushbutton is attached to
const int ledPin = 5; // the pin that the LED is attached to
int buttonState = 0; // current state of the button
int lastButtonState = 0; // previous state of the button
int led = 7;
int ledState = 0; // remember current led state
int pos = 0; // variable to store the servo positions
int pos1 = 180;
myservo.attach(9); // attaches the servo on pin 9 to the servo object
myservo1.attach(10); // attaches the servo 1 on pin 10 to the servo object
pinMode(buttonPin, INPUT); // initialize the button pin as a input
pinMode(ledPin, OUTPUT); // initialize the button pin as a output
pinMode(led, OUTPUT);
digitalWrite(led, HIGH);
buttonState = digitalRead(buttonPin); // read the pushbutton input pin
if (buttonState != lastButtonState) // compare buttonState to previous state
if (buttonState == 1)
if(ledState == 1)
delay(30); ledState = 0;
for(pos = 0; pos <= 45; pos += 10) // goes from 0 degrees to 180 degrees
{ // in steps of 10 degrees
myservo.write(pos); // tell servo to go to position ‘pos’
for(pos1 = 180; pos1 >= 0; pos1 -= 10) // goes from 180 degrees to 0 degrees
myservo1.write(pos1); // tell servo to go to position ‘pos1’
delay(15); // waits 15ms for the servo to reach the position
delay(30); ledState = 1;
for(pos = 45; pos >= -5; pos -= 10) // goes from 180 degrees to 0 degrees
for(pos1 = 0; pos1 <= 180; pos1 += 10) // goes from 0 degrees to 180 degrees
lastButtonState = buttonState; // remember the current state of the button
// turns LED on if the ledState =1 or off if ledState = 0
digitalWrite(ledPin, ledState);
myservo.write(pos); // goes from 0 degrees to 180 degrees
myservo1.write(pos1); // goes from 180 degrees to 0 degrees
delay(20);
OK, first things first.
You need to go and read the forum instructions so that you can go back and modify your original post (not re-post it) - using the “More → Modify” option below the right hand corner of your post - to mark up your code as such using the “</>” icon in the posting window. Just highlight each section of code (or output if you need to post that) from the IDE and click the icon.
In fact, the IDE itself has a “copy for forum” link to put these markings on a highlighted block for you so you then just paste it here in a posting window. But even before doing that, don’t forget to use the “Auto-Format” (Ctrl-T) option first to make it easy to read. If you do not post it as “code” it can easily be quite garbled and is always more difficult to read due to the font.
It is inappropriate to attach it as a “.ino” file unless it is clearly too long to include in the post proper. People can usually see the mistakes directly and do not want to have to actually load it in their own IDE. And even that would also assume they are using a PC and have the IDE running on that PC.
Also tidy up your blank space. Do use blank lines, but only single blanks between complete functional blocks.
