I’m trying to get a stepper motor to move clockwise a random number of steps between a range I’ve defined (which I can do), but then once its completed this random movement, return back to a zero state.
I thought of using a contact switch to solve the problem but I’d be really interested to learn of a coding solution. Do I need some sort of counter to work in conjunction with the random figure?
you just make the same amount of steps back to the original position?
if you just made x (which in your program is a random number between a and b) steps CW, then to get back to the original position you just have to make another x steps CCW.
Yes, keep a counter that matches the number of steps made. Update it for every move
made. If you use AccelStepper library it already keeps a counter for you,
