Random theory question
When I tell the arduino to output HIGH on a certain pin for 1 second, is the signal actually continuous? Or is it really the equivalent of a pwm signal that equals the clock cycle per second of the CPU?
In other words, did I just generate a single peak or, in the case of the Uno, 16 million peaks?
If pin 2 was an output pin, diditalWrite(2, HIGH); will place a DC 5v level on pin 2.
Are you going to show your code?
Continuous.
No code needed I think.
I’ve built a PEMF device and in my research came across this pic online. It seems like a really odd waveform, but it got me thinking that maybe the arduino could potentially be doing something similar. On a really micro level though.
Thanks for the replies.
It doesn't. It puts a solid 5V DC on the pin, as the others have said.
Perhaps extend the thinking a bit more, If the output pins really pulsed like that they would be usleless for a great many applications, and it would be well known.
To get a pwm on an output, you would have to use analogout()
analogWrite().
It’s my understanding that the cpu can only handle a set of instructions or actions once per clock cycle.
If that instruction is to open a transistor to output HIGH on a pin, it must be pulsing the transistor at its clock cycle right? Which would result in the continuous current because the transistor couldn’t switch at that rate.
The software turns on a hardware register, can we call it a flip flop.
The FF holds the state it was told to go to.
As a result once told to go to a HIGH, it stays HIGH until the FF is told to go LOW.
Similar to the light switch on the wall. Flip it up it will stay up until flipped down.
I didn't remember the syntax, thanks for correcting me.
