Random time delay for on led
Need help.
It is necessary to create a code to turn on a led by button, but after pressing the button the led should light up in the time interval (200 to 3000) 0,2 sec a 3 sec
how do I use the RANDOM function in this code?
int botao = 7;
int led = 13;
bool estadoLed = 0;
pinMode(botao, INPUT_PULLUP); // define o pino do botao como entrada "INPUT"
pinMode(led, OUTPUT);
if (digitalRead(botao) == LOW) // Se o botão for pressionado
estadoLed = !estadoLed; // troca o estado do LED
digitalWrite(led, estadoLed);
while (digitalRead(botao) == LOW);
delay(100);
    digitalWrite(LEDPin, HIGH);
    delay(random(200, 3001));
    digitalWrite(LEDPin, LOW);
I'm sorry, it still keeps giving error. could you send the complete code?
Thanks a lot for the help
Please post your sketch
When is our assignment due to be handed in ?
Sorry, I left out a ')'. Try it now.
int botao = 7;
int led = 13;
bool estadoLed = 0;
if(digitalRead(botao) == LOW) // Se o botão for pressionado
while(digitalRead(botao) == LOW);
delay(100);
const int BotaoPin = 7;
  pinMode(BotaoPin, INPUT_PULLUP); // define o pino do BotaoPin como entrada "INPUT"
  pinMode(LED_BUILTIN, OUTPUT);
  while (digitalRead(BotaoPin) == HIGH);
  digitalWrite(LED_BUILTIN, HIGH);
  digitalWrite(LED_BUILTIN, LOW);
THX :slight_smile:
Good afternoon,
Sorry again.
I tried to make the system difficult but it keeps giving an error. could you help me again?
const int Botao1 = 7;
const int Botao2 = 4;
const int Botao3 = 2;
const int led1 = 13;
const int led2 = 12;
const int led3 = 8;
pinMode(Botao1, INPUT_PULLUP); // define o pino do BotaoPin como entrada "INPUT"
pinMode(Botao2, INPUT_PULLUP);
pinMode(Botao3, INPUT_PULLUP);
pinMode(led1, OUTPUT);
pinMode(led2, OUTPUT);
pinMode(led3, OUTPUT);
while(digitalRead(Botao1) == HIGH);
delay(random(200, 3000));
digitalWrite(led1, HIGH);
delay(400);
digitalWrite(led1, LOW);
delay(4000);
//if(digitalRead(Botao2) == HIGH);
//delay(random(200, 3000));
//digitalWrite(led2, HIGH);
//delay(400);
// digitalWrite(led2, LOW);
// delay(4000);
//else(digitalRead(Botao3) == HIGH);
//digitalWrite(led3, HIGH);
// delay(400);
// digitalWrite(led3, LOW);
// delay(4000);
It compiles without error for me.
If you uncomment the new code it will wait until button1 is pressed, blink on led1, then wait until button2 is pressed. The buttons will ONLY work in order because this line means "Wait until button1 is pressed":
while (digitalRead(Botao1) == HIGH) ;
If you want to be able to press buttons in any order, use
  if (pressed)
    // do stuff
instead of
while (notPressed) ;  // Wait for press
// do stuff once the wait is over
  if (digitalRead(Botao1) == LOW)
    delay(400);
    // delay(4000);
  if (digitalRead(Botao2) == LOW)
    delay(400);
    // delay(4000);
  if (digitalRead(Botao3) == LOW)
    delay(400);
    // delay(4000);
@victor88srocha
CODE TAGS please
