hello , im using two arduino unos and two Rf24 modules to control 2 servos and one brushless motor , i have displayed values on serial monitor from transmitting arduino and they are perfect but when i display them from receiver arduino there are random small values appearing between correct values which ruins all the work
transmitter code
* Arduino Wireless Communication Tutorial
* Example 2 - Transmitter Code
* by Dejan Nedelkovski, www.HowToMechatronics.com
* Library: TMRh20/RF24, https://github.com/tmrh20/RF24/
int value = 0; // set values you need to zero
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
#define led 12
RF24 radio(7, 8); // CNS, CE
const byte addresses[][6] = {"00001", "00002"};
boolean buttonState = 0;
#define MAX_SIGNAL 2100
#define MIN_SIGNAL 700
pinMode(12, OUTPUT);
radio.begin();
radio.openWritingPipe(addresses[1]); // 00001
radio.openReadingPipe(1, addresses[0]); // 00002
radio.setPALevel(RF24_PA_MIN);
delay(5);
radio.stopListening();
int potValue = analogRead(A0);
int angleValue = map(potValue, 0, 1023, 0, 180);
radio.write(&angleValue, sizeof(angleValue));
int potValue1 = analogRead(A1);
int angleValue1 = map(potValue1, 0, 1023, 0, 180);
radio.write(&angleValue1, sizeof(angleValue1));
int potValue2 = analogRead(A2);
int angleValue2 = map(potValue2, 0, 1023, MIN_SIGNAL, MAX_SIGNAL);
radio.write(&angleValue2, sizeof(angleValue2));
if(Serial.available())
value = Serial.parseInt(); // Parse an Integer from Serial
Serial.println(angleValue);
Receiver code
* Example 2 - Receiver Code
#include <SPI.h>
#include <RF24.h>
#include <Servo.h>
#define button 4
Servo myServo;
Servo myServo1;
Servo firstESC;
pinMode(button, INPUT);
myServo.attach(5);
myServo1.attach(6);
firstESC.attach(9);
radio.begin();
radio.openWritingPipe(addresses[0]); // 00002
radio.openReadingPipe(1, addresses[1]); // 00001
delay(5);
radio.startListening();
if ( radio.available()) {
while (radio.available()) {
int angleV = 0;
int angleVTRUE = 0;
radio.read(&angleV, sizeof(angleV));
if (angleV < 180 )
angleVTRUE = angleV;
myServo.write(angleVTRUE);
int angleV1 = 0;
int angleV1TRUE = 0;
radio.read(&angleV1, sizeof(angleV1));
if (angleV1 < 180 )
angleV1TRUE = angleV1;
myServo1.write(angleV1TRUE);
int angleV2 = 0;
int angleV2TRUE = 0;
radio.read(&angleV2, sizeof(angleV2));
bitSet(angleV2, 0);
if (angleV2 < 2100 && angleV2 > 700)
angleV2TRUE = angleV2;
angleV2TRUE = constrain(angleV2TRUE,700,2100);
firstESC.writeMicroseconds(angleV2TRUE);
Serial.println(angleVTRUE);
PS: even after constrain() 0 values become 700 which is also not good
try displaying angleVTRUE and angleV1TRUE same problem
any help will be very appreciated and thank you in advance
