I have a project, in which i need to choose between 4 numbers.
I used random(2,5) because those were the values I need.
However, i need to make sure each return is different.
Ex. I can't have the same number repeat. How do I do this?
keep track of the most recent random number. Then before allowing a new random number, compare it to the variable. If it's different, do what you need to do with it. If it's the same, keep generating new ones until it's different.
Lather, rinse, repeat.
iluvplanes:
You want a shuffle algorithm. Put the four numbers into an array. Pick one at random. Remove that. Pick one of the remaining three at random. Remove that. Pick one of the remaining two at random. Then you have the last one.
Nick, Docedison, Shmaron, Thanks for the replies! I'll try Nick's out soon.
More info: Fisher–Yates shuffle - Wikipedia
Thanks!
Keep in mind that the random() function will never return the upper value of the range that you specify. If you want it to return 2, 3, 4, and 5, the upper limit needs to be 6.
thanks!
Thanks for your help everyone, I got it to work now!
Here's the code if anyone else wants to know...
// Random LED lights code...
long randNumber1;
int val = 2;
int led1 = 2;
int led2 = 3;
int led3 = 4;
int led4 = 5;
pinMode(led1, OUTPUT);
pinMode(led2, OUTPUT);
pinMode(led3, OUTPUT);
pinMode(led4, OUTPUT);
randomSeed(analogRead(1));
//make sure pins are on low.
digitalWrite(led1, LOW);
digitalWrite(led2, LOW);
digitalWrite(led3, LOW);
digitalWrite(led4, LOW);
// the loop routine runs over and over again forever:
delay(3000);
val = 1;
randNumber1 = random(2,6);
//First LED.
digitalWrite(randNumber1, HIGH);
delay(700);
val = randNumber1;
digitalWrite(randNumber1, LOW);
//Serial.println(randNumber1);
//Serial.println(val);
//Check to see if randNum is same. If so, change it.
while (randNumber1 == val) {
//write to 2nd LED
delay(700);
val = randNumber1;
//Check
//Write to 3rd LED
delay(700);
val = randNumber1;
//Check
//Write to 4th LED.
delay(700);
val = randNumber1;
Hi iluvplanes,
Just a few coding observations that can make your code easier to read and easier to understand:
You have 2 delays, 3 sec at the beginning of your loop and 1 sec at the bottom of the loop, that can be combined into a single delay.
// Comments help to explain what you are doing. I had to read through the code to determine the following:
It appears that you have a loop cycle time of 6.8 seconds when you add all of the delays. Within this time you would like to randomly flash some LEDs for 0.7 seconds.
From your code, it appears that you can flash an LED multiple times in the cycle--just not twice in a row, and that within a cycle it is ok if an LED doesn't flash at all. If not, then Nick's shuffle approach is the way to go.
That said... This was probably just supposed to be a fun activity and now that you've gotten it to work, you can move on to other things! FUN, FUN, FUN. If you're looking for something to tweak (and something to learn), maybe use potentiometers to vary the loop delay and on/off delays?
patduino:
Hi iluvplanes,Just a few coding observations that can make your code easier to read and easier to understand:
Patduino, thanks for the tips! What the code does is flash each LED once, making sure that each is flashed only once.
@iluvplanes
You can remove the while loops (and possibly endless testing) and make a function that scrambles the array.
Nice part of this solution is that double numbers are allowed (and you can call scramble as often as you want)
int numbers[] = { 0,1,2,3,4,5,6,7,8,9,10,11,12,13 };
int count = 13;
scrambleArray(numbers, count);
for (int i=0; i<count; i++)
Serial.println(numbers[i]);
Serial.println("----");
void scrambleArray(int * array, int size)
int last = 0;
int temp = array[last];
for (int i=0; i<size; i++)
int index = random(size);
array[last] = array[index];
last = index;
array[last] = temp;
Hi iluvplanes,
There seems to be a few other discussions happening here... I'll try to address your comment:
If you are happy with your code, then ignore me... But I believe your software won't do what you wanted. (1) the way you check for repeated random numbers wont guarantee that an LED wont repeat (walk through your code with the sequence: 2 3 2 3) and, (2) the whole thing is in a loop, so this will all happen more than once.
Just trying to help. I hope I'm not being too picky!
Let me give it a try:
//seed the random number generator in the setup()
randNumber1 = random(0,1<<4); //generate a 4-bit random number
digitalWrite(led1, randNumber1 & 0x01); //turn led1 on / off
digitalWrite(led2, randNumber1 & 0x02); //turn led2 on / off
digitalWrite(led3, randNumber1 & 0x04); //turn led3 on / off
digitalWrite(led4, randNumber1 & 0x08); //turn led4 on / off
delay(1000); //waste some time
A little bit tighter.
patduino:
Hi iluvplanes,If you are happy with your code, then ignore me... But I believe your software won't do what you wanted. (1) the way you check for repeated random numbers wont guarantee that an LED wont repeat (walk through your code with the sequence: 2 3 2 3) and, (2) the whole thing is in a loop, so this will all happen more than once.
Thanks, Pat, You're not being picky at all!
I see what you mean by a repeat, now... So I guess the only way to make it work would either be an array, or assign val 1-4, and then check each previous one.
About the loop, that's not much of an issue as much as getting the LEDs to flash in a random sequence.
Thanks for your help!
MT
patduino:
Which now ends. Any mention of the off-topic subject "true random" will be removed from this thread. Either help @iluvplanes or move along.
Thanks for your help, @Coding Badly. It's greatly appreciated.
dhenry:
code...
@dhenry, Thanks for your help!
patduino:
Thanks for pointing that one out, Pat.
I fixed it, so here's the edited part.
//The third LED
while (randNumber1 == val || randNumber1 == val2) {
//The fourth LED
while (randNumber1 == val || randNumber1 == val2 || randNumber1 == val3) {
Almost there!
Be sure to "remember" the previous values - see example below for val3.
//The third LED
val3 = randNumber1;
// light LED here...
//The fourth LED
