So in this I’m trying to get four lights to randomly go up or down in a lighting sequence. I’m fairly new to Arduino so when it comes to troubleshooting the issue I’m pretty lost. At this point it just turns on the first light and from that point onward nothing else happens. If someone could take a look and tell me what I’m doing wrong please let me know.
Unless your code is really huge, it seems preferred here to just stick it in the post rather than attach. As a favour to mankind I have done that here for ya. Note it’s in tags (the </> icon) to appear as code:
//randomized light sequence
int ledBot= 13;
int ledBMid= 12;
int ledTMid= 11;
int ledTop= 10;
int t= 100;
int r;
boolean stateledBot;
boolean stateledBMid;
boolean stateledTMid;
boolean stateledTop;
pinMode (ledBot,OUTPUT);
pinMode (ledBMid, OUTPUT);
pinMode (ledTMid, OUTPUT);
pinMode (ledTop, OUTPUT);
boolean stateledBot=false;
boolean stateledBMid=false;
boolean stateledTMid=false;
boolean stateledTop=false;
// start
//randomization for lights
if (stateledBot==false){
lightu1();
if (stateledBot==true and stateledBMid==false){
int r=random(1,10);
if (stateledBMid==true and stateledTMid==false){
int r=random(11,20);
if (stateledTMid==true and stateledTop==false){
int r=random(21,30);
if (stateledTop==true){
int r=random(31,40);
//programs when bot light is on
if (r==1){
lightd1();
if (r==2 or r==3){
lightdelay();
if (r>3 and r<11){
lightu2();
//programs when lower middle light is on
if (r>10 and r<14){
lightd2();
if (r==14){
lightdelay();
if (r==15){
lightdelay();
if (r>15 and r<21){
lightu3();
//programs when upper middle light is on
if (r>20 and r<25){
lightd3();
if (r==25){
lightdelay();
if (r==26){
lightdelay();
if (r>26 and r<31){
lightu4();
//programs when top light is on
if (r>30 and r<38){
lightd4();
if (r>37){
lightdelay();
//SUBROUTINES FOR THE LIGHTS
void lightu1() {
digitalWrite (ledBot, HIGH);
delay (t);
boolean stateledBot=true;
void lightu2() {
digitalWrite (ledBMid, HIGH);
delay (t);
boolean stateledBMid=true;
void lightu3() {
digitalWrite (ledTMid, HIGH);
delay (t);
boolean stateledTMid=true;
void lightu4() {
digitalWrite (ledTop, HIGH);
delay (t);
boolean stateledTop=true;
void lightd1() {
digitalWrite (ledBot, LOW);
delay (t);
void lightd2() {
digitalWrite (ledBMid, LOW);
delay (t);
void lightd3() {
digitalWrite (ledTMid, LOW);
delay (t);
void lightd4() {
digitalWrite (ledTop, LOW);
delay (t);
void lightdelay(){
delay (t);
When you put the name of a type, such as boolean or int, before an assignment, you are actually creating new variables, not referring to the ones you previously declared. These new variables only exist until the next } and are then destroyed. So if you want to update an existing variable, don’t put a type in front of it.
Another example:
int r=random(1,10);
