Hello everybody!
I'm new here, about this forum and Arduino environment.
I was trying to write a sketch that randomly fades one of the 4 LED connected to the board.
Obviously, something doesn't work properly: in fact, I cannot even see one LED actually fading.
Here's the code:
// Defining MACROs for pins.
#define PIN1 9
#define PIN2 10
#define PIN3 11
#define PIN4 13
// Procedures for fading/blinking leds. //
void blinking_light1();
void blinking_light2();
void blinking_light3();
void blinking_light4();
// Global variables. --------------------------------------------------- //
int rand_generator; // Random number for selecting random leds.
int done1 = 0; // Control variables for procedures blinded to PIN1
int done2 = 0; // Same for PIN2...
int done3 = 0; // ...and PIN3...
int done4 = 0; // ...and even PIN4!
// Setting pins in OUTPUT.
pinMode(PIN1, OUTPUT);
pinMode(PIN2, OUTPUT);
pinMode(PIN3, OUTPUT);
pinMode(PIN4, OUTPUT);
// Seed for random number.
randomSeed(analogRead(0));
// Starting Serial functionalities.
// Generating the random number selector.
rand_generator = (int) random(1, 5); // Casting to "int".
Serial.print(rand_generator);
Serial.print("\n");
// Invocating the right procedures linked to "rand_generator".
switch (rand_generator)
case 1:
if (!done1) blinking_light1();
case 2:
if (!done2) blinking_light2();
case 3:
if (!done3) blinking_light3();
case 4:
if (!done4) blinking_light4();
delay(30);
int brightness = 0; // Setting the starting brightness for pin.
int fadeAmount = 5; // Amount of incrementing brightness.
done1 = 1; // Setting the pin on "busy" mode.
for(; brightness <= 255; brightness += fadeAmount)
analogWrite(PIN1, brightness);
delay(30);
for(; brightness >= 0; brightness -= fadeAmount)
delay(30);
done1 = 0;
int brightness = 0;
int fadeAmount = 5;
done2 = 1;
analogWrite(PIN2, brightness);
delay(30);
delay(30);
done2 = 0;
int brightness = 0;
int fadeAmount = 5;
done3 = 1;
analogWrite(PIN3, brightness);
delay(30);
delay(30);
done3 = 0;
int brightness = 0;
int fadeAmount = 5;
done4 = 1;
analogWrite(PIN4, brightness);
delay(30);
delay(30);
done4 = 0;
Thanks to everyone would point me my n00bie errors
Try printing the value of brightness in your for loops. Are the values what you would expect ?
for(; brightness <= 255; brightness += fadeAmount)This form of for loop always looks ugly to me. Why not use the form where the loop variable is declared in the for loop ?
majenko:
I would suggest you simplify your code massively by:
Learn about arrays
Learn about passing parameters to functions.
You only need 1 blinking_light() function which can act on a member of an array, the index of which is passed to it at runtime.
Trust me, as graduating in CS, i know quite a bit about them... I just don't even think about this possibility.
It's my first sketch for Arduino, sorry.
Riva:
If your using an UNO for this then pin 13 is not a PWM pin and cannot be dimmed. It will just turn on/off only.
michinyon:
Your case statement is no good, if your random number is 1, it will execute all cases, you need to put a break; after each case.
I tried the classic "switch ... case" syntax on my first attempts, but the compiler returns some kind of errors related to the break (I don't really know, I'll try to correct now and re-upload the sketch).
ar3s3ru:
Huh? Did you manage to graduate in CS without learning how to write code?
