is this correct to put range in if order?
if ( t<30 && t>20)
is this code right?
Hi @hadimargo .
To loop this interval it needs to look like this:
while (t<30 &&t>20)
RV mineirin
Your if statement (there is no such thing as an if loop) says
If the value of t is less than 30 and the the value of t is greater than 20 then run the code in the following code block. It is a valid test if that is the range of values that you want to test for
Do you have a problem testing for ranges of values ?
Except that loop will never end as it is currently written
