Hello there, new person here. I was using the MFRC522 RFID Reader in a small project of mine, and I am using the tag instead of the card to trigger the reader. My question is that will the reader be able to read the tag from a distance of maximum 5cm, like the datasheet says or is an external antenna required?
Hi there. A few forums I have been to indicate that an external antenna is required to extend the range (obviously), but those distances are >10cm and more, while mine is just within the in built functioning range, so technically.... should be as you said right?
Pepega.
