Hi there.
Struggeling through this new world of code, forgive me, for maybe asking questions with seemingly obvious answers
So, a brief explanation of what I want to acheive:
I have a wheel, about 80 cm in diameter with 12 spokes. Each spoke is about 1 cm thick and they are round. It's not running very fast. Approx 8 second pr cycle. A quick calculation gave me roughly 667 ms between each spoke. I've attached a drawing off the contraption.
So I have ordered some Sharp IR sensors (GP2Y0A21YK0F) but until they arrive, I'm using my HC-SR04 ultrasonic range detector.
The led will be turned into a sync clock for synthesizers. They need about 11 ms of pulse duration, I'm told.
What I need help with, is to stabalize this. Is the Sharp IR sensor more stable? Thinking it doesn't need any ping'ing. Or is there maybe something in the code I can add/simplify?
I've added some averaging, to smooth the data coming from the sensor, but I can't average to much, because the spokes don't linger in front of the sensor.
// Example NewPing library sketch that does a ping about 20 times per second.
#include <NewPing.h>
#define TRIGGER_PIN 12 // Arduino pin tied to trigger pin on the ultrasonic sensor.
#define ECHO_PIN 11 // Arduino pin tied to echo pin on the ultrasonic sensor.
#define MAX_DISTANCE 400 // Maximum distance we want to ping for (in centimeters). Maximum sensor distance is rated at 400-500cm.
NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE); // NewPing setup of pins and maximum distance.
int distance = 0;
int detection = 0;
int detectionStatus = 0;
int lastDetection = 0;
const int ledPin = 13;
const int numReadings = 2;
int readings[numReadings];Â Â Â // the readings from the analog input
int readIndex = 0;Â Â Â Â Â Â Â // the index of the current reading
int total = 0;Â Â Â Â Â Â Â Â Â // the running total
int distAverage = 0;Â Â Â Â Â Â // the average
 pinMode(ledPin, OUTPUT);
 Serial.begin(9600); // Open serial monitor at 9600 baud to see ping results.
 for (int thisReading = 0; thisReading < numReadings; thisReading++) {
  readings[thisReading] = 0;
Â
 delay(20); // Wait 20ms between pings (about 20 pings/sec). 29ms should be the shortest delay between pings, but there is another delay in the code so this adds up to 30
 unsigned int uS = sonar.ping(); // Send ping, get ping time in microseconds (uS).
 distance = uS / US_ROUNDTRIP_CM;
 total = total - readings[readIndex];
 readings[readIndex] = distance;
 total = total + readings[readIndex];
 readIndex = readIndex + 1;
 if (readIndex >= numReadings) {
  readIndex = 0;
 distAverage = total / numReadings;
 Serial.print(distance);
 Serial.print(" avg ");
 Serial.println(distAverage);
Â
 if (distAverage < 4) {
 detection = 1;
Â
 detection = 0;
 detectionStatus = detection;
 if (detectionStatus != lastDetection) {
  if (detectionStatus == 1) {
   digitalWrite(ledPin, HIGH);
   delay (11); //pulse duration
   digitalWrite(ledPin, LOW);
  Â
lastDetection = detectionStatus;
Any help would be great
thx
