Is there a possibly to adjust a the range of potentiometer to 50 - 1023 instead of 0 - 1023 ?
Use the map() function
The problem on that is if I use map from 50 to 1023 he is at - 52 when I am 0 at the Potentiometer.
Nvm i figured it out thanks alot
Can I suggest that you post your solution
Of course, if you don't actually need the values below 50 you could just ignore them or substitute a value of zero but it depends on your application
Glad you’ve got it working… in addition to map(), take a look at constrain() for future use.
int y = analogRead(0);
y = map(y, 0, 1023, 50, 1023);
It's also possible to use linear mathematics.
As more knowledge gets buried in functions and libraries and frameworks and black boxes, it only means ppl like you will be more valuable.
a7
