I am trying to connect a Mega to my rpi to use the serial monitor to troubleshoot the code. I program it on my PC, which works fine. Unfortunately the PC is 10 feet away from where the pi and arduino are, so I can.t use it.A Uno didn't show either. I program it on the PC because the rpi is too slow.
Grumpy_Mike:
You are lacking very much on detail.
How are you connecting the two together.
What is connected to the Mega to view the serial monitor on?
The USB input on the Arduino is connected to a USB port on the pI through a powered USB Hub.
A VGA monitor is connected to the Pi through a VGA/HDMI adapter and I want to use the Serial monster provided by the Arduino program on the Pi, at least that is what I hope to do. In the meanwhile I am using Arduino on a PC not in sight and going back and forth on my wheelchaiir. What a hassle that is! I have successfully connected the Pi to the Arduino via I2C and am attempting to control hardware on the Arduino with the Pi and need to see what the Arduino is doing.
I have found that using this method the Arduino can appear at one of two com port addresses at random.
In python I cope with this as so:-
import serial
try:
ser = serial.Serial('/dev/ttyACM0',115200, timeout=2)
except :
ser = serial.Serial('/dev/ttyACM1',115200, timeout=2)
I don't understand why everyone is so fixated on what I doing. Think of it this way, i loaded the Arduino software, plugged in the Mega, and there is no listings in "Tools>Serial Port". so I cannot even download code, much less use the serial monitor to monitor what the Arduino is doing! The i2c is working fine, the blacklist is correct! I can blink the port 13 led from the pi just fine!
Sorry if I sounded irritating, I was confused by the I2C and serial monitor , dumb me
Are you plugging the Arduino directly to the USB Port in RPi, if yes then try using a powered USB hub(it may happen that the RPi cannot provide sufficient power to the Arduino through USB).
If it didn't worked try booting RPi with Arduino connected.
If that too didn't work,sorry I don't have anymore ideas. I don't have Arduino and ,I only have a Arduino on beadboard with CP2102 for USB TTL conversion and it seems RPi detects it and I am perfectly ok with using arduino with RPi.(Since RPi uses a linux distribution it must detect FTDI/atmega too , I don't know).
saravananm92:
No problem, I just saw that I needed to reduce things.
I am connected to the rpi through a powered USB 3.0/2.0 hub.
Good suggestion, but no joy, the Tools>Serial Port menu item is still grayed out
I am now connecting a 20x4 lcd via the i2c bus to use as a serial monitor. I move the arduino over to the PC for programming and downloading. Still, a lot of hassle becuase of missing serial port! Where are the gurus?
