Raspberry pi pico + Adafruit_ST7735 + rtos = freeze
Hello. I try to display some data on my TFT 1.8 in 2 different thread (in rtos). My code:
#include <Adafruit_GFX.h>
#include <Adafruit_ST7735.h>
#include <SPI.h>
#include <mbed.h>
#include <rtos.h>
#include <platform/Callback.h>
using namespace rtos;
#if !defined(ARDUINO_ARCH_RP2040)
#error For RP2040 only
#endif
#if defined(ARDUINO_ARCH_MBED)
#define PIN_SD_MOSI       PIN_SPI_MOSI
#define PIN_SD_MISO       PIN_SPI_MISO
#define PIN_SD_SCK        PIN_SPI_SCK
#define PIN_SD_SS         PIN_SPI_SS
#else
#define PIN_SD_MOSI       PIN_SPI0_MOSI
#define PIN_SD_MISO       PIN_SPI0_MISO
#define PIN_SD_SCK        PIN_SPI0_SCK
#define PIN_SD_SS         PIN_SPI0_SS
#endif
#define _RP2040_SD_LOGLEVEL_       0
#include <RP2040_SD.h>
#define ST7735_DRIVER
#define TFT_INVERSION_ON
#define TFT_CS 18
#define TFT_RST 22
#define TFT_DC 19
#define TFT_SCLK 21
#define TFT_MOSI 20
Adafruit_ST7735 tft = Adafruit_ST7735(TFT_CS, TFT_DC, TFT_MOSI, TFT_SCLK, TFT_RST);
Semaphore s1(1);
Semaphore s2(0);
Thread t2;
#define BUFFPIXEL 20
uint16_t read16(File f) {
  uint16_t result;
  ((uint8_t *)&result)[0] = f.read(); // LSB
  ((uint8_t *)&result)[1] = f.read(); // MSB
  return result;
uint32_t read32(File f) {
  uint32_t result;
  ((uint8_t *)&result)[2] = f.read();
  ((uint8_t *)&result)[3] = f.read(); // MSB
  return result;
void bmpDraw(char *filename, uint8_t x, uint16_t y) {
  File     bmpFile;
  int      bmpWidth, bmpHeight;   // W+H in pixels
  uint8_t  bmpDepth;              // Bit depth (currently must be 24)
  uint32_t bmpImageoffset;        // Start of image data in file
  uint32_t rowSize;               // Not always = bmpWidth; may have padding
  uint8_t  sdbuffer[3*BUFFPIXEL]; // pixel buffer (R+G+B per pixel)
  uint8_t  buffidx = sizeof(sdbuffer); // Current position in sdbuffer
  boolean  goodBmp = false;       // Set to true on valid header parse
  boolean  flip    = true;        // BMP is stored bottom-to-top
  int      w, h, row, col;
  uint8_t  r, g, b;
  uint32_t pos = 0, startTime = millis();
  if((x >= tft.width()) || (y >= tft.height())) return;
  Serial.print(F("Loading image '"));
  Serial.print(filename);
  Serial.println("'");
  // Open requested file on SD card
  if ((bmpFile = SD.open(filename)) == NULL) {
    Serial.print(F("File "));
    Serial.println(F(" not found"));
    return;
  // Parse BMP header
  if(read16(bmpFile) == 0x4D42) { // BMP signature
    Serial.print(F("File size: ")); Serial.println(read32(bmpFile));
    (void)read32(bmpFile); // Read & ignore creator bytes
    bmpImageoffset = read32(bmpFile); // Start of image data
    Serial.print(F("Image Offset: ")); Serial.println(bmpImageoffset, DEC);
    // Read DIB header
    Serial.print(F("Header size: ")); Serial.println(read32(bmpFile));
    bmpWidth  = read32(bmpFile);
    bmpHeight = read32(bmpFile);
    if(read16(bmpFile) == 1) { // # planes -- must be '1'
      bmpDepth = read16(bmpFile); // bits per pixel
      Serial.print(F("Bit Depth: ")); Serial.println(bmpDepth);
      if((bmpDepth == 24) && (read32(bmpFile) == 0)) { // 0 = uncompressed
        goodBmp = true; // Supported BMP format -- proceed!
        Serial.print(F("Image size: "));
        Serial.print(bmpWidth);
        Serial.print('x');
        Serial.println(bmpHeight);
        // BMP rows are padded (if needed) to 4-byte boundary
        rowSize = (bmpWidth * 3 + 3) & ~3;
        // If bmpHeight is negative, image is in top-down order.
        // This is not canon but has been observed in the wild.
        if(bmpHeight < 0) {
          bmpHeight = -bmpHeight;
          flip      = false;
        // Crop area to be loaded
        w = bmpWidth;
        h = bmpHeight;
        if((x+w-1) >= tft.width())  w = tft.width()  - x;
        if((y+h-1) >= tft.height()) h = tft.height() - y;
		tft.startWrite();
        tft.setAddrWindow(x, y, w, h);
        tft.endWrite();
        for (row=0; row<h; row++) { // For each scanline...
          // Seek to start of scan line.  It might seem labor-
          // intensive to be doing this on every line, but this
          // method covers a lot of gritty details like cropping
          // and scanline padding.  Also, the seek only takes
          // place if the file position actually needs to change
          // (avoids a lot of cluster math in SD library).
          if(flip) // Bitmap is stored bottom-to-top order (normal BMP)
            pos = bmpImageoffset + (bmpHeight - 1 - row) * rowSize;
          else     // Bitmap is stored top-to-bottom
            pos = bmpImageoffset + row * rowSize;
          if(bmpFile.position() != pos) { // Need seek?
            bmpFile.seek(pos);
            buffidx = sizeof(sdbuffer); // Force buffer reload
          for (col=0; col<w; col++) { // For each pixel...
            // Time to read more pixel data?
            if (buffidx >= sizeof(sdbuffer)) { // Indeed
              bmpFile.read(sdbuffer, sizeof(sdbuffer));
              buffidx = 0; // Set index to beginning
            // Convert pixel from BMP to TFT format, push to display
            b = sdbuffer[buffidx++];
            g = sdbuffer[buffidx++];
            r = sdbuffer[buffidx++];
            tft.pushColor(tft.color565(r,g,b));
          } // end pixel
        } // end scanline
		tft.endWrite();
	    Serial.print(F("Loaded in "));
        Serial.print(millis() - startTime);
        Serial.println(" ms");
  bmpFile.close();
  if(!goodBmp) Serial.println(F("BMP format not recognized."));
void runCore1 ()
  s1.acquire();
	while (true) {
 bmpDraw("img/TEST.bmp", 0, 10);
 s2.release();
	  tft.initR(INITR_BLACKTAB);
  Serial.println(F("Initialized"));
  tft.fillScreen(ST77XX_BLACK);
  tft.setRotation(3);
   t2.start(mbed::callback(runCore1)); //all display ok
		delay(3000);
		tft.setFont(&TIMES8pt8b);
  tft.setTextColor(ST7735_WHITE);
/* After this all is freeze, pico start blink green LED*/
  tft.setCursor(40, 15);
  tft.println(utf8cyr("Print TEST"));
  bmpDraw("img/TEST2.bmp", 40, 20);
Any one can help how to fix it? Thanks
