Raspberry pi pico in arduino.ide not compiling
Hi to all. I need help. I'm trying to program a raspberry pi pico into an arduino.ide, but I'm getting errors. I have installed all the libraries and configured everything but the sketches are not compiling. The only sketch that was compiled is blink.
loading library from c:\Users\admin\Documents\Arduino\libraries\DHT-sensor-library: invalid library: no header files foundloading library from c:\Users\admin\Documents\Arduino\libraries\Ds1302-master: invalid library: no header files foundloading library from c:\Users\admin\Documents\Arduino\libraries\LCD5110_Graph: invalid library: no header files foundloading library from c:\Users\admin\Documents\Arduino\libraries\TryTech_RTC_Clock: invalid library: no header files foundloading library from c:\Users\admin\Documents\Arduino\libraries\arduino-ds1302-master: invalid library: no header files found
FQBN: rp2040:rp2040:rpipico
Using board 'rpipico' from platform in folder: C:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2
Using core 'rp2040' from platform in folder: C:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2
Detecting libraries used...
C:\Users\admin\AppData\Local\Arduino15\packages\rp2040\tools\pqt-gcc\2.2.0-d04e724/bin/arm-none-eabi-g++ -I C:\Users\admin\AppData\Local\Temp\arduino\sketches\9217A23F579D783B44CCF3B247E76EA5/core -c -Werror=return-type -Wno-psabi -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSBD_PID=0x000a -DUSBD_VID=0x2e8a -DUSBD_MAX_POWER_MA=250 -DUSB_MANUFACTURER="Raspberry Pi" -DUSB_PRODUCT="Pico" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=1 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 -DARDUINO_VARIANT="rpipico" -DTARGET_RP2040 -DPICO_FLASH_SIZE_BYTES=2097152 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -iprefixC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2/ @C:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2/lib/platform_inc.txt -IC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2/include -fno-rtti -std=gnu++17 -g -pipe -w -x c++ -E -CC -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO -DBOARD_NAME="RASPBERRY_PI_PICO" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE -IC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2\cores\rp2040 -IC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2\variants\rpipico C:\Users\admin\AppData\Local\Temp\arduino\sketches\9217A23F579D783B44CCF3B247E76EA5\sketch\temp_disp_rtc.ino.cpp -o nul
Alternatives for DallasTemperature.h: [DallasTemperature@3.9.0]
ResolveLibrary(DallasTemperature.h)
-> candidates: [DallasTemperature@3.9.0]
C:\Users\admin\AppData\Local\Arduino15\packages\rp2040\tools\pqt-gcc\2.2.0-d04e724/bin/arm-none-eabi-g++ -I C:\Users\admin\AppData\Local\Temp\arduino\sketches\9217A23F579D783B44CCF3B247E76EA5/core -c -Werror=return-type -Wno-psabi -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSBD_PID=0x000a -DUSBD_VID=0x2e8a -DUSBD_MAX_POWER_MA=250 -DUSB_MANUFACTURER="Raspberry Pi" -DUSB_PRODUCT="Pico" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=1 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 -DARDUINO_VARIANT="rpipico" -DTARGET_RP2040 -DPICO_FLASH_SIZE_BYTES=2097152 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -iprefixC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2/ @C:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2/lib/platform_inc.txt -IC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2/include -fno-rtti -std=gnu++17 -g -pipe -w -x c++ -E -CC -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO -DBOARD_NAME="RASPBERRY_PI_PICO" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE -IC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2\cores\rp2040 -IC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2\variants\rpipico -Ic:\Users\admin\Documents\Arduino\libraries\DallasTemperature C:\Users\admin\AppData\Local\Temp\arduino\sketches\9217A23F579D783B44CCF3B247E76EA5\sketch\temp_disp_rtc.ino.cpp -o nul
Alternatives for OneWire.h: [OneWire@2.3.7]
ResolveLibrary(OneWire.h)
-> candidates: [OneWire@2.3.7]
C:\Users\admin\AppData\Local\Arduino15\packages\rp2040\tools\pqt-gcc\2.2.0-d04e724/bin/arm-none-eabi-g++ -I C:\Users\admin\AppData\Local\Temp\arduino\sketches\9217A23F579D783B44CCF3B247E76EA5/core -c -Werror=return-type -Wno-psabi -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSBD_PID=0x000a -DUSBD_VID=0x2e8a -DUSBD_MAX_POWER_MA=250 -DUSB_MANUFACTURER="Raspberry Pi" -DUSB_PRODUCT="Pico" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=1 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 -DARDUINO_VARIANT="rpipico" -DTARGET_RP2040 -DPICO_FLASH_SIZE_BYTES=2097152 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -iprefixC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2/ @C:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2/lib/platform_inc.txt -IC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2/include -fno-rtti -std=gnu++17 -g -pipe -w -x c++ -E -CC -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO -DBOARD_NAME="RASPBERRY_PI_PICO" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE -IC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2\cores\rp2040 -IC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2\variants\rpipico -Ic:\Users\admin\Documents\Arduino\libraries\DallasTemperature -Ic:\Users\admin\Documents\Arduino\libraries\OneWire C:\Users\admin\AppData\Local\Temp\arduino\sketches\9217A23F579D783B44CCF3B247E76EA5\sketch\temp_disp_rtc.ino.cpp -o nul
Alternatives for Wire.h: [Wire@1.0]
ResolveLibrary(Wire.h)
-> candidates: [Wire@1.0]
C:\Users\admin\AppData\Local\Arduino15\packages\rp2040\tools\pqt-gcc\2.2.0-d04e724/bin/arm-none-eabi-g++ -I C:\Users\admin\AppData\Local\Temp\arduino\sketches\9217A23F579D783B44CCF3B247E76EA5/core -c -Werror=return-type -Wno-psabi -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSBD_PID=0x000a -DUSBD_VID=0x2e8a -DUSBD_MAX_POWER_MA=250 -DUSB_MANUFACTURER="Raspberry Pi" -DUSB_PRODUCT="Pico" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=1 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 -DARDUINO_VARIANT="rpipico" -DTARGET_RP2040 -DPICO_FLASH_SIZE_BYTES=2097152 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -iprefixC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2/ @C:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2/lib/platform_inc.txt -IC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2/include -fno-rtti -std=gnu++17 -g -pipe -w -x c++ -E -CC -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO -DBOARD_NAME="RASPBERRY_PI_PICO" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE -IC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2\cores\rp2040 -IC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2\variants\rpipico -Ic:\Users\admin\Documents\Arduino\libraries\DallasTemperature -Ic:\Users\admin\Documents\Arduino\libraries\OneWire -IC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2\libraries\Wire\src C:\Users\admin\AppData\Local\Temp\arduino\sketches\9217A23F579D783B44CCF3B247E76EA5\sketch\temp_disp_rtc.ino.cpp -o nul
Alternatives for LiquidCrystal_I2C.h: [Newliquidcrystal_1.3.5 LiquidCrystal I2C@1.1.2 LiquidCrystal_I2C@1.1.4]
ResolveLibrary(LiquidCrystal_I2C.h)
-> candidates: [Newliquidcrystal_1.3.5 LiquidCrystal I2C@1.1.2 LiquidCrystal_I2C@1.1.4]
C:\Users\admin\AppData\Local\Arduino15\packages\rp2040\tools\pqt-gcc\2.2.0-d04e724/bin/arm-none-eabi-g++ -I C:\Users\admin\AppData\Local\Temp\arduino\sketches\9217A23F579D783B44CCF3B247E76EA5/core -c -Werror=return-type -Wno-psabi -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSBD_PID=0x000a -DUSBD_VID=0x2e8a -DUSBD_MAX_POWER_MA=250 -DUSB_MANUFACTURER="Raspberry Pi" -DUSB_PRODUCT="Pico" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=1 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 -DARDUINO_VARIANT="rpipico" -DTARGET_RP2040 -DPICO_FLASH_SIZE_BYTES=2097152 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -iprefixC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2/ @C:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2/lib/platform_inc.txt -IC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2/include -fno-rtti -std=gnu++17 -g -pipe -w -x c++ -E -CC -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO -DBOARD_NAME="RASPBERRY_PI_PICO" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE -IC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2\cores\rp2040 -IC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2\variants\rpipico -Ic:\Users\admin\Documents\Arduino\libraries\DallasTemperature -Ic:\Users\admin\Documents\Arduino\libraries\OneWire -IC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2\libraries\Wire\src -Ic:\Users\admin\Documents\Arduino\libraries\Newliquidcrystal_1.3.5 C:\Users\admin\AppData\Local\Temp\arduino\sketches\9217A23F579D783B44CCF3B247E76EA5\sketch\temp_disp_rtc.ino.cpp -o nul
Alternatives for virtuabotixRTC.h: [ArduinoRTClibrary-master]
ResolveLibrary(virtuabotixRTC.h)
-> candidates: [ArduinoRTClibrary-master]
C:\Users\admin\AppData\Local\Arduino15\packages\rp2040\tools\pqt-gcc\2.2.0-d04e724/bin/arm-none-eabi-g++ -I C:\Users\admin\AppData\Local\Temp\arduino\sketches\9217A23F579D783B44CCF3B247E76EA5/core -c -Werror=return-type -Wno-psabi -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSBD_PID=0x000a -DUSBD_VID=0x2e8a -DUSBD_MAX_POWER_MA=250 -DUSB_MANUFACTURER="Raspberry Pi" -DUSB_PRODUCT="Pico" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=1 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 -DARDUINO_VARIANT="rpipico" -DTARGET_RP2040 -DPICO_FLASH_SIZE_BYTES=2097152 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -iprefixC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2/ @C:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2/lib/platform_inc.txt -IC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2/include -fno-rtti -std=gnu++17 -g -pipe -w -x c++ -E -CC -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO -DBOARD_NAME="RASPBERRY_PI_PICO" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE -IC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2\cores\rp2040 -IC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2\variants\rpipico -Ic:\Users\admin\Documents\Arduino\libraries\DallasTemperature -Ic:\Users\admin\Documents\Arduino\libraries\OneWire -IC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2\libraries\Wire\src -Ic:\Users\admin\Documents\Arduino\libraries\Newliquidcrystal_1.3.5 -Ic:\Users\admin\Documents\Arduino\libraries\ArduinoRTClibrary-master C:\Users\admin\AppData\Local\Temp\arduino\sketches\9217A23F579D783B44CCF3B247E76EA5\sketch\temp_disp_rtc.ino.cpp -o nul
C:\Users\admin\AppData\Local\Arduino15\packages\rp2040\tools\pqt-gcc\2.2.0-d04e724/bin/arm-none-eabi-g++ -I C:\Users\admin\AppData\Local\Temp\arduino\sketches\9217A23F579D783B44CCF3B247E76EA5/core -c -Werror=return-type -Wno-psabi -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSBD_PID=0x000a -DUSBD_VID=0x2e8a -DUSBD_MAX_POWER_MA=250 -DUSB_MANUFACTURER="Raspberry Pi" -DUSB_PRODUCT="Pico" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=1 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 -DARDUINO_VARIANT="rpipico" -DTARGET_RP2040 -DPICO_FLASH_SIZE_BYTES=2097152 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -iprefixC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2/ @C:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2/lib/platform_inc.txt -IC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2/include -fno-rtti -std=gnu++17 -g -pipe -w -x c++ -E -CC -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO -DBOARD_NAME="RASPBERRY_PI_PICO" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE -IC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2\cores\rp2040 -IC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2\variants\rpipico -Ic:\Users\admin\Documents\Arduino\libraries\DallasTemperature -Ic:\Users\admin\Documents\Arduino\libraries\OneWire -IC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2\libraries\Wire\src -Ic:\Users\admin\Documents\Arduino\libraries\Newliquidcrystal_1.3.5 -Ic:\Users\admin\Documents\Arduino\libraries\ArduinoRTClibrary-master c:\Users\admin\Documents\Arduino\libraries\DallasTemperature\DallasTemperature.cpp -o nul
C:\Users\admin\AppData\Local\Arduino15\packages\rp2040\tools\pqt-gcc\2.2.0-d04e724/bin/arm-none-eabi-g++ -I C:\Users\admin\AppData\Local\Temp\arduino\sketches\9217A23F579D783B44CCF3B247E76EA5/core -c -Werror=return-type -Wno-psabi -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSBD_PID=0x000a -DUSBD_VID=0x2e8a -DUSBD_MAX_POWER_MA=250 -DUSB_MANUFACTURER="Raspberry Pi" -DUSB_PRODUCT="Pico" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=1 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 -DARDUINO_VARIANT="rpipico" -DTARGET_RP2040 -DPICO_FLASH_SIZE_BYTES=2097152 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -iprefixC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2/ @C:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2/lib/platform_inc.txt -IC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2/include -fno-rtti -std=gnu++17 -g -pipe -w -x c++ -E -CC -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO -DBOARD_NAME="RASPBERRY_PI_PICO" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE -IC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2\cores\rp2040 -IC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2\variants\rpipico -Ic:\Users\admin\Documents\Arduino\libraries\DallasTemperature -Ic:\Users\admin\Documents\Arduino\libraries\OneWire -IC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2\libraries\Wire\src -Ic:\Users\admin\Documents\Arduino\libraries\Newliquidcrystal_1.3.5 -Ic:\Users\admin\Documents\Arduino\libraries\ArduinoRTClibrary-master c:\Users\admin\Documents\Arduino\libraries\OneWire\OneWire.cpp -o nul
C:\Users\admin\AppData\Local\Arduino15\packages\rp2040\tools\pqt-gcc\2.2.0-d04e724/bin/arm-none-eabi-g++ -I C:\Users\admin\AppData\Local\Temp\arduino\sketches\9217A23F579D783B44CCF3B247E76EA5/core -c -Werror=return-type -Wno-psabi -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSBD_PID=0x000a -DUSBD_VID=0x2e8a -DUSBD_MAX_POWER_MA=250 -DUSB_MANUFACTURER="Raspberry Pi" -DUSB_PRODUCT="Pico" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=1 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 -DARDUINO_VARIANT="rpipico" -DTARGET_RP2040 -DPICO_FLASH_SIZE_BYTES=2097152 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -iprefixC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2/ @C:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2/lib/platform_inc.txt -IC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2/include -fno-rtti -std=gnu++17 -g -pipe -w -x c++ -E -CC -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO -DBOARD_NAME="RASPBERRY_PI_PICO" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE -IC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2\cores\rp2040 -IC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2\variants\rpipico -Ic:\Users\admin\Documents\Arduino\libraries\DallasTemperature -Ic:\Users\admin\Documents\Arduino\libraries\OneWire -IC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2\libraries\Wire\src -Ic:\Users\admin\Documents\Arduino\libraries\Newliquidcrystal_1.3.5 -Ic:\Users\admin\Documents\Arduino\libraries\ArduinoRTClibrary-master C:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2\libraries\Wire\src\Wire.cpp -o nul
C:\Users\admin\AppData\Local\Arduino15\packages\rp2040\tools\pqt-gcc\2.2.0-d04e724/bin/arm-none-eabi-g++ -I C:\Users\admin\AppData\Local\Temp\arduino\sketches\9217A23F579D783B44CCF3B247E76EA5/core -c -Werror=return-type -Wno-psabi -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSBD_PID=0x000a -DUSBD_VID=0x2e8a -DUSBD_MAX_POWER_MA=250 -DUSB_MANUFACTURER="Raspberry Pi" -DUSB_PRODUCT="Pico" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=1 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 -DARDUINO_VARIANT="rpipico" -DTARGET_RP2040 -DPICO_FLASH_SIZE_BYTES=2097152 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -iprefixC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2/ @C:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2/lib/platform_inc.txt -IC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2/include -fno-rtti -std=gnu++17 -g -pipe -w -x c++ -E -CC -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO -DBOARD_NAME="RASPBERRY_PI_PICO" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE -IC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2\cores\rp2040 -IC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2\variants\rpipico -Ic:\Users\admin\Documents\Arduino\libraries\DallasTemperature -Ic:\Users\admin\Documents\Arduino\libraries\OneWire -IC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2\libraries\Wire\src -Ic:\Users\admin\Documents\Arduino\libraries\Newliquidcrystal_1.3.5 -Ic:\Users\admin\Documents\Arduino\libraries\ArduinoRTClibrary-master -IC:\Users\admin\Documents\Arduino\libraries\Newliquidcrystal_1.3.5\utility c:\Users\admin\Documents\Arduino\libraries\Newliquidcrystal_1.3.5\FastIO.cpp -o nul
C:\Users\admin\AppData\Local\Arduino15\packages\rp2040\tools\pqt-gcc\2.2.0-d04e724/bin/arm-none-eabi-g++ -I C:\Users\admin\AppData\Local\Temp\arduino\sketches\9217A23F579D783B44CCF3B247E76EA5/core -c -Werror=return-type -Wno-psabi -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSBD_PID=0x000a -DUSBD_VID=0x2e8a -DUSBD_MAX_POWER_MA=250 -DUSB_MANUFACTURER="Raspberry Pi" -DUSB_PRODUCT="Pico" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=1 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 -DARDUINO_VARIANT="rpipico" -DTARGET_RP2040 -DPICO_FLASH_SIZE_BYTES=2097152 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -iprefixC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2/ @C:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2/lib/platform_inc.txt -IC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2/include -fno-rtti -std=gnu++17 -g -pipe -w -x c++ -E -CC -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO -DBOARD_NAME="RASPBERRY_PI_PICO" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE -IC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2\cores\rp2040 -IC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2\variants\rpipico -Ic:\Users\admin\Documents\Arduino\libraries\DallasTemperature -Ic:\Users\admin\Documents\Arduino\libraries\OneWire -IC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2\libraries\Wire\src -Ic:\Users\admin\Documents\Arduino\libraries\Newliquidcrystal_1.3.5 -Ic:\Users\admin\Documents\Arduino\libraries\ArduinoRTClibrary-master -IC:\Users\admin\Documents\Arduino\libraries\Newliquidcrystal_1.3.5\utility c:\Users\admin\Documents\Arduino\libraries\Newliquidcrystal_1.3.5\I2CIO.cpp -o nul
C:\Users\admin\AppData\Local\Arduino15\packages\rp2040\tools\pqt-gcc\2.2.0-d04e724/bin/arm-none-eabi-g++ -I C:\Users\admin\AppData\Local\Temp\arduino\sketches\9217A23F579D783B44CCF3B247E76EA5/core -c -Werror=return-type -Wno-psabi -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSBD_PID=0x000a -DUSBD_VID=0x2e8a -DUSBD_MAX_POWER_MA=250 -DUSB_MANUFACTURER="Raspberry Pi" -DUSB_PRODUCT="Pico" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=1 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 -DARDUINO_VARIANT="rpipico" -DTARGET_RP2040 -DPICO_FLASH_SIZE_BYTES=2097152 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -iprefixC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2/ @C:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2/lib/platform_inc.txt -IC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2/include -fno-rtti -std=gnu++17 -g -pipe -w -x c++ -E -CC -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO -DBOARD_NAME="RASPBERRY_PI_PICO" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE -IC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2\cores\rp2040 -IC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2\variants\rpipico -Ic:\Users\admin\Documents\Arduino\libraries\DallasTemperature -Ic:\Users\admin\Documents\Arduino\libraries\OneWire -IC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2\libraries\Wire\src -Ic:\Users\admin\Documents\Arduino\libraries\Newliquidcrystal_1.3.5 -Ic:\Users\admin\Documents\Arduino\libraries\ArduinoRTClibrary-master -IC:\Users\admin\Documents\Arduino\libraries\Newliquidcrystal_1.3.5\utility c:\Users\admin\Documents\Arduino\libraries\Newliquidcrystal_1.3.5\LCD.cpp -o nul
C:\Users\admin\AppData\Local\Arduino15\packages\rp2040\tools\pqt-gcc\2.2.0-d04e724/bin/arm-none-eabi-g++ -I C:\Users\admin\AppData\Local\Temp\arduino\sketches\9217A23F579D783B44CCF3B247E76EA5/core -c -Werror=return-type -Wno-psabi -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSBD_PID=0x000a -DUSBD_VID=0x2e8a -DUSBD_MAX_POWER_MA=250 -DUSB_MANUFACTURER="Raspberry Pi" -DUSB_PRODUCT="Pico" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=1 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 -DARDUINO_VARIANT="rpipico" -DTARGET_RP2040 -DPICO_FLASH_SIZE_BYTES=2097152 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -iprefixC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2/ @C:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2/lib/platform_inc.txt -IC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2/include -fno-rtti -std=gnu++17 -g -pipe -w -x c++ -E -CC -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO -DBOARD_NAME="RASPBERRY_PI_PICO" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE -IC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2\cores\rp2040 -IC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2\variants\rpipico -Ic:\Users\admin\Documents\Arduino\libraries\DallasTemperature -Ic:\Users\admin\Documents\Arduino\libraries\OneWire -IC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2\libraries\Wire\src -Ic:\Users\admin\Documents\Arduino\libraries\Newliquidcrystal_1.3.5 -Ic:\Users\admin\Documents\Arduino\libraries\ArduinoRTClibrary-master -IC:\Users\admin\Documents\Arduino\libraries\Newliquidcrystal_1.3.5\utility c:\Users\admin\Documents\Arduino\libraries\Newliquidcrystal_1.3.5\LiquidCrystal.cpp -o nul
C:\Users\admin\AppData\Local\Arduino15\packages\rp2040\tools\pqt-gcc\2.2.0-d04e724/bin/arm-none-eabi-g++ -I C:\Users\admin\AppData\Local\Temp\arduino\sketches\9217A23F579D783B44CCF3B247E76EA5/core -c -Werror=return-type -Wno-psabi -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSBD_PID=0x000a -DUSBD_VID=0x2e8a -DUSBD_MAX_POWER_MA=250 -DUSB_MANUFACTURER="Raspberry Pi" -DUSB_PRODUCT="Pico" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=1 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 -DARDUINO_VARIANT="rpipico" -DTARGET_RP2040 -DPICO_FLASH_SIZE_BYTES=2097152 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -iprefixC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2/ @C:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2/lib/platform_inc.txt -IC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2/include -fno-rtti -std=gnu++17 -g -pipe -w -x c++ -E -CC -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO -DBOARD_NAME="RASPBERRY_PI_PICO" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE -IC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2\cores\rp2040 -IC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2\variants\rpipico -Ic:\Users\admin\Documents\Arduino\libraries\DallasTemperature -Ic:\Users\admin\Documents\Arduino\libraries\OneWire -IC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2\libraries\Wire\src -Ic:\Users\admin\Documents\Arduino\libraries\Newliquidcrystal_1.3.5 -Ic:\Users\admin\Documents\Arduino\libraries\ArduinoRTClibrary-master -IC:\Users\admin\Documents\Arduino\libraries\Newliquidcrystal_1.3.5\utility c:\Users\admin\Documents\Arduino\libraries\Newliquidcrystal_1.3.5\LiquidCrystal_I2C.cpp -o nul
C:\Users\admin\AppData\Local\Arduino15\packages\rp2040\tools\pqt-gcc\2.2.0-d04e724/bin/arm-none-eabi-g++ -I C:\Users\admin\AppData\Local\Temp\arduino\sketches\9217A23F579D783B44CCF3B247E76EA5/core -c -Werror=return-type -Wno-psabi -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSBD_PID=0x000a -DUSBD_VID=0x2e8a -DUSBD_MAX_POWER_MA=250 -DUSB_MANUFACTURER="Raspberry Pi" -DUSB_PRODUCT="Pico" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=1 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 -DARDUINO_VARIANT="rpipico" -DTARGET_RP2040 -DPICO_FLASH_SIZE_BYTES=2097152 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -iprefixC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2/ @C:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2/lib/platform_inc.txt -IC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2/include -fno-rtti -std=gnu++17 -g -pipe -w -x c++ -E -CC -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO -DBOARD_NAME="RASPBERRY_PI_PICO" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE -IC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2\cores\rp2040 -IC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2\variants\rpipico -Ic:\Users\admin\Documents\Arduino\libraries\DallasTemperature -Ic:\Users\admin\Documents\Arduino\libraries\OneWire -IC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2\libraries\Wire\src -Ic:\Users\admin\Documents\Arduino\libraries\Newliquidcrystal_1.3.5 -Ic:\Users\admin\Documents\Arduino\libraries\ArduinoRTClibrary-master -IC:\Users\admin\Documents\Arduino\libraries\Newliquidcrystal_1.3.5\utility c:\Users\admin\Documents\Arduino\libraries\Newliquidcrystal_1.3.5\LiquidCrystal_I2C_ByVac.cpp -o nul
C:\Users\admin\AppData\Local\Arduino15\packages\rp2040\tools\pqt-gcc\2.2.0-d04e724/bin/arm-none-eabi-g++ -I C:\Users\admin\AppData\Local\Temp\arduino\sketches\9217A23F579D783B44CCF3B247E76EA5/core -c -Werror=return-type -Wno-psabi -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSBD_PID=0x000a -DUSBD_VID=0x2e8a -DUSBD_MAX_POWER_MA=250 -DUSB_MANUFACTURER="Raspberry Pi" -DUSB_PRODUCT="Pico" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=1 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 -DARDUINO_VARIANT="rpipico" -DTARGET_RP2040 -DPICO_FLASH_SIZE_BYTES=2097152 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -iprefixC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2/ @C:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2/lib/platform_inc.txt -IC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2/include -fno-rtti -std=gnu++17 -g -pipe -w -x c++ -E -CC -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO -DBOARD_NAME="RASPBERRY_PI_PICO" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE -IC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2\cores\rp2040 -IC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2\variants\rpipico -Ic:\Users\admin\Documents\Arduino\libraries\DallasTemperature -Ic:\Users\admin\Documents\Arduino\libraries\OneWire -IC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2\libraries\Wire\src -Ic:\Users\admin\Documents\Arduino\libraries\Newliquidcrystal_1.3.5 -Ic:\Users\admin\Documents\Arduino\libraries\ArduinoRTClibrary-master -IC:\Users\admin\Documents\Arduino\libraries\Newliquidcrystal_1.3.5\utility c:\Users\admin\Documents\Arduino\libraries\Newliquidcrystal_1.3.5\LiquidCrystal_SI2C.cpp -o nul
C:\Users\admin\AppData\Local\Arduino15\packages\rp2040\tools\pqt-gcc\2.2.0-d04e724/bin/arm-none-eabi-g++ -I C:\Users\admin\AppData\Local\Temp\arduino\sketches\9217A23F579D783B44CCF3B247E76EA5/core -c -Werror=return-type -Wno-psabi -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSBD_PID=0x000a -DUSBD_VID=0x2e8a -DUSBD_MAX_POWER_MA=250 -DUSB_MANUFACTURER="Raspberry Pi" -DUSB_PRODUCT="Pico" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=1 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 -DARDUINO_VARIANT="rpipico" -DTARGET_RP2040 -DPICO_FLASH_SIZE_BYTES=2097152 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -iprefixC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2/ @C:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2/lib/platform_inc.txt -IC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2/include -fno-rtti -std=gnu++17 -g -pipe -w -x c++ -E -CC -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO -DBOARD_NAME="RASPBERRY_PI_PICO" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE -IC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2\cores\rp2040 -IC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2\variants\rpipico -Ic:\Users\admin\Documents\Arduino\libraries\DallasTemperature -Ic:\Users\admin\Documents\Arduino\libraries\OneWire -IC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2\libraries\Wire\src -Ic:\Users\admin\Documents\Arduino\libraries\Newliquidcrystal_1.3.5 -Ic:\Users\admin\Documents\Arduino\libraries\ArduinoRTClibrary-master -IC:\Users\admin\Documents\Arduino\libraries\Newliquidcrystal_1.3.5\utility c:\Users\admin\Documents\Arduino\libraries\Newliquidcrystal_1.3.5\LiquidCrystal_SR.cpp -o nul
C:\Users\admin\AppData\Local\Arduino15\packages\rp2040\tools\pqt-gcc\2.2.0-d04e724/bin/arm-none-eabi-g++ -I C:\Users\admin\AppData\Local\Temp\arduino\sketches\9217A23F579D783B44CCF3B247E76EA5/core -c -Werror=return-type -Wno-psabi -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSBD_PID=0x000a -DUSBD_VID=0x2e8a -DUSBD_MAX_POWER_MA=250 -DUSB_MANUFACTURER="Raspberry Pi" -DUSB_PRODUCT="Pico" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=1 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 -DARDUINO_VARIANT="rpipico" -DTARGET_RP2040 -DPICO_FLASH_SIZE_BYTES=2097152 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -iprefixC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2/ @C:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2/lib/platform_inc.txt -IC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2/include -fno-rtti -std=gnu++17 -g -pipe -w -x c++ -E -CC -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO -DBOARD_NAME="RASPBERRY_PI_PICO" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE -IC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2\cores\rp2040 -IC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2\variants\rpipico -Ic:\Users\admin\Documents\Arduino\libraries\DallasTemperature -Ic:\Users\admin\Documents\Arduino\libraries\OneWire -IC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2\libraries\Wire\src -Ic:\Users\admin\Documents\Arduino\libraries\Newliquidcrystal_1.3.5 -Ic:\Users\admin\Documents\Arduino\libraries\ArduinoRTClibrary-master -IC:\Users\admin\Documents\Arduino\libraries\Newliquidcrystal_1.3.5\utility c:\Users\admin\Documents\Arduino\libraries\Newliquidcrystal_1.3.5\LiquidCrystal_SR1W.cpp -o nul
C:\Users\admin\AppData\Local\Arduino15\packages\rp2040\tools\pqt-gcc\2.2.0-d04e724/bin/arm-none-eabi-g++ -I C:\Users\admin\AppData\Local\Temp\arduino\sketches\9217A23F579D783B44CCF3B247E76EA5/core -c -Werror=return-type -Wno-psabi -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSBD_PID=0x000a -DUSBD_VID=0x2e8a -DUSBD_MAX_POWER_MA=250 -DUSB_MANUFACTURER="Raspberry Pi" -DUSB_PRODUCT="Pico" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=1 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 -DARDUINO_VARIANT="rpipico" -DTARGET_RP2040 -DPICO_FLASH_SIZE_BYTES=2097152 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -iprefixC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2/ @C:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2/lib/platform_inc.txt -IC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2/include -fno-rtti -std=gnu++17 -g -pipe -w -x c++ -E -CC -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO -DBOARD_NAME="RASPBERRY_PI_PICO" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE -IC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2\cores\rp2040 -IC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2\variants\rpipico -Ic:\Users\admin\Documents\Arduino\libraries\DallasTemperature -Ic:\Users\admin\Documents\Arduino\libraries\OneWire -IC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2\libraries\Wire\src -Ic:\Users\admin\Documents\Arduino\libraries\Newliquidcrystal_1.3.5 -Ic:\Users\admin\Documents\Arduino\libraries\ArduinoRTClibrary-master -IC:\Users\admin\Documents\Arduino\libraries\Newliquidcrystal_1.3.5\utility c:\Users\admin\Documents\Arduino\libraries\Newliquidcrystal_1.3.5\LiquidCrystal_SR2W.cpp -o nul
C:\Users\admin\AppData\Local\Arduino15\packages\rp2040\tools\pqt-gcc\2.2.0-d04e724/bin/arm-none-eabi-g++ -I C:\Users\admin\AppData\Local\Temp\arduino\sketches\9217A23F579D783B44CCF3B247E76EA5/core -c -Werror=return-type -Wno-psabi -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSBD_PID=0x000a -DUSBD_VID=0x2e8a -DUSBD_MAX_POWER_MA=250 -DUSB_MANUFACTURER="Raspberry Pi" -DUSB_PRODUCT="Pico" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=1 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 -DARDUINO_VARIANT="rpipico" -DTARGET_RP2040 -DPICO_FLASH_SIZE_BYTES=2097152 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -iprefixC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2/ @C:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2/lib/platform_inc.txt -IC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2/include -fno-rtti -std=gnu++17 -g -pipe -w -x c++ -E -CC -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO -DBOARD_NAME="RASPBERRY_PI_PICO" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE -IC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2\cores\rp2040 -IC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2\variants\rpipico -Ic:\Users\admin\Documents\Arduino\libraries\DallasTemperature -Ic:\Users\admin\Documents\Arduino\libraries\OneWire -IC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2\libraries\Wire\src -Ic:\Users\admin\Documents\Arduino\libraries\Newliquidcrystal_1.3.5 -Ic:\Users\admin\Documents\Arduino\libraries\ArduinoRTClibrary-master -IC:\Users\admin\Documents\Arduino\libraries\Newliquidcrystal_1.3.5\utility c:\Users\admin\Documents\Arduino\libraries\Newliquidcrystal_1.3.5\LiquidCrystal_SR3W.cpp -o nul
C:\Users\admin\AppData\Local\Arduino15\packages\rp2040\tools\pqt-gcc\2.2.0-d04e724/bin/arm-none-eabi-g++ -I C:\Users\admin\AppData\Local\Temp\arduino\sketches\9217A23F579D783B44CCF3B247E76EA5/core -c -Werror=return-type -Wno-psabi -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSBD_PID=0x000a -DUSBD_VID=0x2e8a -DUSBD_MAX_POWER_MA=250 -DUSB_MANUFACTURER="Raspberry Pi" -DUSB_PRODUCT="Pico" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=1 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 -DARDUINO_VARIANT="rpipico" -DTARGET_RP2040 -DPICO_FLASH_SIZE_BYTES=2097152 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -iprefixC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2/ @C:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2/lib/platform_inc.txt -IC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2/include -fno-rtti -std=gnu++17 -g -pipe -w -x c++ -E -CC -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO -DBOARD_NAME="RASPBERRY_PI_PICO" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE -IC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2\cores\rp2040 -IC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2\variants\rpipico -Ic:\Users\admin\Documents\Arduino\libraries\DallasTemperature -Ic:\Users\admin\Documents\Arduino\libraries\OneWire -IC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2\libraries\Wire\src -Ic:\Users\admin\Documents\Arduino\libraries\Newliquidcrystal_1.3.5 -Ic:\Users\admin\Documents\Arduino\libraries\ArduinoRTClibrary-master -IC:\Users\admin\Documents\Arduino\libraries\Newliquidcrystal_1.3.5\utility c:\Users\admin\Documents\Arduino\libraries\Newliquidcrystal_1.3.5\SI2CIO.cpp -o nul
C:\Users\admin\AppData\Local\Arduino15\packages\rp2040\tools\pqt-gcc\2.2.0-d04e724/bin/arm-none-eabi-g++ -I C:\Users\admin\AppData\Local\Temp\arduino\sketches\9217A23F579D783B44CCF3B247E76EA5/core -c -Werror=return-type -Wno-psabi -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSBD_PID=0x000a -DUSBD_VID=0x2e8a -DUSBD_MAX_POWER_MA=250 -DUSB_MANUFACTURER="Raspberry Pi" -DUSB_PRODUCT="Pico" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=1 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 -DARDUINO_VARIANT="rpipico" -DTARGET_RP2040 -DPICO_FLASH_SIZE_BYTES=2097152 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -iprefixC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2/ @C:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2/lib/platform_inc.txt -IC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2/include -fno-rtti -std=gnu++17 -g -pipe -w -x c++ -E -CC -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO -DBOARD_NAME="RASPBERRY_PI_PICO" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE -IC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2\cores\rp2040 -IC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2\variants\rpipico -Ic:\Users\admin\Documents\Arduino\libraries\DallasTemperature -Ic:\Users\admin\Documents\Arduino\libraries\OneWire -IC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2\libraries\Wire\src -Ic:\Users\admin\Documents\Arduino\libraries\Newliquidcrystal_1.3.5 -Ic:\Users\admin\Documents\Arduino\libraries\ArduinoRTClibrary-master c:\Users\admin\Documents\Arduino\libraries\ArduinoRTClibrary-master\virtuabotixRTC.cpp -o nul
Generating function prototypes...
C:\Users\admin\AppData\Local\Arduino15\packages\rp2040\tools\pqt-gcc\2.2.0-d04e724/bin/arm-none-eabi-g++ -I C:\Users\admin\AppData\Local\Temp\arduino\sketches\9217A23F579D783B44CCF3B247E76EA5/core -c -Werror=return-type -Wno-psabi -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSBD_PID=0x000a -DUSBD_VID=0x2e8a -DUSBD_MAX_POWER_MA=250 -DUSB_MANUFACTURER="Raspberry Pi" -DUSB_PRODUCT="Pico" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=1 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 -DARDUINO_VARIANT="rpipico" -DTARGET_RP2040 -DPICO_FLASH_SIZE_BYTES=2097152 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -iprefixC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2/ @C:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2/lib/platform_inc.txt -IC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2/include -fno-rtti -std=gnu++17 -g -pipe -w -x c++ -E -CC -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO -DBOARD_NAME="RASPBERRY_PI_PICO" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE -IC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2\cores\rp2040 -IC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2\variants\rpipico -Ic:\Users\admin\Documents\Arduino\libraries\DallasTemperature -Ic:\Users\admin\Documents\Arduino\libraries\OneWire -IC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2\libraries\Wire\src -Ic:\Users\admin\Documents\Arduino\libraries\Newliquidcrystal_1.3.5 -Ic:\Users\admin\Documents\Arduino\libraries\ArduinoRTClibrary-master C:\Users\admin\AppData\Local\Temp\arduino\sketches\9217A23F579D783B44CCF3B247E76EA5\sketch\temp_disp_rtc.ino.cpp -o C:\Users\admin\AppData\Local\Temp\2229955256\sketch_merged.cpp
C:\Users\admin\AppData\Local\Arduino15\packages\builtin\tools\ctags\5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives C:\Users\admin\AppData\Local\Temp\2229955256\sketch_merged.cpp
ΠšΠΎΠΌΠΏΠΈΠ»ΡΡ†ΠΈΡ скСтча...
"C:\Users\admin\AppData\Local\Arduino15\packages\rp2040\tools\pqt-python3\1.0.1-base-3a57aed/python3" -I "C:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2/tools/signing.py" --mode header --publickey "C:\Users\admin\Documents\Arduino\libraries\TryTech_RTC_Clock\TryTech_RTC_Clock\temp_disp_rtc/public.key" --out "C:\Users\admin\AppData\Local\Temp\arduino\sketches\9217A23F579D783B44CCF3B247E76EA5/core/Updater_Signing.h"
"C:\Users\admin\AppData\Local\Arduino15\packages\rp2040\tools\pqt-gcc\2.2.0-d04e724/bin/arm-none-eabi-g++" -I "C:\Users\admin\AppData\Local\Temp\arduino\sketches\9217A23F579D783B44CCF3B247E76EA5/core" -c -Wall -Wextra -Werror=return-type -Wno-ignored-qualifiers -Wno-psabi -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSBD_PID=0x000a -DUSBD_VID=0x2e8a -DUSBD_MAX_POWER_MA=250 "-DUSB_MANUFACTURER="Raspberry Pi"" "-DUSB_PRODUCT="Pico"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=1 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT="rpipico"" -DTARGET_RP2040 -DPICO_FLASH_SIZE_BYTES=2097152 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2/" "@C:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2/lib/platform_inc.txt" "-IC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2/include" -fno-rtti -std=gnu++17 -g -pipe -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO "-DBOARD_NAME="RASPBERRY_PI_PICO"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2\cores\rp2040" "-IC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2\variants\rpipico" "-Ic:\Users\admin\Documents\Arduino\libraries\DallasTemperature" "-Ic:\Users\admin\Documents\Arduino\libraries\OneWire" "-IC:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2\libraries\Wire\src" "-Ic:\Users\admin\Documents\Arduino\libraries\Newliquidcrystal_1.3.5" "-Ic:\Users\admin\Documents\Arduino\libraries\ArduinoRTClibrary-master" "C:\Users\admin\AppData\Local\Temp\arduino\sketches\9217A23F579D783B44CCF3B247E76EA5\sketch\temp_disp_rtc.ino.cpp" -o "C:\Users\admin\AppData\Local\Temp\arduino\sketches\9217A23F579D783B44CCF3B247E76EA5\sketch\temp_disp_rtc.ino.cpp.o"
C:\Users\admin\Documents\Arduino\libraries\TryTech_RTC_Clock\TryTech_RTC_Clock\temp_disp_rtc\temp_disp_rtc.ino:7: warning: "ONE_WIRE_BUS" redefined
7 | #define ONE_WIRE_BUS 2
C:\Users\admin\Documents\Arduino\libraries\TryTech_RTC_Clock\TryTech_RTC_Clock\temp_disp_rtc\temp_disp_rtc.ino:6: note: this is the location of the previous definition
6 | #define ONE_WIRE_BUS 3
In file included from c:\Users\admin\Documents\Arduino\libraries\Newliquidcrystal_1.3.5/LiquidCrystal_I2C.h:35,
from C:\Users\admin\Documents\Arduino\libraries\TryTech_RTC_Clock\TryTech_RTC_Clock\temp_disp_rtc\temp_disp_rtc.ino:4:
c:\Users\admin\Documents\Arduino\libraries\Newliquidcrystal_1.3.5/LCD.h: In member function 'virtual void LCD::setBacklightPin(uint8_t, t_backlighPol)':
c:\Users\admin\Documents\Arduino\libraries\Newliquidcrystal_1.3.5/LCD.h:486:43: warning: unused parameter 'value' [-Wunused-parameter]
486 | virtual void setBacklightPin ( uint8_t value, t_backlighPol pol ) { };
c:\Users\admin\Documents\Arduino\libraries\Newliquidcrystal_1.3.5/LCD.h:486:64: warning: unused parameter 'pol' [-Wunused-parameter]
c:\Users\admin\Documents\Arduino\libraries\Newliquidcrystal_1.3.5/LCD.h: In member function 'virtual void LCD::setBacklight(uint8_t)':
c:\Users\admin\Documents\Arduino\libraries\Newliquidcrystal_1.3.5/LCD.h:505:40: warning: unused parameter 'value' [-Wunused-parameter]
505 | virtual void setBacklight ( uint8_t value ) { };
C:\Users\admin\Documents\Arduino\libraries\TryTech_RTC_Clock\TryTech_RTC_Clock\temp_disp_rtc\temp_disp_rtc.ino: At global scope:
C:\Users\admin\Documents\Arduino\libraries\TryTech_RTC_Clock\TryTech_RTC_Clock\temp_disp_rtc\temp_disp_rtc.ino:12:33: error: invalid conversion from 'int' to 't_backlighPol' [-fpermissive]
12 | LiquidCrystal_I2C lcd(0x27, 20, 4); // УстанавливаСм дисплСй
| int
c:\Users\admin\Documents\Arduino\libraries\Newliquidcrystal_1.3.5/LiquidCrystal_I2C.h:53:76: note: initializing argument 3 of 'LiquidCrystal_I2C::LiquidCrystal_I2C(uint8_t, uint8_t, t_backlighPol)'
53 | LiquidCrystal_I2C (uint8_t lcd_Addr, uint8_t backlighPin, t_backlighPol pol);
C:\Users\admin\Documents\Arduino\libraries\TryTech_RTC_Clock\TryTech_RTC_Clock\temp_disp_rtc\temp_disp_rtc.ino: In function 'void setup()':
C:\Users\admin\Documents\Arduino\libraries\TryTech_RTC_Clock\TryTech_RTC_Clock\temp_disp_rtc\temp_disp_rtc.ino:73:11: error: 'int LiquidCrystal_I2C::init()' is private within this context
73 | lcd.init();
c:\Users\admin\Documents\Arduino\libraries\Newliquidcrystal_1.3.5/LiquidCrystal_I2C.h:154:9: note: declared private here
154 | int init();
НСсколько Π±ΠΈΠ±Π»ΠΈΠΎΡ‚Π΅ΠΊ Π½Π°ΠΉΠ΄Π΅Π½ΠΎ для "LiquidCrystal_I2C.h"
Π˜ΡΠΏΠΎΠ»ΡŒΠ·ΡƒΠ΅Ρ‚ΡΡ: C:\Users\admin\Documents\Arduino\libraries\Newliquidcrystal_1.3.5
НС ΠΈΡΠΏΠΎΠ»ΡŒΠ·ΡƒΠ΅Ρ‚ΡΡ: C:\Users\admin\Documents\Arduino\libraries\LiquidCrystal_I2C_V112
НС ΠΈΡΠΏΠΎΠ»ΡŒΠ·ΡƒΠ΅Ρ‚ΡΡ: C:\Users\admin\Documents\Arduino\libraries\LiquidCrystal_I2C-master
Π˜ΡΠΏΠΎΠ»ΡŒΠ·ΡƒΠ΅ΠΌ Π±ΠΈΠ±Π»ΠΈΠΎΡ‚Π΅ΠΊΡƒ DallasTemperature вСрсии 3.9.0 ΠΈΠ· ΠΏΠ°ΠΏΠΊΠΈ: C:\Users\admin\Documents\Arduino\libraries\DallasTemperature
Π˜ΡΠΏΠΎΠ»ΡŒΠ·ΡƒΠ΅ΠΌ Π±ΠΈΠ±Π»ΠΈΠΎΡ‚Π΅ΠΊΡƒ OneWire вСрсии 2.3.7 ΠΈΠ· ΠΏΠ°ΠΏΠΊΠΈ: C:\Users\admin\Documents\Arduino\libraries\OneWire
Π˜ΡΠΏΠΎΠ»ΡŒΠ·ΡƒΠ΅ΠΌ Π±ΠΈΠ±Π»ΠΈΠΎΡ‚Π΅ΠΊΡƒ Wire вСрсии 1.0 ΠΈΠ· ΠΏΠ°ΠΏΠΊΠΈ: C:\Users\admin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2\libraries\Wire
Π˜ΡΠΏΠΎΠ»ΡŒΠ·ΡƒΠ΅ΠΌ Π±ΠΈΠ±Π»ΠΈΠΎΡ‚Π΅ΠΊΡƒ Newliquidcrystal_1.3.5 Π² ΠΏΠ°ΠΏΠΊΠ΅: C:\Users\admin\Documents\Arduino\libraries\Newliquidcrystal_1.3.5 (ΡƒΡΡ‚Π°Ρ€Π΅Π²ΡˆΠ΅Π΅)
Π˜ΡΠΏΠΎΠ»ΡŒΠ·ΡƒΠ΅ΠΌ Π±ΠΈΠ±Π»ΠΈΠΎΡ‚Π΅ΠΊΡƒ ArduinoRTClibrary-master Π² ΠΏΠ°ΠΏΠΊΠ΅: C:\Users\admin\Documents\Arduino\libraries\ArduinoRTClibrary-master (ΡƒΡΡ‚Π°Ρ€Π΅Π²ΡˆΠ΅Π΅)
exit status 1
Compilation error: invalid conversion from 'int' to 't_backlighPol' [-fpermissive]
This means that the issue is in your code.
Please show your code using code tags.
shows a bug in the LiquidCrystal library :neutral_face:
but the same library compiles normally with nano and uno boards.
sorry for my English, I'm from Ukraine.
what devices are you attempting to connected to the RPi pico?
have you tested each device in a separate program?
in each case did you check in the library documentation that it supports the RPi pico?
The output shows a lot of errors not in the library, but in your code.
But it is your decision, do not show your code if you do not need a help
#include <DallasTemperature.h>
#include <OneWire.h>
#include <Wire.h>
#include <virtuabotixRTC.h>
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
virtuabotixRTC myRTC(6, 7, 8);       //Wiring of the RTC (CLK,DAT,RST)
                                     //If  you change the wiring change the pins here also
//#include "DHT.h"
//#define DHTPIN 2  //Π΄ΠΎ якого ΠΏΡ–Π½Ρƒ Π±ΡƒΠ΄Π΅ ΠΏΡ–Π΄ΠΊΠ»ΡŽΡ‡Π΅Π½ΠΈΠΉ Π²ΠΈΠ²Ρ–Π΄ Data
//Π²ΠΈΠ±Ρ–Ρ€ Π΄Π°Ρ‚Ρ‡ΠΈΠΊΠ°
//#define DHTTYPE DHT22  // DHT 11
//#define DHTTYPE DHT22   // DHT 22  (AM2302)
//#define DHTTYPE DHT21   // DHT 21 (AM2301)
//ініціалізація Π΄Π°Ρ‚Ρ‡ΠΈΠΊΠ°
//DHT dht(DHTPIN, DHTTYPE);
void print_temp() {
  lcd.setCursor(0, 1);
  //float h = dht.readHumidity();
  //float t = dht.readTemperature();
  // пСрСвіряємо Ρ‡ΠΈ ΠΏΡ€Π°Π²ΠΈΠ»ΡŒΠ½Ρ– Π΄Π°Π½Ρ– ΠΎΡ‚Ρ€ΠΈΠΌΠ°Π»ΠΈ
  //if (isnan(t) || isnan(h)) {
  //  lcd.print("Error sensor");
  //} else {
  //  lcd.setCursor(0, 2);
  //  lcd.print(t);
   // lcd.write(2);
    //lcd.print("C ");
   // lcd.setCursor(10, 2);
   // lcd.print(h);
    //lcd.write(1);
  sensors.begin();  // Start up the library
  byte drop[8] = {
    0b00100,
    0b01010,
    0b11011,
    0b10011,
    0b10001,
    0b11011,
    0b01110,
    0b00000
  byte cel[8] = {
    0b00111,
    0b00101,
    0b00111,
    0b00000,
    0b00000,
    0b00000,
    0b00000,
    0b00000
  //dht.begin();
  lcd.init();
  lcd.begin(20, 4);  // initialize the lcd
  lcd.createChar(1, drop);
  lcd.createChar(2, cel);
  lcd.backlight();  // Π’ΠΊΠ»ΡŽΡ‡Π°Π΅ΠΌ подсвСтку дисплСя
//myRTC.setDS1302Time(17,  8, 0, 4, 10, 2, 2024);
  myRTC.updateTime();
   sensors.requestTemperatures();
  print_temp();
  lcd.setCursor(0, 3);
  lcd.print(sensors.getTempCByIndex(0));
  lcd.write(2);
  lcd.print("C ");
  lcd.print(sensors.getTempCByIndex(1));
  lcd.write(2);
  lcd.print("C ");
  lcd.setCursor(10, 0);
  lcd.print(myRTC.dayofmonth);
  lcd.print(".");
  if (myRTC.month < 10) lcd.print(0);
  lcd.print(myRTC.month);
  lcd.print(".");
  lcd.print(myRTC.year);
  lcd.setCursor(0, 0);
  myRTC.updateTime();
  lcd.print(myRTC.hours, DEC);
  lcd.print(":");
  if (myRTC.minutes < 10) lcd.print(0);
  lcd.print(myRTC.minutes, DEC);
  lcd.print(":");
  if (myRTC.seconds < 10) lcd.print(0);
  lcd.print(myRTC.seconds, DEC);
  delay(10);
but the same code works and compiles for arduino uno or nano.
here is a simple example of code that works on uno but does not work on raspberry pi pico
//YWROBOT
//Compatible with the Arduino IDE 1.0
//Library version:1.1
LiquidCrystal_I2C lcd(0x27,20,4);  // set the LCD address to 0x27 for a 16 chars and 2 line display
  lcd.init();                      // initialize the lcd
  // Print a message to the LCD.
  lcd.backlight();
  lcd.setCursor(3,0);
  lcd.print("Hello, world!");
  lcd.setCursor(2,1);
  lcd.print("Ywrobot Arduino!");
   lcd.setCursor(0,2);
  lcd.print("Arduino LCM IIC 2004");
   lcd.setCursor(2,3);
  lcd.print("Power By Ec-yuan!");
the fact that the code compiles and works on a UNO does not guarantee that it will compile and work on a RPi Pico
you need to test each device seperatly checking the library documentation that it is compatible with the RPi pico
for example attempting to use onewire.h on a pico gives
In file included from c:\Users\bb\Documents\Arduino\libraries\OneWire\OneWire.cpp:144:
c:\Users\bb\Documents\Arduino\libraries\OneWire\util/OneWire_direct_gpio.h:441:2: warning: #warning "OneWire. Fallback mode. Using API calls for pinMode,digitalRead and digitalWrite. Operation of this library is not guaranteed on this architecture." [-Wcpp]
  441 | #warning "OneWire. Fallback mode. Using API calls for pinMode,digitalRead and digitalWrite. Operation of this library is not guaranteed on this architecture."
on the RPi pico for the DS18B20 temperature Sensor I used OneWireNg
see OneWireNg/tree/master/examples DallasTemperature
it is very difficult for me.
approach the problem in stages
  1. test the DS18B20 temperature Sensor using the link I gave in post 7 - does it work?
  2. implement a program to test the LCD using <LiquidCrystal_I2C.h> does it work? if not try a web search for LiquidCrystal_I2C pico
  3. similar with the RTC
if your original program works on a UNO why are you attempting to port it to a RPi Pico? - it seems a strange choice
the library LiquidCristal_i2c.h is not working.
what LCD are you using? is it 5V or 3.3V logic?
I did a web search and found RPI-Pico-I2C-LCD-Control - note the use of a level converter to convert the Pico 3.3V logic to the LCD 5V logic
There are more than one library with the same name LiquidCristal_i2c.h.
According to this error:
you installed not the same library that used in your code.
Also your code contains a weird lines:
Why do you define a two One_Wire buses?
Is it you who wrote the code or you found it in the net? Do you understand the code or just copy it?
this code i put together from pieces of other codes.
you have make sure the pieces work before you attempt to put them together
hence seperate test programs to check the pieces work on the target microcontroller then implement the final project
You didn't answer - do you understand the code?
In general - what do you expect from the forum? Somebody to fix your code for you? It is not works that way. The forum could help you, but you still have to done it yourself.
Yes, i understand that code
