Raspberry pi Pico (RP2040) and Encoder
Hello, working with ConfigurableFirmata and RP2040 ive noticed the encoder library works unreliably for this board.
I get encoder readings however they are unreliable. meaning if i turn left sometimes the value increases, sometimes decreases, skips steps, and the same the other way. Also there is no correlation with the number of clicks of the encoder and the increase/decrease of the reading.
I suspect this issue is related with RP2040 interrupts.
This works great for other boards like arduino nano for instance.
issue link:
Ive installed the RP2040 board in the Arduino IDE ARDUINO MBED OS RP2040 3.4.1
Ive done some research and this issue has been reported
in theory it was fixed, however its not working for me, can you please help me? having the encoder work is the last piece in the puzzle to start using RP2040 for my projects.
if using the encoder library is not compatible with rp2040 would it be possible to adapt other encoder library to work with ConfigurableFirmata?
thanks a lot.
