Can I run the Arduino IDE on a Raspberry Pi 4 and upload the code to my arduino boards?
Yes, that is very easy to do
What about using a LattePanda instead of the Raspberry Pi?
What OS does it use ?
Windows 10. But I'm more worried about ram.
Why not just give the full details of it instead of a drip feed ?
See links in post #5
Which you added since my post
It looks like it has plenty of RAM to run the IDE
Oh okay.
My moms PC is 16gb ram, but when I run the IDE the ram goes from 11% used to 78% used.
Meaning the IDE is using 67% of 16gb - 11 gb for the IDE itself.
That sounds unlikely considering that the IDE runs perfectly on a 4Gb Raspberry Pi 4
Modern programs change their requests depending on the resources. That is, with available 16 GB, it will take 11, and with available 4 - it will be enough from 3.5
Ah ok.
I suppose it will be slightly slower though.
I regularly run the IDE in a VM with only 6gb allocated, and I just checked on another VM with only 3G, and that seem to work OK as well. 8G should be plenty.
