Raspberry PI Zer <-> CLI: invalid item
Hello,
I have a problem.
I connect a Raspberry PI Zero W (current headless image) to a MKR 1010 using a MicroUSB-> MicroUSB cable (data pins: white on white, green on green).
Here are the following issues:
pi@raspberry:~ $ arduino-cli board list
Port         Type              Board Name            FQBN                     Core
/dev/ttyACM0 Serial Port (USB) Arduino MKR WiFi 1010 arduino:samd:mkrwifi1010 arduino:samd
/dev/ttyAMA0 Serial Port       Unknown
pi@raspberry:~ $ arduino-cli core install arduino:samd:mkrwifi1010
Invalid argument passed: invalid item arduino:samd:mkrwifi1010
-> invalid item
what is wrong?
Many thanks for your help!
The argument to th earduino-cli core install command is the platform (AKA "core") name, which has the form "vendor:architecture". You've passed it the FQBN of the MKR WiFi 1010, arduino:samd:mkrwifi1010. You need to instead pass it the platform name listed under the "Core" column: arduino:samd. So the command to install the arduino:samd platform is:
Hello,
thanks for the quick response.
The samd installation works. The error remains here:
And I am getting a compiler error:
pi@raspberry:~ $
pi@raspberry:~ $
pi@raspberry:~ $ arduino-cli sketch new MyFirstSketch
Sketch created in: /home/pi/MyFirstSketch
pi@raspberry:~ $ cat MyFirstSketch/MyFirstSketch.ino
pi@raspberry:~ $
pi@raspberry:~ $ arduino-cli compile --fqbn arduino:samd:mkrwifi1010 MyFirstSketch
/home/pi/.arduino15/packages/arduino/hardware/samd/1.8.11/cores/arduino/WInterrupts.c: In function 'detachInterrupt':
/home/pi/.arduino15/packages/arduino/hardware/samd/1.8.11/cores/arduino/WInterrupts.c:199:1: internal compiler error: Illegal instruction
Please submit a full bug report,
with preprocessed source if appropriate.
See <https://gcc.gnu.org/bugs/> for instructions.
/home/pi/.arduino15/packages/arduino/hardware/samd/1.8.11/cores/arduino/cortex_handlers.c: In function 'Reset_Handler':
/home/pi/.arduino15/packages/arduino/hardware/samd/1.8.11/cores/arduino/cortex_handlers.c:188:1: internal compiler error: Illegal instruction
Error during build: exit status 1
pi@raspberry:~ $ arduino-cli core list
ID           Installed Latest Name
arduino:samd 1.8.11    1.8.11 Arduino SAMD Boards (32-bits ARM Cortex-M0+)
OK, let's see if it's tied to a specific version of the arduino:samd platform. There was a big change in the arduino:samd platform's core library in 1.8.10, so try 1.8.9:
arduino-cli core install arduino:samd@1.8.9
Then try compiling again. If the problem persists, try installing 1.6.21:
arduino-cli core install arduino:samd@1.6.21
The arm-none-eabi-gcc compiler version was upgraded after that.
Unfortunately, I think the RPi Zero support is a bit patchy because it uses a different ARM architecture version than the more high end ARM SBCs.
Thank you very much!
arduino:samd 1.6.21    1.6.21 Arduino SAMD Boards (32-bits ARM Cortex-M0+)
Sketch uses 11024 bytes (4%) of program storage space. Maximum is 262144 bytes.
I hope everything goes well with the version 1.6.21.
I should use the identical arduino ide version.
I'm very glad to see that successful compilation.
Enjoy!
Per
