This is a bit of a follow on from my previous post with some specific findings, my issue is uploading code to a Pico or Pico W and then it automatically runs when power is added, in my case this is not happening.
I can create code and it runs successfully on the Pico whilst connected to Arduino 2.1.1 running on a Mac M2, the Blink example is the same. Disconnecting it from the MAC and connecting a power supply I would expect and hope that the code would automatically start but it does not.
As a result of the above I have used the BOOTSEL and loaded the flash_nuke.uf2 to reset the Pico and the Pico appears as a flash drive. I have found my weather_lorawan_app.ino.uf2 and dragged it to the flash drive which as expected reboots and disappears.
Three key points:
1 - When power is applied from external power supply the code does not run.
2 - When power is applied from the MAC USB port and the Arduino IDE 2.1.1 is NOT loaded my code does not run.
3 - When power is applied from the MAC USB port and the Arduino IDE 2.1.1 IS loaded and the weather_lorawan_app not loaded my weather_lorawan_app.ino.uf2 is running.
I can confirm if my weather_lorawan_app.ino.uf2 is running as the Serial Monitor is displaying output and I also have an OLED display that when working, temperature data is displayed.
I have used a Pico, Pico W and various cable to trouble shoot the issues, am I missing something very simple here?
