RaspberryPi下上传程序占用了 (193%) 程序存储空间
esp32的例程camerawebserver,在win10电脑上上传的开发板可以正常上传,但是在RaspberryPi4B里上传却显示
text section exceeds available space in board
项目使用了 2530534 字节,占用了 (193%) 程序存储空间。最大为 1310720 字节。
全局变量使用了55812字节,(17%)的动态内存,余留271868字节局部变量。最大为327680字节。
Sketch too big; see https://support.arduino.cc/hc/en-us/articles/360013825179 for tips on reducing it.
为开发板 ESP32 Dev Module 编译时出错。
我试了试在win10中arduinoide2.0rc版本里也会出现这样的情况。
我不明白这是为什么,明明使用的是同样的代码和同样的开发板。
English: via Google:
The routine camerawebserver of esp32, the development board uploaded on the win10 computer can be uploaded normally, but the upload in RaspberryPi4B shows
The project used 2,530,534 bytes, occupying (193%) of the program storage space. The maximum is 1310720 bytes.
Global variables use 55,812 bytes (17%) of dynamic memory, leaving 271,868 bytes of local variables. The maximum is 327680 bytes.
An error occurred when compiling for the development board ESP32 Dev Module.
I tried the same situation in the arduinoide2.0rc version of win10.
I don't understand why this is because I obviously use the same code and the same development board.
