I have the raspi pico w hardware and I have a mac address that belongs to the wifi chip. I want to plug w5500 series ethernet into pico and I want the mac address to be more than 1 Wifi mac address how can I do it
Were it possible, the lengthy reference manual would be the source I would consult. But, from Advance Setup guide, I do not see a direct mechanism:
Advanced Setup of W5500 Ethernet Shield for Internet and LAN — XOD
The W5500 chip does not hard-code its MAC as many consumer devices do, so you have to provide it manually.
you use the Ethernet library or the lwIP_Ethernet library?
Hi i will try LwIP_Ethernet Library,
Here is my code
#include <WiFi.h>
delay(5000);
WiFi.mode(WIFI_STA);
WiFi.setHostname("PicoW2");
// start WiFi to read current mac
Serial.print("Wifi Mac Address : ");
Serial.println(WiFi.macAddress().c_str());
byte mac[6] ;
WiFi.macAddress(mac );
//const size_t arrlen = sizeof(mac);
//Serial.println(arrlen);
//mac[0]=0xEA;
for(int i= 5; i<6; i++)
int a = ((mac[i]%100)/10)*16;
int b = ((mac[i]%100)%10);
mac[i]=a+b;
Serial.print("ETH MAC address : ");
for(int i=0; i<5; i++)
Serial.print(mac[i], HEX);
Serial.print(":");
Serial.println(mac[5], HEX);
//Ethernet.init(WIZ_CS);
//Ethernet.begin(mac);run once:
But it doesn't show the numbers 0 in the screen output
I am not sure if the LwIP_Ethernet is ready to use,
the MAC address for the W5500 is your responsibility. it is not a good idea to use the MAC address of the WiFi adapter. see the examples of the Ethernet library
I update code corret value return
#include <WiFi.h>
delay(5000);
byte mac[6] ;
//mac[0]=0xEA;
mac[i]=a+b;
char s[18];
sprintf(s, "%02x:%02x:%02x:%02x:%02x:%02x", mac[0],mac[1],mac[2],mac[3],mac[4],mac[5],mac[6]);
Serial.println(s);
//Ethernet.begin(s);
But i wan to change wifi -> Eth last character
