rational number's arithmetic operation malfunction
"1 + (B/A)" is different from "(A+B) / A"
example,
A = 0.0048828125*0.0002953;
B = 29.92126;
following result :
(A+B) / A : Serial.print = 0.0000001192
1 + (B/A) : Serial.print = 0.0000000000
it is not casting problem.
total source code :
double A = 0.0048828125*0.0002953;
double B = 29.92126;
Serial.println( (double)( (double)A + (double)B) / (double)B , 10 );
Serial.println( (double)((double)1)+(double)((double)A / (double)B),10 );
while(1);
"float" is same, too.
i am very confuse....
what's problem for me?
Your expectations of 32 bit floating point arithmetic are too high?
That's not what the (badly posted) code does.
Thank you.
you are right.
mentisa is overflow..
both float and double are 4bytes.
following result :
Strange, I would expect
1.0000001192
1.0000000000
made me think of the saying "1 + 1 = 3 for very large values of 1"
