Raw byte data via Bluetooth LE from arduino (HM-10) to Android
Hi
I have a project where I want to send sensor-data from my arduino via my HM-10 bluetooth module to an android app for visualisation. So I am testing transmission with a toy project.
I am sending raw bytes (from a struct) over a softwareSerial connection.
#include <SoftwareSerial.h>
#include "typedefs.h"
SoftwareSerial mySerial(2, 3);
sensorPack constructPack(unsigned long t,int v){
  sensorPack result;
  result.data.pre=0xFF;
  result.data.post=0xFF;
  result.data.time=t;
  result.data.value=v;
  return result;
  while (!Serial) {}
  mySerial.begin(9600);
  sensorPack cur = constructPack((unsigned long)1,(float)1.0);
  mySerial.write(cur.raw,10);
//Code to print bytes to string
  int size = 10;
  int i;
  char* buf_str = (char*) malloc (2*size + 1);
  char* buf_ptr = buf_str;
  for (i = 0; i < size; i++){
    buf_ptr += sprintf(buf_ptr, "%02X", cur.raw[i]);
  sprintf(buf_ptr,"\n");
  *(buf_ptr + 1) = '\0';
  Serial.println(buf_str);
  delay(5000);
typedefs.h
#ifndef _LOADED_H
#define _LOADED_H
typedef struct sensorData{
  unsigned char pre;
  unsigned long time;
  float value;
  unsigned char post;
typedef union sensorPack{
  sensorData data;
  unsigned char raw[10];
#endif
Over the regular serial connection I get "FF010000000000803FFF" (FF 0100 0000 0000 803F FF) as expected.
However using the app 'nRF Master Control Panel' on my Android phone I receive all sorts of data packets
V	14:21:03.969	Notifications enabled for 0000ffe1-0000-1000-8000-00805f9b34fb
I	14:21:05.123	Notification received from 0000ffe1-0000-1000-8000-00805f9b34fb, value: (0x) FF-01-00-00-00-00-00-80-3F-FF-00
A	14:21:05.218	"(0x) FF-01-00-00-00-00-00-80-3F-FF-00" received
I	14:21:10.126	Notification received from 0000ffe1-0000-1000-8000-00805f9b34fb, value: (0x) FF-01-00-00-00-00-00-FA
A	14:21:10.163	"(0x) FF-01-00-00-00-00-00-FA" received
I	14:21:15.143	Notification received from 0000ffe1-0000-1000-8000-00805f9b34fb, value: (0x) FF-01-00-00-00-00-00-80-3F-FF-00
A	14:21:15.158	"(0x) FF-01-00-00-00-00-00-80-3F-FF-00" received
I	14:21:20.143	Notification received from 0000ffe1-0000-1000-8000-00805f9b34fb, value: (0x) FF-01-00-00-00-00-00-00-F8
A	14:21:20.168	"(0x) FF-01-00-00-00-00-00-00-F8" received
I	14:21:25.172	Notification received from 0000ffe1-0000-1000-8000-00805f9b34fb, value: (0x) FF-01-00-00-00-00-80-3F-FF
A	14:21:25.197	"(0x) FF-01-00-00-00-00-80-3F-FF" received
I	14:21:26.572	Notification received from 0000ffe1-0000-1000-8000-00805f9b34fb, value: (0x) FF-01-00-00-00-00-80-3F-FF
A	14:21:26.604	"(0x) FF-01-00-00-00-00-80-3F-FF" received
I	14:21:31.568	Notification received from 0000ffe1-0000-1000-8000-00805f9b34fb, value: (0x) FF-01-00-00-00-00-00-80-3F-FF
A	14:21:31.600	"(0x) FF-01-00-00-00-00-00-80-3F-FF" received
I	14:21:36.590	Notification received from 0000ffe1-0000-1000-8000-00805f9b34fb, value: (0x) FF-01-00-00-00-00-00-FA
A	14:21:36.623	"(0x) FF-01-00-00-00-00-00-FA" received
I	14:21:41.592	Notification received from 0000ffe1-0000-1000-8000-00805f9b34fb, value: (0x) FF-01-00-00-00-00-80-3F-FF
A	14:21:41.631	"(0x) FF-01-00-00-00-00-80-3F-FF" received
I	14:21:46.612	Notification received from 0000ffe1-0000-1000-8000-00805f9b34fb, value: (0x) FF-01-00-00-00-00-00-00-00
A	14:21:46.654	"(0x) FF-01-00-00-00-00-00-00-00" received
I	14:21:51.616	Notification received from 0000ffe1-0000-1000-8000-00805f9b34fb, value: (0x) FF-01-00-00-00-00-80-3F-FF
A	14:21:51.651	"(0x) FF-01-00-00-00-00-80-3F-FF" received
Is this behavior normal? Is extra bookkeeping data sent? Is the data corrupt and should I include error-correction?
Other tips?
Kind regards
Jasper
