Raw code for servo motor on CNC shield V3.
Greetings fellow forum members,
I am new to this forum so please forgive me and tell me whenever I do not comply to the customs that are at work here.
I am working on a project with the Arduino Uno and I have a hard time finding information on how to get a hobby servo motor (SM-S2309S) working with the CNC shield.
I know a much that the shield is not designed for servo motors, but I see many plotter projects that have one, two or three stepper motors AND a servo working alongside of each other.
My project contains two stepper motors(which i have gotten working) and a servo. The stepper motors realize the movements in the X and Z direction while the servo needs to open and close a gripper.
I want to realize these actions with the use of the CNC shield, but I do not want to use any form of GRBL. I want to understand and be able to write the raw code for this project, so I can easily adapt and correct it when necessary.
My question to you is how I can control this servo motor through the CNC shield. I understand how it works on the UNO directly but I cannot figure out which pins to use for output to servo.
I hope I have formulated my question clearly and you are able to provide some information for me.
With kind regards,
MrGls
ps: I am running an external power supply of 12v (8xAA).
I don't really understand why you want to drive servos through a shield not intended for use with servos. But you certainly should say exactly which of the many possible "CNC Shields" you are using. A link to it would be good.
Steve
For this CNC shield.
You can use any of the pins that are unused in your setup to control a servo. Here is an example using the coolant enable pin (A3) for a servo. It is the Servo sweep example, modified. Note that a servo will probably need an external power supply as the Uno 5V or USB power may not be sufficient.
#include <Servo.h>
Servo servo;
const byte servoPin = A3; // coolant enable
byte pos = 0;
   servo.attach(servoPin);
  for (pos = 0; pos <= 180; pos += 1) { // goes from 0 degrees to 180 degrees
    // in steps of 1 degree
    servo.write(pos);              // tell servo to go to position in variable 'pos'
    delay(15);                       // waits 15ms for the servo to reach the position
  for (pos = 180; pos >= 0; pos -= 1) { // goes from 180 degrees to 0 degrees
Here are how the CNC shield pins are assigned to an Uno.
Thank you so much groundFungus. I got my servo working.
As I explained, the one thing I was missing was to identify the output pin. In this case you say the cooler enable is connected to A3. If I understand you correctly then I can also, for example, connect the servo to the limit Z-Axis by code: "servo.attach(11)". Is that correct? I also wondered where pin A4 and A5 are connected to. Which pins are these on the CNC shield?
To Steve:
I defined the shield in the topic title. I forgot to specify it in my post. The reason I want to put the servo on my CNC shield is that I will most likely have 3 or four stepper motors running when my project continues and I was looking for a shield that could provide me this. Then I found this CNC v3 shield that let me do that. Later I realized that I needed space for a servo too. Since the CNC goes straight onto my UNO I had difficulties finding a way to use the CNC shield and add the servo all together.
With kind regards,
MrGls
Above the header for connecting limit swices is a seperate 8 pin (4x2) header. The SDA (A4) and SCL (A5) are boken out on that header.
Yes.
