Could help help me with the command line to "Batch convert" a folder of .gif to an other folder of .raw?
What! raw is the format when the image is take stright from the cameras CCD (Nikon call NEF). You would never go from gif to raw. Are you sure you don't mean bmp and not raw. gif also has a very limited colour palete as it's meant for cartoons.
Ok I guess i need to clarify a few things... If I use the "ImageConverter565.exe" included in the UTFT lib... Everything works just fine... I can convert a .gif to raw with no problem...
I'm reading images from the SD card no problem.
But what I require is to convert over 5000 images, not really feasible 1 by 1.
I can use a bulk converter to change them from .gif to .bmp if requires.
I've tried to read the converted .bmp directly without success.
Only .raw converted with "ImageConverter565.exe" will display correctly.
I'm using UTFT_SdFat lib because I'm using a DUE with a CTE shield and a 7 display...
Hey I recently started using a professional camera and I would like to know is anyone can recommend a good converter from RAW to JPEG. I've been looking online but it's all kind of just not right
hey just joined. I'm using soft orbits to covert raw images. I have been looking for a good photo converter for a while now since I started doing photography on the side. It's always kind of been a passion of mine to be able to create this beautiful and unique pictures. I had a problem though because A) the pictures were too big and B) they were in a RAW format that my regular photo viewer did not recognized. So I started looking for a semi-cheap software and I found Softorbits (You can check it here: www.softorbits.com). I have been using it for a while now and I really like it. It's nice and user friendly. I feel like it helps me with my studies with XOD as well.
