I'm using a dual dimmer (2 channel, RobotDyn & RBDDimmer-master), but non of the relays are opening up. got two dimmer...same problem with both
with the testprogram I can set 'power' and all other functions seem to work. blue LEDs are 'on', reading value with 1 channel active is correct. Using two channels it returns false results.
Frontend seems to be working (more or less), but nothing is happening on the line output (LEDs aren't on and neither is the light)
would be great to get at least one channel working and have a look into the rest later...
Using a Mega r3
if someone out there could help, would be most appreciated
regards
* RobotDyn
* Dimmer Library
* The following sketch is meant to define the dimming value through the serial port of the controller,
* using USE_SERIAL.begin
* void printSpace() function is used for adding of space after functional data
* void loop() serial port evaluator, used to register and define values in dimmer.setPower(outVal);
* ---------------------- OUTPUT & INPUT Pin table ---------------------
* | Board | INPUT Pin | OUTPUT Pin |
* | | Zero-Cross | |
* | Lenardo | D7 (NOT CHANGABLE) | D0-D6, D8-D13 |
* | Mega | D2 (NOT CHANGABLE) | D0-D1, D3-D70 |
* | Uno | D2 (NOT CHANGABLE) | D0-D1, D3-D20 |
* | ESP8266 | D1(IO5), D2(IO4), | D0(IO16), D1(IO5), |
* | | D5(IO14), D6(IO12), | D2(IO4), D5(IO14), |
* | | D7(IO13), D8(IO15), | D6(IO12), D7(IO13), |
* | | | D8(IO15) |
* | ESP32 | 4(GPI36), 6(GPI34), | 8(GPO32), 9(GP033), |
* | | 5(GPI39), 7(GPI35), | 10(GPIO25), 11(GPIO26), |
* | | 8(GPO32), 9(GP033), | 12(GPIO27), 13(GPIO14), |
* | | 10(GPI025), 11(GPIO26), | 14(GPIO12), 16(GPIO13), |
* | | 12(GPIO27), 13(GPIO14), | 23(GPIO15), 24(GPIO2), |
* | | 14(GPIO12), 16(GPIO13), | 25(GPIO0), 26(GPIO4), |
* | | 21(GPIO7), 23(GPIO15), | 27(GPIO16), 28(GPIO17), |
* | | 24(GPIO2), 25(GPIO0), | 29(GPIO5), 30(GPIO18), |
* | | 26(GPIO4), 27(GPIO16), | 31(GPIO19), 33(GPIO21), |
* | | 28(GPIO17), 29(GPIO5), | 34(GPIO3), 35(GPIO1), |
* | | 30(GPIO18), 31(GPIO19), | 36(GPIO22), 37(GPIO23), |
* | | 33(GPIO21), 35(GPIO1), | |
* | | 36(GPIO22), 37(GPIO23), | |
* | Arduino M0 | D7 (NOT CHANGABLE) | D0-D6, D8-D13 |
* | Arduino Zero | | |
* | Arduino Due | D0-D53 | D0-D53 |
* | STM32 | PA0-PA15,PB0-PB15 | PA0-PA15,PB0-PB15 |
* | Black Pill | PC13-PC15 | PC13-PC15 |
* | BluePill | | |
* | Etc... | | |
#include <RBDdimmer.h>//
//#define USE_SERIAL SerialUSB //Serial for boards whith USB serial port
#define outputPin1 3
#define outputPin2 4
#define zerocross 2 // for boards with CHANGEBLE input pins
//dimmerLamp dimmer(outputPin, zerocross); //initialase port for dimmer for ESP8266, ESP32, Arduino due boards
dimmerLamp dimmer1(outputPin1); //initialase port for dimmer for MEGA, Leonardo, UNO, Arduino M0, Arduino Zero
//dimmerLamp dimmer2(outputPin2);
int outVal = 0;
USE_SERIAL.begin(9600);
dimmer1.begin(NORMAL_MODE, ON); //dimmer initialisation: name.begin(MODE, STATE)
//dimmer2.begin(NORMAL_MODE, ON);
USE_SERIAL.println("Dimmer Program is starting...");
USE_SERIAL.println("Set value");
void printSpace(int val)
if ((val / 100) == 0) USE_SERIAL.print(" ");
if ((val / 10) == 0) USE_SERIAL.print(" ");
int preVal = outVal;
if (USE_SERIAL.available())
int buf = USE_SERIAL.parseInt();
if (buf != 0) outVal = buf;
delay(200);
dimmer1.setPower(outVal); // setPower(0-100%);
//dimmer2.setPower(70); // setPower(0-100%);
if (preVal != outVal)
USE_SERIAL.print("lampValue -> ");
printSpace(dimmer1.getPower());
USE_SERIAL.print(dimmer1.getPower());
USE_SERIAL.println("%");
USE_SERIAL.print(dimmer1.getState());
/*printSpace(dimmer2.getPower());
USE_SERIAL.print(dimmer2.getPower());
USE_SERIAL.print(dimmer2.getState());*/
delay(50);
that's the result
Dimmer program is starting...
Set value
lampValue -> 50%
1
