RBG with WS2811 chips
To start: please. Not a cross post. I don't want to be banned again, This is an entirely different post unrelated to any other ones.
Now: I am trying to program two common cathode RBG LEDs that will be soldered to to individual WS2811 chips. A neopixel is too big to fit in the space I need this in and I only need two about 10 cm apart. So 1 chip per LED, 2 LEDs, two chips. I've been looking at the examples in FastLED and Adafruit neopixel library and for the most part I understand what they are doing but what I am trying to do is have these two LEDs come on at solid red (255,0,0) and then on a button press fade to cyan, for a few seconds using millis(), and then fade back to red. Not necessarily looking for code but if someone can point me at an example that's similar that I don't see in the library/internet or walk me through programming it myself I'd appreciate it.
This will be my last post for a while as I will have all I need for at least 2 years in models but of course I will respond to anything here, just nothing new will be posted in a new topic. I've seen the blend using fast LED but using the chips it won't work because they only need a data pin.
see data sheet for chip details Data Sheet
UPDATE: Ok I have modified an example with the FastLed.h library. It will fade the colors to what I want them to do but its automated. I have a lot of commented out things but the code is below. i need to figure out how to control it, so it starts on red and stay red until I press a button (NOT CODED YET) and then fades to Cyan. Waits say 10 seconds then fades back to Red until I press the button again.
#include <FastLED.h>
#define LED_PIN     9
#define NUM_LEDS    2
#define BRIGHTNESS  64
#define LED_TYPE    WS2811
#define COLOR_ORDER GRB
CRGB leds[NUM_LEDS];
#define UPDATES_PER_SECOND 100
// This example shows several ways to set up and use 'palettes' of colors
// with FastLED.
// These compact palettes provide an easy way to re-colorize your
// animation on the fly, quickly, easily, and with low overhead.
// USING palettes is MUCH simpler in practice than in theory, so first just
// run this sketch, and watch the pretty lights as you then read through
// the code.  Although this sketch has eight (or more) different color schemes,
// the entire sketch compiles down to about 6.5K on AVR.
// FastLED provides a few pre-configured color palettes, and makes it
// extremely easy to make up your own color schemes with palettes.
// Some notes on the more abstract 'theory and practice' of
// FastLED compact palettes are at the bottom of this file.
CRGBPalette16 currentPalette;
TBlendType    currentBlending;
extern CRGBPalette16 myRedWhiteBluePalette;
extern const TProgmemPalette16 myRedWhiteBluePalette_p PROGMEM;
extern const TProgmemPalette16 myRedCyanPalette_p PROGMEM;
  delay( 3000 ); // power-up safety delay
  FastLED.addLeds<LED_TYPE, LED_PIN, COLOR_ORDER>(leds, NUM_LEDS).setCorrection( TypicalLEDStrip );
  FastLED.setBrightness(  BRIGHTNESS );
  currentPalette = myRedCyanPalette_p;
  currentBlending = LINEARBLEND;
  /*ChangePalettePeriodically();*/
  static uint8_t startIndex = 0;
  startIndex = startIndex + 1; /* motion speed */
  FillLEDsFromPaletteColors( startIndex);
  FastLED.show();
  FastLED.delay(5000 / UPDATES_PER_SECOND);
void FillLEDsFromPaletteColors( uint8_t colorIndex)
  uint8_t brightness = 255;
  for ( int i = 0; i < NUM_LEDS; i++) {
    leds[i] = ColorFromPalette( currentPalette, colorIndex, brightness, currentBlending);
    colorIndex += 3;
// There are several different palettes of colors demonstrated here.
// FastLED provides several 'preset' palettes: RainbowColors_p, RainbowStripeColors_p,
// OceanColors_p, CloudColors_p, LavaColors_p, ForestColors_p, and PartyColors_p.
// Additionally, you can manually define your own color palettes, or you can write
// code that creates color palettes on the fly.  All are shown here.
/*void ChangePalettePeriodically()
    uint8_t secondHand = (millis() / 1000) % 60;
    static uint8_t lastSecond = 99;
    if( lastSecond != secondHand) {
        lastSecond = secondHand;
        if( secondHand ==  0)  { currentPalette = myRedCyanPalette_p;         currentBlending = LINEARBLEND; }
        if( secondHand == 10)  { currentPalette = myRedCyanPalette_p;   currentBlending = NOBLEND;  }
        if( secondHand == 15)  { currentPalette = myRedCyanPalette_p;   currentBlending = LINEARBLEND; }
        if( secondHand == 20)  {  currentPalette = myRedCyanPalette_p;            currentBlending = LINEARBLEND; }
        if( secondHand == 25)  {  currentPalette = myRedCyanPalette_p;               currentBlending = LINEARBLEND; }
        if( secondHand == 30)  {  currentPalette = myRedCyanPalette_p;        currentBlending = NOBLEND; }
        if( secondHand == 35)  {  currentPalette = myRedCyanPalette_p;        currentBlending = LINEARBLEND; }
        if( secondHand == 40)  { currentPalette = myRedCyanPalette_p;           currentBlending = LINEARBLEND; }
        if( secondHand == 45)  { currentPalette = myRedCyanPalette_p;           currentBlending = LINEARBLEND; }
        if( secondHand == 50)  { currentPalette = myRedCyanPalette_p; currentBlending = NOBLEND;  }
        if( secondHand == 55)  { currentPalette = myRedCyanPalette_p;      currentBlending = LINEARBLEND; }
// This function fills the palette with totally random colors.
void SetupTotallyRandomPalette()
  for ( int i = 0; i < 16; i++) {
    currentPalette[i] = CHSV( random8(), 255, random8());
// This function sets up a palette of black and white stripes,
// using code.  Since the palette is effectively an array of
// sixteen CRGB colors, the various fill_* functions can be used
// to set them up.
void SetupBlackAndWhiteStripedPalette()
  // 'black out' all 16 palette entries...
  fill_solid( currentPalette, 16, CRGB::Black);
  // and set every fourth one to white.
  currentPalette[0] = CRGB::White;
  currentPalette[4] = CRGB::White;
  currentPalette[8] = CRGB::White;
  currentPalette[12] = CRGB::White;
// This function sets up a palette of purple and green stripes.
void SetupPurpleAndGreenPalette()
  CRGB purple = CHSV( HUE_PURPLE, 255, 255);
  CRGB green  = CHSV( HUE_GREEN, 255, 255);
  CRGB black  = CRGB::Black;
  currentPalette = CRGBPalette16(
                     green,  green,  black,  black,
                     purple, purple, black,  black,
                     purple, purple, black,  black );
// This example shows how to set up a static color palette
// which is stored in PROGMEM (flash), which is almost always more
// plentiful than RAM.  A static PROGMEM palette like this
// takes up 64 bytes of flash.
const TProgmemPalette16 myRedWhiteBluePalette_p PROGMEM =
  CRGB::Red,
  CRGB::Gray, // 'white' is too bright compared to red and blue
  CRGB::Blue,
  CRGB::Black,
  CRGB::Red,
  CRGB::Gray,
  CRGB::Blue,
  CRGB::Black,
  CRGB::Red,
  CRGB::Red,
  CRGB::Gray,
  CRGB::Gray,
  CRGB::Blue,
  CRGB::Blue,
  CRGB::Black,
  CRGB::Black
const TProgmemPalette16 myRedCyanPalette_p PROGMEM =
  CRGB::Red,
  CRGB::Red,
  CRGB::Red,
  CRGB::Red,
  // CRGB::Gray, // 'white' is too bright compared to red and blue
  CRGB::Cyan,
  CRGB::Cyan,
  CRGB::Cyan,
  CRGB::Cyan,
  CRGB::Red,
  //CRGB::Black,
  /* CRGB::Red,
    // CRGB::Gray,
    CRGB::Cyan,
    // CRGB::Black,
    CRGB::Red,
    CRGB::Red,
    //CRGB::Gray,
    //CRGB::Gray,
    CRGB::Cyan,
    CRGB::Cyan,
    //CRGB::Black,
    //CRGB::Black*/
// Additional notes on FastLED compact palettes:
// Normally, in computer graphics, the palette (or "color lookup table")
// has 256 entries, each containing a specific 24-bit RGB color.  You can then
// index into the color palette using a simple 8-bit (one byte) value.
// A 256-entry color palette takes up 768 bytes of RAM, which on Arduino
// is quite possibly "too many" bytes.
// FastLED does offer traditional 256-element palettes, for setups that
// can afford the 768-byte cost in RAM.
// However, FastLED also offers a compact alternative.  FastLED offers
// palettes that store 16 distinct entries, but can be accessed AS IF
// they actually have 256 entries; this is accomplished by interpolating
// between the 16 explicit entries to create fifteen intermediate palette
// entries between each pair.
// So for example, if you set the first two explicit entries of a compact
// palette to Green (0,255,0) and Blue (0,0,255), and then retrieved
// the first sixteen entries from the virtual palette (of 256), you'd get
// Green, followed by a smooth gradient from green-to-blue, and then Blue.
