RC car control
i am trying to controll an rc car and cant figer out how to make the weels spin the connecter is just like a servo moter
Try researching how to control a servo.. the operation is identical.
i tryed that it diddent work >:( :cry:
ill try it again i guess ::slight_smile:
thank you :wink:
i got it to work thank you very much
edit: one more Q how do you go backwards :smiley:
RC car speed controls have a few different varieties.. some can only go forward. some can foward/brake, some can do forward and reverse. You need to look at the spec for your unit.
They function the same as a servo. they rely on pulse timing. try to learn how to control a servo first. when you can make it rotate both clockwise and counter- from center position, you will have your speed control working.
you may need to 'train' your speed control to know what the upper/lower bounds are.
