RC Car Flashing Police Lights......Newbie
Hello all-
I am very new to the arduino, I have a little knowledge playing around with leds but am far from really knowing what I am doing. I want to build some flashing lights to go into my rc car, here is a link that I found
For Toys Custom Built 1/18 1/24 Scale Police Car Circuit Boards - YouTube!
I want to build this exactly, maybe not so many different functions but as close as possible.
I need to know what to use, maybe ideas, maybe schematics, what components.
Again I am newbie so bear with me. I really appreciate all the support that this forum gives, I hope that I will be able to give back soon!!
Thanks Again
Brandon
Hi, this is a very simple circuit that kinda looks light police car lights. Just connect the long leg of a red LED to the arduino on pin 13 and the other leg to the ground (GND) pin. Do the same with a blue LED but on pin 12. Then copy and paste this code to a sketch.
//Turns on two LEDs like police car lights.
int red = 13;
int blue = 12;
  pinMode(red, OUTPUT);
  pinMode(blue, OUTPUT);
  digitalWrite(red, HIGH); //turns led on
  delay(250);               //waits
  digitalWrite(red, LOW);   //turns led off
  digitalWrite(blue, HIGH);
  delay(250);
  digitalWrite(blue, LOW);
All you need ...
http://nootropicdesign.com/projectlab/2010/01/08/arduino-police-lights/
Here is the problem though, I am new to all of this, I am not sure what components to use, it needs to be small enough that I can fit/hide it in a rc car, also I want to run this off a 9v battery. I need to do this with 6 lights, spitting image of the video is what I need.
I dont want to buy a kit I want to learn how to build this, I also need long enough wires to reach different parts of the vehicle, basically just like the video.
Thanks Again I think we are getting somewhere.
brandoncook:
It's laudable that you want to learn everything, but trying to do it all from scratch on your first project isn't sensible. I suggest you buy a standard Arduino and wire up the appropriate number of LEDs. You'll need to write a sketch to make them light up and flash etc however you want. This is entirely suitable for a first project. Building your own protoboard Arduino, I'd suggest, isn't.
brandoncook:
Do you understand that anywhere you can connect a LED, you can connect a pair of wires to a remote LED? Your objection here doesn't make any sense.
