RC car motor control
Hello,
I am new to coding on Arduino. I am building an RC car and I am currently working on controlling the motor speed with a Joystick. I built my own H-bridge out of BJTs. So far the forward direction works and I am able to control the speed. However, when I try the backwards direction, the motor rolls backwards but I am not able to control how fast it goes. Could anyone look at my code and tell me what could be done better?
code:
const int Joystick1 = A1;
int motorPin1 = 3;
int motorPin2 = 2;
int Joy1 = analogRead(Joystick1);
Serial.print("Joystick 1: ");
Serial.print(Joy1);
if(Joy1 > 510)
analogWrite(motorPin1, Joy1);
Serial.print("Forward motor speed: ");
Serial.print(Joy1);
else analogWrite(motorPin1, 0);
int backspeed;
if(Joy1 < 500 && Joy1 >=0)
analogWrite(motorPin2, 1023 - Joy1);
Serial.print("Backward motor speed: ");
Serial.print(1023 - Joy1);
else analogWrite(motorPin2, 0);
delay(1);
Hello there!
Can you post a schematic of your wiring so we can see where any wires and components are connected?
  if(Joy1 > 510)
analogWrite takes a value from 0-255, not 510 to whatever.
You must first find the A/D range that the joystick returns (e.g. 210 to 820),
and then use map() and constrain() to convert that into the values for forwards and reverse.
Use the Help>Reference tab in the IDE.
Leo..
Or just take the pot reading of 0 to 1023 (0 to 0x03FF) and shift it right two bits to convert if to 0 to 255 (0 to 0xFF).
shiftPotRead = (analogRead(Ax)) >>2;
What I understand is that OP wants forwards and reverse with a deadband from that joystick.
And a joystick usually doesn't go from 0-1023.
Could be something like
speedForward = map(joy1, 520, 850, 50, 255);
520-850 being the forward range of the joystick, and 50 the minimum PWM value to move the motor.
Leo..
